I am looking at a '04 K1200GT. :D She's a beauty...and I need a run around bike. The bike only has 8k on it and appears to be sound.
Are there any issues that I should be aware of? Is there anything to look for?
Any help would be appreciated.
It is the fastest color....Blue :wave
Discussion Starter · #2 ·
I am looking at a '04 K1200GT. Something to ride around town in....not quite as cumbersome as the LT.
Has anybody had any problems with the '04 GT?
What should I look for or look out for?
Any help would be appreciated. :D
Other then hang on for dear life LOL that's one fun bike
No known problems to speak of - the only complaint I have with mine is a few of the tupperware screws that can be maddening, pretty standard fare for BMW. You will love it!
Re: antenna problem
I am curious about what to do with the antenna on the K1200LT when it comes to putting a bike cover on. Even the Gold Wing has a folding antenna so as to facilitate a bike cover with no problem - but BMW chose not to consider that. Even taking the antenna off is not that easy. Is there any other short-type antenna that will fit the BMW mounting system? Even the BMW antenna mounting system is different than any other factory motorcycle antenna mounting system.
My buddy bought an 03 this past spring, really a great bike and in my opinion better looking then the new GT's.
Typical RS/GT issues:
Broken plastic fuel disconnects (look for them to have been replaced with metal ones).
Rear main seal leak. Look for a oil seep along the transmission / engine mating faces.
Clutch slave leak ... the clutch slave should have been resealed with a new one with a wiper.
Headlight ground wire failure ... should be replaced with a newer headlamp assembly.
Weep/seep at timing chain cover.
Rough idle ... there was a "voluntary recall" on the ECU's. Customers complaining of rough idle, and having a build date within a specific time window, were eligible for a free ECU replacement.
