1 - 11 of 11 Posts
I am thinking that my RT's battery and the tire pressure monitors may be on their last legs. The bike is a '16 R1200-RT and was manufactured in Feb/2016. I've been riding the bike for 30K flawless miles. Just recently I have discovered that I need to reset the desired settings on the gauge cluster at least one time per driving event. After starting out the bike's instrument clusters setting will suddenly return to the factory settings. I then have to stop and select the desired settings using the "wonder wheel". Other that this inconvenience the RT's gauges the bike has preformed flawlessly. Has anyone else had this problem?
Regarding the tire pressure monitors, after starting out and riding for a short time the low pressure time warning presents itself on the gauge cluster. After this happens I stop and confirm that the tires are at the proper pressure. I then drive on for a time and the warning lights then return to normal.
I'd like to think that both of these issues are a result of a weak battery and not a gauge cluster that is going bad.
I'll appreciate any input.
Jim Prior
Cottonwood Heights, Utah
I have a 16 rt and my front sensor would drop out at about 6 miles from home. Under 10 miles later it would reset to tire pressure. If the sensor did not restart I would get the low pressure warning light. Again once the sensor started working the warning light would go out. This gradually got worse and I had the dealer check them out. They replaced them under warranty. I had about 16000 miles on the odometer. Funny thing was the front sensor is what I told them about. When I picked up the bike the front sensor was malfunctioning again. I called . Their tech said he tested both front and rear and the rear said it was bad. So I ended up with both R and F replaced.
Jim Prior
Hi Jim, my '16 was also built in Feb 2016 and its TPMS sensors recently died at about 44K miles, albeit slowly over about 3 months, so I had them replaced by a local dealer. I replace the battery every 3 years regardless of condition--it's really pretty cheap insurance and the consequences are significant I feel. I'd put in a new battery. Surprised your tire sensors are going out if they are as the bike does not have the miles even if a similar age.
First time I hear that the TPMS sensors batteries can be changed?
I don't see any mention of this in my repair manual.
How is it done?
2015 R1200RT
How is it done?
The first have to be taken out of rim, obviously. But there is a hard epoxy covering the battery that needs to be removed. Then the battery that is in there is hard to find, but EBay has them. Some others have used a slightly smaller battery. Then you put in your own hot glue or something to cover it back up again.
Here is a YouTube video showing the process.
How is it done?
I think he meant the bikes battery every three years, TPMS batteries last far longer than that.
Three years John? I thought 5, and that is when I always preemptively change my bike's battery. Never had one gone bad on me yet, but then I always plug in a good maintenance charger whenever the bike is parked in the garage.
I am only on my third battery in 16 years on the LT, got 5 years out of the OEM and 9 on the first PC-680. Neither was a dead battery just appeared to be weak. Never had a tender on the OEM.
I was referring to the 12v battery the bike uses, not the TPMS sensors. I change out the 12v battery every 3y regardless of battery health--it's cheap insurance against being stranded, or having you gauge cluster get wonky. I don't use a trickle charger as I ride the bike often enough to avoid this practice. The TPMS sensors were replaced by the dealer for me a few months ago. For reasons unkown to me historically one could buy 3-4-5 maybe 6y rated car batteries. I just went to replace the 12v in my F Fusion Hybrid and from 3 local shops contacted 2y was the maximum rating you could purchase at any price. And FWIW the battery on our 2015 Subaru Forester lasted less than 2y each.
That's a lot of work for a battery. I bought sensors on eBay for $16 and they work great. Had no problem activating them with the GS-911.
2014 RT
Jim Prior
I had a similar issue and stuck my head up my ass because the instruments always reset. Long and short, one time stranded with a dead battery taught me a valuable lesson... a new battery is much is cheaper than a tow. I seem to get 4 years out of a battery so I would replace that first and see if it fixes your issue. If not, you needed a new battery anyway and potentially saved a real hassle down the road. I am also having an issue with my rear TPMS, which is unrelated. There is a difference, that is described in the owner's manual, between the warning light for low pressure, bad TPMS battery, and lost connection to the TPMS unit. Make sure you know which it is and then you can diagnose what needs to be done. My issue is a communication failure so I need to replace the TPMS on my next tire change. Of course, that is the most expensive issue to resolve. It is damn concerning when it lights up. It sends a shiver up your spine when you see the warning light for tire failure pop up. It pisses me off to have to replace the unit (over $250) but the peace of mind of not seeing that warning light is worth it to me and it is a quick fix when the tire is being replaced anyway.
Good luck!
1 - 11 of 11 Posts
