Air Ride Suspension - BMW Luxury Touring Community
post #1 of 14 Old Jan 22nd, 2010, 4:51 pm Thread Starter
gwpdx's Avatar
Air Ride Suspension
I have an 05 Bushtec Quantum GL that I will now be towing behind my "LT". I saw at one time someone had come up with a portable compressor you can install to adjust your suspension. I have been thinking about purchasing one but can't seem to find it anywhere.
Does anyone have one? If so, how do you like it. And can someone point to to a link to look at it.
Gary
garyw
BMW MOA #156791
"09" K1200 LT
"03" GL1800
gwpdx is offline
post #2 of 14 Old Jan 22nd, 2010, 5:57 pm
shoswell's Avatar
Re: Air Ride Suspension
http://www.bmwlt.com/forums/showthread.php?t=52112
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #3 of 14 Old Jan 22nd, 2010, 8:06 pm Thread Starter
gwpdx's Avatar
I saw that the other day while browsing but that is not what I have seen for the bushtec. Specifically designed for the ride suspension. Thanks for the link though
Gary
garyw
BMW MOA #156791
"09" K1200 LT
"03" GL1800
gwpdx is offline
post #4 of 14 Old Jan 22nd, 2010, 8:13 pm Thread Starter
gwpdx's Avatar
I did some more searching and found it. Made by Electrical Connections. Here is the link
http://www.electricalconnection.com/...ents/08011.htm
Gary
garyw
BMW MOA #156791
"09" K1200 LT
"03" GL1800
gwpdx is offline
post #5 of 14 Old Jan 23rd, 2010, 10:37 am
RonKMiller's Avatar
Wow, $300.00 just to adjust your trailer suspension "on the fly" ?
The ultimate farkle!
"Like Butt-ahh!"
RonKMiller is offline
post #6 of 14 Old Feb 3rd, 2010, 8:54 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Hell It's worth every penny to me. It,s a PITA to keep adjusting the air as your load changes.
That's the only complaint I have ever had with Bushtec. Just think fling 80 down the Hiway & you see you need to adjust your air. Push the button & your done. KEWL.
It WILL be my next Farkle
Stevie Shreeve
katnapinn is offline
post #7 of 14 Old Feb 24th, 2010, 3:12 pm
katnapinn's Avatar
Gary
I just order this Air Compressor system so I'll post my findings on install , fit & finish. also over all thoughts. I did find out that the owner of this company is the son of the owner of Bushtec.
Stevie Shreeve
post #8 of 14 Old Feb 26th, 2010, 3:33 pm
If you close the lid before you drive down the road the load won't change... (and I won't have to dodge your skivies in the twisties)
post #9 of 14 Old Feb 26th, 2010, 5:35 pm
Miles of Smiles
Hilton's Avatar
Smile Re: Air Ride Suspension
Done a load of miles with our Quantum. Measure to check the tongue weight, syringe pump from Bushtec prior to hooking up to adjust the camber. You need to roll the trailer back and forth to get this right. Never needed to adjust after this first daily check, however I do see that the lid is shut properly. 2nd click !
Cheers
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #10 of 14 Old Feb 27th, 2010, 7:09 am
katnapinn's Avatar
Cheers
My problem (among many ) is when I am not working (truck & trailer goes with employee) my only transportation is the bike. If I need to go to the store I hook up the trailer when it's empty then add weight at the store. Now I either have to GUESS how much air to put in & ride around the parking lot to check then stop to adjust air if needed or unhook trailer & roll back & forth while airing up the shocks.
With this NEW set up it will be faster to get on the road.
BTW John them aint my Skivvies flyin outa my rig ..... Commando all the way.
Stevie Shreeve
post #11 of 14 Old Mar 1st, 2010, 8:11 pm
Miles of Smiles
Hilton's Avatar
Of course ! Shopping trailer. That makes much more sense.
See the need now for variable pressures of a daily nature.
On tour, our load remains fairly static and hence the initial setting remains OK.
Requires about 70 - 75 psi to achieve the correct tire camber as we are around
max load. Would depend on shocks and "stiction " though.
Sorry dude.
Trailer safe and happy shopping.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #12 of 14 Old Mar 2nd, 2010, 11:34 am Thread Starter
gwpdx's Avatar
Steve,
I would be interested in hearing from you regarding how you like it. I have not ordered yet but may be soon as I have a couple of good rode trips planned this summer.
Gary
garyw
BMW MOA #156791
"09" K1200 LT
"03" GL1800
gwpdx is offline
post #13 of 14 Old Mar 2nd, 2010, 1:25 pm
katnapinn's Avatar
Steve,
Gary
Gary it came in yesterday & I installed last night & this morning.
First impressions ...... VERY nice design, looks well made & compact.
Instructions are NOT VERY GOOD I contacted Bushtec & they told me the best way to wire it to their trailer
It came with wiring I DID NOT need.
The remote has 4 buttons but you only use 2 of them.
Instruction say button 1 to air up & button 3 to dump air. My remote was #2 to air up & 3 to dump air. Not a big deal I just started pushing buttons till it worked.
Very EASY to install , On the Bushtec you use the interior light wire (black) for power. If you have the interior light (I do not) just move power for light to running light.
Ground the unit to the trailer ground wire (white).
On the bike (With Bushtec isolator) you cut black wire at the isolator and run it to your power source WITH the 7.5 amp inline fuse in the kit.
Hook up trailer , plug in wires to bike , turn bike on & push a button.
It really is that easy. It takes 5 or 6 seconds to fully air up shocks & about the same time to dump the air. Now this is with the trailer empty. I will NOT be able to ROAD TEST it till Sunday.
Stevie Shreeve
post #14 of 14 Old Mar 14th, 2010, 6:59 pm
katnapinn's Avatar
Well finally we had a DRY Sunday so I got Lola & Mae out for a little 100+ mile ride. The New onboard compressor on the trailer worked flawlessly. I put about 75 lbs in the center section of the trailer and hit the twisties. It's pretty cool to just hit 1 button & adjust the suspension going down the road. On the way home I stopped by Home Depot & picked up another 90 + lbs of mulch, loaded it up & off I went. Pushed 1 button & 2 seconds later the trailer was level again.
If you use your trailer as a "SHOPPING" trailer as Hilton called it you have to get this upgrade.
Stevie Shreeve
My Longest Day! TallPaul Ride Tales 7 Apr 17th, 2009 12:41 pm
Multiple Sclerosis Ride 2009 -- April 19, 2009 Westchester Co., NY UnderRider Rides, Rallies and Get-togethers 0 Feb 3rd, 2009 8:35 pm
Suspension Clinic - Garage Party Ted Shred Northern California 6 Jan 17th, 2008 1:13 pm
Snowy Ride & Aussie LT Riders Meet & Greet Nov 10th 2007 barryst1100 Australia, New Zealand, and AsiaPac 39 Oct 1st, 2007 6:03 am
Event Calendar from the BMWDFW Club eljeffe South Central 0 Jul 7th, 2007 8:33 am
