I am just about ready to do the 12k miles maintenance on my 2021 RT, and I thought that I would share something with the community that should save some money for those who also do their own maintenance. The major differences between the 12k and 6k miles maintenance are that for the 12k miles, you need to change the FD oil, which is extremely simple. Next, you are supposed to change the air filter, which is somewhat of a PITA, since lots of fairing and trims needs to be removed, but otherwise quite simple. Of course, you also have to do the valve clearance check. The last big thing that one is supposed to do is to change the spark-plugs. This last part is what this thread is about!
BMW specifies Iridium spark-plugs for the 1250 boxers. Specifically, the NGK LMAR8AI-10. The very first question that some will ask right away is why change at only 12k miles? That's an iridium plug, and it should last for at least 50k miles! Good question, and partial answer from me is that, it's what BMW specifies, and if you want to make sure that BMW have absolutely no reasons to deny you any potential warranty service in the future, then you should make the change, and keep the old plugs off the bike for future use if they looks to be OK. Keep reading. There some more data on this later.
The next question will come when you start shopping for the specified plug. Wow, why so expensive??? It seems that this plug is only used for the 1250 shiftcam boxers, as far as I can tell. Buying the plug from BMW dealer will cost you more than $30 each, in the US (our friends in the UK and EU countries have it at much lower price). Even Beemerboneyard, who usually have much lower price, is selling them for $54.38 per pair. The best price that I had found was here: Iridium Spark Plug - BMW R1200 2017on R1250; 12 12 8 560 811 / LMAR8AI-10 / NGK for $21.99 each. Can I do any better than this?
Well, in looking around I came across this: NGK LMAR8AI-8. BMW specifies it for the K1600s, and this plug is much cheaper. Best price that I have found was here: NGK 92288 LMAR8AI-8 Laser Iridium Spark Plug at $12.79 each!
So, what is the difference between the 2 plugs, since from the part number, that difference is in the last -10 vs -8. What does that really mean? It turns out that the two plugs are the same plug, with the -10 having the electrode gaped at 1 mm from the factory, while the -8 are gaped from the factory at 0.8 mm. Just for an FYI, here are the meanings of the rest of the NGK part number, specifically as applied to the NGK LMAR8AI-10 :
L- Plug Type Thread Reach: 26.5mm
MA- Metal Shell
R-Resistor
Heat Rating Number 8
A-Firing End Construction Special Design
I-Firing End Construction Single Iridium Spark Plug
Stock Number - 94319
Type - Laser Iridium
Plug Diameter = 10mm
Thread Length = 26.5mm
Hex Nut = 14mm
Heat Range = 8
Resistor = YES
How you use the above information is up to you, as always! It's your bike. However, should you decide to buy the -8 and open up the gap to 1 mm, then I should caution you to be very careful in how you do that. The center iridium electrode is very thin and delicate. You absolutely need to use the proper spark-plug gaping tool to do the job.
Last note is that, I always refer to posts in Adventure Riders Forum for accurate technical information. Those guys are very much more knowledgeable in the technical areas than in any other forums. I had discovered the meaning of the dash-number from there, specifically from this thread: 2019 R1250GSA Spark Plugs/Unicorns? I think that it's worthwhile for you to at least scan over the posts. Now, back to why you might want to consider changing the plugs as early as 12k miles, or at the very least give them a very good examination keeping your riding environment in mind, you need to read post #71 on page 4.
Ride safe!
MA- Metal Shell
R-Resistor
Hex Nut = 14mm
Heat Range = 8
Resistor = YES
Ride safe!
