Is there a "soft" reset procedure for the IABS system on the 2005 K1200LT? I just finished flushing the ABS system, clutch and bled all brakes as well as new pads all the way around. The ABS failure lamp and the "triangle" now continuously alternate flashing. Never had this problem before. The fluid I removed was not all that bad (I change every year or two). The system cycles on start-up and servos engage but then continues flashing after moving. I also replaced the battery (overdue). The bike has plenty of braking but worries me with the fault codes indicators flashing. I still have to check the ABS status on a hard packed gravel road but as I said there is plenty of whoa power. The brake light is not lit nor are there any fluid leaks with all reservoirs at full capacity. I did, however, break one of the plastic caps on the ABS unit itself (I believe the front reservoir) but repaired it with a little JB Weld and it appears fine. Can anyone give me some direction? I would prefer to do a "soft" reset like I've read about the pre-2000 bikes before I have to purchase a GS-911 diagnostic tool.
BTW: I live in New York State's Hudson Valley. Thanks to all.
