I did one not long ago. Be sure to get the four wire sensor and cut the old sensor end of the plug off. Solder the OEM plug to the new sensor. There are two white's, it doesn't matter which white on the corresponding wires they go to .dnifong said:George,
Have you done it? "use the universal model that is" Im a little nervous about cutting the wires.
The spark knock is driving me crazy. I going to start changing parts until is stops. "Motor included"![]()
Bosch part # 0 258 003 475... no cutting of wires.... theres a post in here somewhere with some good tips in doing the replacement... attaching a string when pulling the wire thru so u can snake the new one back up backdnifong said:George,
I would be VERY wary of using any splices on an O2 sensor. The signal is VERY small and is supposed to swing from 400mv to 600mv..constantly switching up and down. Any extra resistance induced by the splices would wreak havoc with the readings. Whenever I have to "splice" an O2 sensor connector to the pigtail I always solider it with silverbearing solider and cover it with weatherproof heatshrink, the kind that has a heat activated glue on the inside surface to seal it up good. Like the stuff here http://www.jamestowndistributors.com/userportal/show_product.do?pid=669gbob said:I have installed the Bosch universal ,the wires that are cut and spliced are not the bike wire harness
the universal Bosch comes with the splice kit , read the instructions and you will have no problems .
The splice must be clean and secure as the signal is from .3 to about .9 VDC and it switches up and down many times a second
