Which Hitch to use - BMW Luxury Touring Community
post #1 of 8 Old Apr 12th, 2006, 12:56 am Thread Starter
Question Which Hitch to use
I would like to know what type of hitches everybody uses and how they like them. I will be pulling a Little Guy Rascal. Thanks for all your help
ColoSpgs_K1200LT is offline
post #2 of 8 Old Apr 12th, 2006, 1:03 am
I use the Dauntless. It is very easy to remove (for appearance sake or to change the back tire) as it uses 2 "linch pins". Also came with the proper wiring so that it doesn't screw up the ABS system.
I know others here have used the Bushtech and like it, but it makes changing the back tire a PIA (in my humble opinion).
jorawro is offline
post #3 of 8 Old Apr 12th, 2006, 1:27 am
BillCav's Avatar
Hitch
Ditto. I also have a Dauntless.
Cheers, Bill
BillCav is offline
post #4 of 8 Old Apr 12th, 2006, 6:49 am
Dean_BMW's Avatar
I use Dauntless as well. I would also recommend their isolator wiring harness.
Dean_BMW is offline
post #5 of 8 Old Apr 12th, 2006, 3:30 pm
SilverBuffalo's Avatar
I had a Dauntless and replaced it with a Bushtec.
Dauntless makes a great hitch, looks great, partially remove-able to change out the tire, very convenient
So why did I take it off my LT and replace it with a Bushtec?
Bushtec pulls from the lower motormount.
Take a good look at what's holding up your bags and tailsection, it's pretty wimpy.
Dauntless pulls from the hollow tubular frame and saddlebag mount, my theory is in time with the trailer pulling back and down on the hitch with every bump, sooner or later the rear subframe is going to stress crack just like the old airhead BMW's did if you put a top box on.
Now that's not to say that the Bushtec is the perfect hitch, it's more work to change a tire, 3 bolts on the front and 2 on the rear of the hitch.
And as I just found out last week you also have to remove the front bolts of the hitch to remove the right side footpeg bracket when you change the transmission oil.
You decide, it depends on the weight of your trailer and what type of roads you intend to ride on, is the Bushtec worth the extra effort, in my opinion yes (ymmv)
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #6 of 8 Old Apr 12th, 2006, 8:38 pm
RonKMiller's Avatar
I was unhappy with my Bushtec until I welded the the center of the "X" mounting straps on the rear. It is now as solid as a rock. Does not move at all.
I agree that it is by far the best design, although a bit inconvenient...
WARNING: Do not attempt this while on your scoot - you MUST remove it or risk frying some VERY expensive electronics! I simply clamped mine in the mounted position with some Vice Grips, unbolted it, welded, then re - installed it.
"Like Butt-ahh!"
RonKMiller is offline
post #7 of 8 Old Apr 13th, 2006, 7:00 am
2Wheelroadtrip's Avatar
I use the Hitch doctor one because it is rock solid. It pulls from the frame up front. It is not as easy to change a tire. You have 4 bolts. 3 that have to be loosened and one has to be removed. I bought it because I saw a picture of the dauntless that was bent from the trailer hitting a curb. I always overload the trailer.
2Wheelroadtrip (Barney)
03 LTC
82 Aspencade
Time Out camper
It's not where we go. It's that we go.
The information from this site and its members has proven to be invaluable again.
2Wheelroadtrip is offline
post #8 of 8 Old Apr 13th, 2006, 10:46 am
lenny's Avatar
what did you use for a wiring harness?
lenny is offline
Trailer Hitch rodgtc Trailers, Sidecars, & Trikes 19 Apr 24th, 2009 9:58 am
Has anyone built their own hitch? Holy Cow Trailers, Sidecars, & Trikes 38 Nov 15th, 2008 9:35 am
Question about Duantless hitch and Bushtec trailer SilverBuffalo Trailers, Sidecars, & Trikes 3 Oct 10th, 2005 8:04 am
