Hey guys,
Here is a new question that I have not yet been able to find in the hall of wissdom.
This concerns a '99 LT that has just given the well-known ABS 1 Hz message on the dashlights. It showed up while driving on the highway, with slightly damp weather. The battery is new and measures 13.3v and the battery terminals are tight. At first the OBD dongle indicated error codes in the hall sensor signal 1 (0335) and signal 2 (0385). After I restarted the engine the error messages disappeared. I have to mention that the enige came to life after starting in two times. I'm going to see the brake fluid reservoir at the back this evening, front is full. Since I have scheduled a serious motorcycle ride next Friday, any help is welcome to take any uncertainties away. If I find anything myself, I will let you know. Thanks in advance...
