This happened the same time left turn and left 4 way not working and engine will not turn over where should i start have it stripped to the starter relay power to the red wire and green but nothing changes when start button is pressed
have you checked all the fuses?
Perhaps the engine disable/alarm ?
check the kickstand switch....
just thinkin out loud...
what is the Voltage on the battery?
i found the problem pulled the trunk off panel under had a mouse nest and chewed some of the wires into soldered the wires back together heat shrank everything works.
2011 R1200RT
I am so happy we have lots of street cats in my neighborhood.:D
My bikes and the old Carrera in the garage never had a rodent problem.
