Big shout of thanks to gr8ridn for explaining the tools to do the timing on a WetHead! And I would have never known my timing was off or what to do about it without you and your great posts and pictures.
R1200GSW Cam Timing Adjustment
Another big shout of thanks to Jim Baden And JVB Productions. I do not know if without a tech session, and seeing this in person if I would have ever done this. The DVD was clear and concise and was a great reference and was great for a visual leaner like myself. How about a coolant one as the clock is ticking. When I asked my dealer about service on it he said "oh, it is lifetime".
As to the tools they are very nice but you pay for it. Knowing how to use them is very important and one must do a bit of reading to get all the information gathered you need. Researching for the torque specs of various things is worth beforehand to have ready when you need them.
This was my 12K a bit early 11,600 on a 15 RT. I had previously done the brake flush using the GS-911, and installed speed bleeders in all three calipers. Three different sizes I might add! I had done the air filter when I was in doing some wiring and had to remove Tupperware almost to the filter and said bag it I will do it then. About 10,500 miles.
Nothing new under the sun for the valves. Jim's tip on bending the feeler in a arch is an important tip. It works very nice giving you reliable readings.
Left Intake 13 13 Exhaust 37 37 Tight Right Intake 14 14 Exhaust 36 37
As to the timing, it was off. A lot IMHO on the Left, and not so much on the Right. But both were off. Both had to be adjusted.
I used the tools as described by gr8ridn and it all worked flawlessly! The cam chain tension tool is without a doubt one of the coolest tools I ever used! 3 Clicks you are there just too cool. The TDC tool is pretty sporty also but as I said you do pay for the privilege to lay hands on these tools. Also I thought I might lend them out so others could use them but I have shut that down. Only because if you do not understand them or ham fist them I think there is the potential to break them. At the very least loose parts of them as the cam chain tension tool is 3 pieces alone. I will however help someone in my garage. If someone knows how to check valves and can turn their own wrench I would share my tools with them. Make sure you have a 3/8" torque in the right ranges to cover the ranges you work with here. From like 10 Nm for the valve cover bolts to 65 Nm for the cam gear bolts. I did not, I do now. The 16MM crows foot works well on those cam gear bolts.
Only other thing I did was install Iridium Plugs.
Well I did change the oil, oil filter, and final drive fluid too.
It was a good day of turning wrenches today! I had a long good day learning a bunch of stuff and it was way cool.
