Now need to replace front tire on LT trike--????? - BMW Luxury Touring Community
post #1 of 25 Old Jan 27th, 2013, 2:54 pm Thread Starter
Question Now need to replace front tire on LT trike--?????
Rode my 05 LT with a new Hannigan trike kit to an RTE today. The helpful guys pointed out that the dunlap front tire was cupping and that there was not much tread left--so now the search begins. What tire works best for you trike riders. My msc instructor has a gold wing trike and has a motorcycle tire mounted backwards on the front. He said that was recommended for trikes??????????
I have been using pr3 on the RT and did not experience cupping but since the ft wheel stays upright at all times on the trike, it seems that another design would be better suited ,.
The trike is about 350 pounds heavier that an LT, but most of that weight is carried by the two auto tires on the rear. I would think a normal high quality LT tire would work OK, but what are the experiences of this group of trike riders.
After the cupping was pointed out to me, the ride home was rougher!!!!!!!!!!!
Any ideas?
EricSuz is offline
post #2 of 25 Old Jan 27th, 2013, 3:14 pm
Gold Supporter
GHOSTRACER's Avatar
Re: Now need to replace front tire on LT trike--?????
Any ideas?
Sorry Eric
USN Retired
IBA #37743
2005 K1200LT O'l Blue (Mine)
2002 R1150RT (Hers)
Cage-2006 SLK 280
Previous Rides: 2006 VTX 1300R, 1986 CB650 Nighthawk, 1982 CM450, Countless Dirt Bikes
GHOSTRACER is offline
post #3 of 25 Old Jan 27th, 2013, 4:36 pm
I have an LT with a Hannigan sidecar. I have heard that using a rear tire of the correct size to mount on the front with rotation opposite indicated by the arrow works great. I have no data or experience to substantiate this but plan to give it a try. Anybody know more??
afgrava is offline
post #4 of 25 Old Jan 27th, 2013, 9:26 pm
dasmith59's Avatar
Just today I ordered a Michelin PilotActiv rear tire for the front on my 02 LTHannigan. I will mount it for reverse rotation. This is what I got out of all the posts on front tires on this site as well as another trike forum. My front tire is also cupping.
Don S
dasmith59 is offline
post #5 of 25 Old Jan 27th, 2013, 9:58 pm Thread Starter
Don,
Did you order the Pilot Activ 130/70/17 bias ply? There is also a letter designator H plus others. I'm not sure what that means
Eric
EricSuz is offline
post #6 of 25 Old Jan 28th, 2013, 5:56 am
dasmith59's Avatar
Eric
I only saw the one with the "H" designation so I ordered it. I am hoping that it will be OK.
Don S
post #7 of 25 Old Jan 28th, 2013, 8:38 am
Eric...this forum might be useful for you:
http://www.triketalk.com/index.php
I'm guessing you're already trying to give the Hannigan folks a call by now...let us know what they say.
JimE is offline
post #8 of 25 Old Jan 28th, 2013, 8:57 pm Thread Starter
Thanks, Jim. I have been on that site, but had not registered. Now I have.
I did call Hannigan, but did not get much help. The first guy I talked to said to use Mitzler M880 rear tire. He was a salesman. When I called back when I could not find the proper size m880 rear tire, he refered me to a tech. The tech told me to search on line trike forums to see what actual riders are using!!!!!!!!!!!!!
I will talk to the dealer tomorrow. I think he will be able to get better information than I got when I called Hannigan direct. Totally unexpected result. Guess I should have started with the dealer, but he is closed on Mondays and I couldn't wait. Why? I don't know...
EricSuz is offline
post #9 of 25 Old Jan 29th, 2013, 4:09 pm
Eric
I run the standard Metz frontTire, 42-43 lbs air with no problems, always on the slab at the limit and maybe a little +.
2 up and only touring. Plan on about 6k mile each summer.
Oh, there is one other thing I change that tire every year, kind of peace of mind, it's not expensive considering the options.
Dennis
Beemer2up is offline
post #10 of 25 Old Jan 29th, 2013, 5:48 pm
JPSpen's Avatar
I'd look around and see if I could find a car tire in that size...Or something that would work.
After all. You're running it like a car now..
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #11 of 25 Old Jan 30th, 2013, 5:25 pm Thread Starter
Smile Re: Now need to replace front tire on LT trike--?????
My search is ended. Ordered a Michlin pilot active 130/70 H17 rear tire today. Now the remaining issues are should it be mounted backwards and finding someone who will mount the tire. Thanks Don. You made the search much easier.
EricSuz is offline
post #12 of 25 Old Jan 30th, 2013, 6:19 pm
The flip flop reason on the tire rotation makes sense when you consider the loads on a rear tire are always acceleration and the loads on a front tire are always deceleration. Since the roles are now reversed thus the arrow must point.
post #13 of 25 Old Jan 30th, 2013, 7:42 pm
Call Hannigans and talk to Dave Hannigan. I have talked to him over the phone and at rallies. He always was pleasant and gave good info.
afgrava is offline
post #14 of 25 Old Feb 6th, 2013, 9:22 am
Richco's Avatar
I have read with interest the concept of using a rear tire mounted on the front, but in reverse. I also remember comments by someone that the rear tire was a 130 mm compared to the normal 120 mm width. Also that the wider width may not fit on 2005 and up K1200LT's. If anyone has done the swap on a 2005 LT please comment.
Richard
2005 K1200LT Trike.
Richco is offline
post #15 of 25 Old Feb 9th, 2013, 6:22 pm
I have a 2000 LT Trike. I have a 130 PilotActiv on the front, mounted backwards. Very happy so far. I'll let you know how many miles I get. BMW dealer in LV mounted it during a service.
