1 - 3 of 3 Posts
THANKS TO YOU GUYS MY 05 1200LT IS BACK ON THE ROAD AGAIN. after bypassing the alarm (with some issues) , that made it turn over i still had a issue of it not running. if i sprayed carb cleaner into the intake it would run . that told me it was fuel related. removed the tank, removed the fuel pump and to my surprise the pressure hose came off the outlet side of the line. ( the dealer did not crimp the hose clamp good enough last year when the pump was replaced). installed the hose, added another clamp for safety sake installed the pump , installed the tank and away we go. what a ordeal but again thanks to you guys i fixed it.
Yeah!! It is always good to find and fix the gremlins. Now go ride it you deserve it.
What a sense of accomplishment...what a forum and what a ride. :dance:
1 - 3 of 3 Posts
