1 - 3 of 3 Posts
Hello everyone! I own a 2007 K1200LT. The electric windscreen has worked intermittently for about 6 months now. It will not work, and then suddenly works again. Currently it only goes up, not down (lots of fun in strong crosswinds!). This also happened some years back. I had it at my dealer for service at that time and they replaced a relay. It fixed the problem until recently. I no longer have the service record of what relay was replaced and the dealer has been no help over the phone. I have not had much luck looking online figuring out which relay and what location controls the electric windscreen. Has anyone had the same problem and knows which relay to replace? Thanks!
I have had very similar symptoms, it was the switch contacts in the button control
There are two relays located under the dash cover (right behind the windscreen). PN 61 36 1 393 415 MINIRELAY, CHANGE-OVER CONTACT, GREY
Here is where they both are (#1 &#10 are together) and two diagrams to help you troubleshoot.
1 - 3 of 3 Posts
