I found an 08 final drive on ebay at a reasonable price , with 20,876 miles on it. My question is: will it work on an 02 lt?
Why not rebuild yours?olddog1946 said:I found an 08 final drive on ebay at a reasonable price , with 20,876 miles on it. My question is: will it work on an 02 lt?
Saddleman is correct. BMW states that the final drives changed with a a build data of 01/01.olddog1946 said:I found an 08 final drive on ebay at a reasonable price , with 20,876 miles on it. My question is: will it work on an 02 lt?
jzeiler said:Dave's correct even if he does drive on studded tires.
I use the oil that it came with. I drain it, look for flakes & then reinstall the same oil.JoeTerry said::histerica :histerica :histerica :histerica :histerica
He needs another set with bigger studs and should go tear it up on a frozen lake.
So just to stir the pot, what kind of FD oil do you use when it's below 20F Dave?
