Bushtec Trailer lights not working - BMW Luxury Touring Community
post #1 of 7 Old Oct 8th, 2010, 9:17 pm Thread Starter
Hello,
My wife and I are in the middle of a cross country trip on a new bike. We flew to Cali and bought the bike and are riding it home to Georgia.
The lights on the trailer worked perfectly yesterday and sometime today I noticed that that none of the lights on the trailer are working. I checked the 30A fuse under the drivers seat that leads to the trailer and it was still in good shape. I also looked around for a pinched/frayed wire and didn't see anything.
We're supposed to be back in ATL by Tuesday morning for work but if we can't ride at night it's going to be pushing it.
Do any of y'all have any ideas or things to check?
Thanks!
Cliff
cliff0529 is offline
post #2 of 7 Old Oct 8th, 2010, 9:39 pm
Re: Bushtec Trailer lights not working
Normally the fuse that feeds the isolator is the culprit. I would go ahead and replace it any way even if it looks good or at least jumper it to eliminate that as a problem. Then check the black wire coming from the isloator - it should go to the battery (-) terminal not a frame ground. I have had one of the internal relays go bad on mine so I replaced the isolator but that only affected one circuit not all the lights.
The red wire/fuse to (+) and black wire to battery (-) will kill all the lights if they are not hooked up.
post #3 of 7 Old Oct 8th, 2010, 10:04 pm
Gold Supporter
Originally Posted by cliff0529
Hello,
Thanks!
Cliff
A quick way to test the wiring is to stop at a auto parts house and get a 12volt circuit tester. Hook the clip to ground and probe the fuse block & make sure you have voltage going to, then thru the fuse. Then you can check each wire output at the trailer plug on the bike side. You should have one wire hot any time the key is on- a second that is hot with the brake on & two that are hot intermittantly with the turn signals. If you have power at the fuse but no power at the plug then the adapter is defective. You should be able to get one at a U-Haul outlet & they could probably even wire it in for you if you are not proficient with wiring. If nothing else they would probably even test your existing one if you need them to.
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #4 of 7 Old Oct 9th, 2010, 4:34 pm
Good points except for the last one. Bushtec trailers use separate lights for turn and stop so a standard U-Haul won't work. The trailer connector is a six pin flat. I did use one from U-Haul for my old trailer fed by my Bushtec Isolator before I got a Bushtec trailer.
post #5 of 7 Old Oct 9th, 2010, 5:24 pm
Gold Supporter
The uhaul place here has both types of isolators Four wire & Five wire so I thought they all would have both types.
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #6 of 7 Old Oct 9th, 2010, 8:32 pm
U-Haul does not have isolators only couplers. The Bushtec system puts no load on the bike's lighting system and supplies all the power to the trailer lights from a separate battery feed.
post #7 of 7 Old Oct 14th, 2010, 3:53 pm Thread Starter
It was in fact the isolator shorting out, thanks for all your help. I made it to ABQ the next day and met my father for lunch. He brought some tools and we got her fixed in the parking lot.
The next morning my FD went out about 120 miles out of Amarillo though. What an adventure! Finally got home last night. Thanks to the CMA chapter in Weatherford, OK and the dealership in OKC. Now we're turning around and heading back to Arkansas on it tomorrow!
Brake lights quit working TVPearson K1200LT 2 Jul 23rd, 2010 7:57 am
Bushtec trailer owners I need some help SilverBuffalo Bike Talk 10 Jun 11th, 2010 12:17 pm
Took delivery of my Bushtec yesterday. BruceHarrisJr Trailers, Sidecars, & Trikes 10 Jul 24th, 2008 10:27 am
Hella FF50 Driving Lights installed unleashd Lighting 22 Aug 21st, 2006 2:11 pm
