K1200LT and Aluma trailer wiring - BMW Luxury Touring Community
post #1 of 6 Old Aug 31st, 2011, 4:33 pm Thread Starter
Munmi's Avatar
Earlier this summer, I purchased an Aluma trailer model MCT. Nice trailer so far, but very limited in how much we could use it. Shortly after purchase we had an electrical short of some kind a burned up the wiring harness of our 2002 K1200LT. The bike was totalled by the insurance company and we have since purchased another bike. I have spent the last couple of days studying my burned bike, my new bike, online images of wiring and forums. I now hope I have the trailer wiring complete on the bike. It has been very nerve racking dealing with it. Although it has not been determined why the first bike burned out, it is quite unsettling moving along to wire up again as it may have been something in my error or just a goofy coincidence. I just don't know.
Concerning the trailer wiring, I am confused. The trailer's harness is a six wire with the white cut short and not used. If you look at this...
http://www.alumaklm.com/images/stori...mctharness.pdf
you can see the cause for confusion. Notice the color lineup...red, green, yellow, brown, white....and then the plug diagram on the left shows black as ground. The schematic shows white going to ground on the trailer.
What is right?
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #2 of 6 Old Aug 31st, 2011, 5:43 pm
Axle's Avatar
Re: K1200LT and Aluma trailer wiring
unless your trailer ground wire is going straight to batt 12V terminal on the bike there is not really any way the trailer could cause a fire, the fuse in the circuit would blow first, just wire the bike up and use a 12v test light to confirm that the plug is correct on the bike before you plug into the trailer
white or black is usually earth dont know why it is showing both, doesnt matter just make sure you confirm your connections and you will be good to go
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 6 Old Aug 31st, 2011, 8:33 pm
SilverBuffalo's Avatar
Yeah right, what could possibly go wrong?
oh...wait you already know the answer to that question.
What you need is called an isolator relay set,
it is a set of four relays that you can buy from either Dauntless or Bushtec for around sixty bucks,
It will "isolate" the trailer wiring from the LT wiring (cheap insurance)
Most common trailers use a four wire system,
lights, brake, left, right and of course a ground,
they use the brake light filament for the turn signal.
You cannot do that with the LT, it has a separate brake light circuit (five wires)
what you need is a separate brake light on your trailer.
The cut wire inside your trailer was probably intended to be used for an interior cargo light,
since it is already there you can use it to power the brake lights that you'll need to add to your trailer,
I repeat you cannot wire the brake light into the turn signal filaments,
the 4 into five converters that you buy at Wallmart won't work.
Name:	wiring (Medium).jpg
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #4 of 6 Old Sep 1st, 2011, 12:47 pm Thread Starter
Munmi's Avatar
This trailer is using 5 of the 6 wires and has a nice brake light already installed. All LED lights. I have opened the connector on the trailer harness to confirm each wire corresponds with the bike end. When I tested with plugging into the bike, the lights all worked....but they did on the last bike too. Is it possible that the black wire is used as a ground like the LT brown ground works.....linking ground to all components, frame as some vehicles are?
I also contacted DMC (Dauntless) the isolator relay is $100. Cha-Ching!
Scott and Theresa
Munising, MI
2004 K1200LT Black
Munmi is offline
post #5 of 6 Old Sep 1st, 2011, 8:32 pm
The BMW wiring harness is over $1500 ChaChingers, installation just a "few" dollars more,
your call.
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #6 of 6 Old Sep 2nd, 2011, 5:53 am Thread Starter
Munmi's Avatar
your call.
LOL Yea, the dealer here estimated $4000 to get started fixing the bike....about $2000 each for the harness and labor. Plus whatever else may be damaged....hence the insurance company totaling the bike.
Scott and Theresa
Munising, MI
2004 K1200LT Black
Munmi is offline
K1200LT & Hannigan SideCar Tourdog Trailers, Sidecars, & Trikes 16 Dec 12th, 2006 7:27 pm