Jerry
BMWMOA # 134919
2000 LT Hannigan Trike
1986 Suzuki TM400 (gone)
1957 BSA 500 cc Twin (long gone)
1955 BSA Golden Flash (longer gone)
1950 or thereabouts HD 165 cc 2 stroke! (gone in 1954)
scubajgp is offline
post #16 of 25 Old Feb 9th, 2013, 7:21 pm
dasmith59's Avatar
Likewise, I have a 130 PilotActive mounted in reverse. The dealer did the mount and balance. I just picked it up today and have 30 miles on it. It is very neutral as a new tire should be. Need to get some miles on it before any meaningful comments can be made.
Don S
post #17 of 25 Old Feb 10th, 2013, 8:05 pm Thread Starter
Steve installed my 130 70 17 today. Steve pointed out that the tire I had on the front was made in 2004 and had 22000 miles on it. It was hard rubber. Glad I changed it. Rode about 50 miles home, seems better, but, like Don, need more time and miles to be sure.
There was no clearance problem, but could not use a 140. Looked to me less than 1/4 inch clearance.
Rode both the RT and the Trike this morning. I have decided that I like both. Time will tell if I sell one.
EricSuz is offline
post #18 of 25 Old Mar 1st, 2013, 8:19 pm
dasmith59's Avatar
Small update on the front tire. My wife and I went out for lunch yesterday and did ~150 miles on the trike. The trike just handles better since I changed the tire. I am not sure whether mounting the tire backwards, or the increased air pressure or maybe just being a new tire has given us the most benefit but the difference is significant.
Don Smith
post #19 of 25 Old Mar 1st, 2013, 8:23 pm
johnbaker15's Avatar
So why do you mount it backwards/reverse?
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #20 of 25 Old Mar 1st, 2013, 8:33 pm
dasmith59's Avatar
I mounted a rear tire backwards or in reverse because of the inputs for the last five years on trike forums that it will produce better wear and better handling. John Z offers in post #12 above that:
"The flip flop reason on the tire rotation makes sense when you consider the loads on a rear tire are always acceleration and the loads on a front tire are always deceleration. Since the roles are now reversed thus the arrow must point."
Really, I guess I am just following suit.
Don Smith
post #21 of 25 Old Mar 1st, 2013, 8:42 pm
Don Smith
Sorry Don I missed John Z's post...just don't understand how the front's roll on a trike is different than a non trike..or did I miss something else?
But if you get better wear and handeling go with it.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
post #22 of 25 Old Mar 2nd, 2013, 6:25 am
dasmith59's Avatar
Not a problem John. I looked back through this forum as well as a trike forum and the first I saw where they'd tried this approach was in 2007, I think. I didn't want to "reinvent the wheel" and so I just followed suit.
Don Smith
post #23 of 25 Old Mar 2nd, 2013, 11:40 am
I got to thinking about my original statement so I did a bit of research and I was sort of correct. The tread pattern can be designed to remove water best in a particular rotation direction but the structural part is what I to found back me up.
From the Continental site:
Where a tyre has directional arrows moulded upon it, the tyre must be fitted so that the relevant front or rear arrow follows the direction of rotation. Road handling and tyre wear may worsen, or damage to the tyre can occur in extreme circumstances if these instructions are not followed
Found here: Link
Published by Cyril Huze August 23rd, 2009in Builders, Editorial and Wheels.
The arrow tells you which way to mount a tire for maximum water dispersal. Another, less apparent reason for directional arrows is the tread splice.
What is a tread splice? When a tire is manufactured the tread portion of the tire starts out as a long flat strip. This strip is wrapped around the tire and the two ends are cut on an angle so one end overlaps the other rather than having square cut ends.
To further ensure the strength of this bond along the tread splice the directional arrow will show you which way to mount the tire so that when the rider is “on the gas”; the acceleration force on the rear tire is pressing the splice together, rather than peeling it back.
As for braking, 80 % of the braking should take place in the front on most bikes. Therefore, the front tread splice is run in the opposite direction than that of the rear, so when the rider is on the brakes, he’s not peeling the tread splice back.
And that is why you flip a "designated Rear" tire backwards when it is on the front.
post #24 of 25 Old Mar 2nd, 2013, 12:39 pm
I am slow, had to read John Z's post twice to get it into my head. I also didn't know about the thread splice part.
I thought directional mounting had to do with the bias of the way the tire carcass was built.
Just another reason to enjoy reading this forum.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
post #25 of 25 Old Mar 2nd, 2013, 2:06 pm
bikerj's Avatar
Okay, the explanation makes sense for the need to mount a rear tire backwards when used on the front.
With this realization, I assume front tires are manufactured in such a way where the splice is backwards from the get-go because of the fact mentioned that most of the applied forces are from braking. Is this correct?
So, if this is correct, then how do the tire manufacturers deal with unidirectional automotive tires? The same forces are affecting the tires in the same positions of the vehicle in the same manner, but I don't recall different tires for front vs. rear, at least on applications where the tire is same size on all four corners.
Jeff
Big D is my neck of the woods
08 HD wide glide
prior:
07 HD XL1200C (sold!
78 KZ750 twin
76 CB750F
71 CL175 Scrambler
73? Yamaha 100 enduro
bikerj is offline
Front tire change in Sacramento LTFan Northern California 15 Aug 30th, 2012 9:44 pm
Found best Front tire for Trike bassj Trailers, Sidecars, & Trikes 18 Jun 3rd, 2012 12:02 am
Front tire wobble steeler34 K1200LT 3 Aug 8th, 2008 9:37 pm
Trike front tire recomendation? ben1364 Trailers, Sidecars, & Trikes 0 Jan 25th, 2008 7:00 am
Verdict on Front Tire...Sounds like BS to me... petevandyke K1200LT 35 Aug 14th, 2007 9:25 pm
