So what do you guys make of this?
A week or two ago I wheeled Lorelei out of the garage to go visit a friend of mine, only to discover a large puddle had formed underneath her after she'd idled in the garage for for a minute or so while I found my friend in the GPS. I quickly shut her off, stuck my fingers in the puddle, and took a whiff. Gasoline. Swell.
After searching the FAQs and forums here I now know fuel leaks were more common among the quick-disconnects on the tanks of the 2001-2003 bikes, but I didn't discover anything about leaky fuel systems on a 1999.
Even stranger is this: I stripped her topless last night and cranked her up, hoping to get a bead on where the fuel might be coming from.
I got no leak at all. Everything worked as designed.
So I put her all back together (after doing some maintenance stuff I'd been meaning to unbutton the Tupperware for but had been putting off) and test-rode her. Still nothing. No leak at all.
Before I had wheeled her out of the garage on that fateful morning, she had sat idle for two weeks after two-and-a-half solid hours of high-speed highway riding. Could some expanding fuel somewhere in the fuel system be the culprit?
I'm baffled. As a hardware engineer, serious problems that magically go away frighten me--they always seem to come back at the most inopportune times (like right before the product delivery date).
Any thoughts, gang?
Other than oil changes, I haven't worked on my bike one bit for some backgroud. I'm capable but the 2002 LTC is my car and I don't have the time to do anything but ride it (darn) :) Oh yeah, almost 70k miles on it.
However, coming home from St Louis last thurs/fri, jumped the bike fri morn to ride the rest of the way home and...gas!! pumping on the ground.
Had a 100 mile tow to Ft Wayne (Thanks Bob Woodson BMW, great folks there!!) and the tech found the QD was cracked.
Ok, so what....well, my mileage took a dive a couple months ago (to 30 MPH) and I just knew it was the O2 sensor...turns out it was just unplugged, that was causing gas smells on startup and inbetween.
Sooooo....what I think is that the O2 sensor problem may have masked the cracked fuel QD all that time (I was still getting small wiff's of gas here and there) and finally bit the dust.
Sooooo....who knows??? I had my bike at the dealer for service a couple of times but maybe it was a small crack that grew to total failure, not sure but its worth a thought. Maybe you have the same problem.
regards..geo
My 99' had a fuel leak a few months back. I had started her up in the garage and cruised out on the driveway. Parked her for a few minutes and when I came back noticed a small puddle. Long story short, it was the fuel lines (I have no quick connects, but there are a couple of screw clamps and they became loose). Only leaked when I kind of moved the lines around when the bike was running. Tightened them up and no leak since.
