1 - 3 of 3 Posts
My radio has been acting up. here are the symptoms:
Turns on and works fine.
After awhile, controls won't work but it keeps playing. Then goes out completely and a "No Radio" message appears.
intercom, phone, radar, aux input(ipod) all still work fine.
I charged up the battery and radio worked for awhile and then did the same thing.
Battery seems to be holding a charge and all other electrics work fine.
Any ideas?
Thanks for any help.
Ron
Any ideas?
Ron
Hey, Ron - kinda sounds like it's on it's way to radio heaven. However - try the battery disconnect for a half hour or so. That process has fixed some other radios with similar problems. No guarantee, but worth a try.
And after you hook the battery back up, do the TPS re-set at the throttle grip:
Key on - no start.
Twist throttle wide open and release (twice)
Key off.
Key on - start the engine and ride around the block.
Good luck.
1 - 3 of 3 Posts
