pictures of Lt wired for a trailer!!! - BMW Luxury Touring Community
post #1 of 15 Old Apr 4th, 2009, 8:55 pm Thread Starter
bowdon's Avatar
Question pictures of Lt wired for a trailer!!!
Hi all;
I am in the process of wiring the LT for a trailer. I have the 5 to 4 connector ( hoppy) a bosch relay ( PBT-GF30-12V)( which has a red wire with a fuse going to the + battery side, another red wire going to the ( LT yellow/grey) and the white wire from the relay to ground (brown) somewhere on one of the lights.
Some guys are talking about one relay, others are talking about 4 relays.
I have installed ( velcro) the relay in the rear light area ( in an open space ) on the left side ( LT light harness ( rubber grommet) is on the right).
I will be trying to see if the 5 to 4 connector will fit in the same area, or I will place it under the seat, and just run the wires to the lights, and the hitch plug ( which is a 4 wire plug for the trailer plug).
I am getting worried that the harness is not protected enough( after reading the emails!!!!)
Anyone have a few pictures of how they did this?? All the parts came with a Dauntless Hitch.
I can take some pictures if need be ( not much done so far!!
Regards,
Bowdon
bowdon is offline
post #2 of 15 Old Apr 4th, 2009, 10:05 pm
Re: pictures of Lt wired for a trailer!!!
Originally Posted by bowdon
Hi all;
Regards,
Bowdon
do a search on "5 wire trailer wiring" and also start here:
http://www.bmwlt.com/forums/showthread.php?t=21731
for some suggestions. Good luck.and enjoy!
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #3 of 15 Old Apr 5th, 2009, 8:15 am Thread Starter
bowdon's Avatar
Question Re: pictures of Lt wired for a trailer!!!
SmolinJoe; I have the wiring diagram from Dauntless ( does not show much, just tells yo how to do the hook-up to the lights). I have the harness which has a red and white wire from the relay, other red wire from the relay goes to the + side of the battery ( has fuse) inline. The other wires hook from the hoppy converter yellow, green and brown from the lights (rear) to the trailer plug ( 4 plug).
I will try to hook this up this afternoon to see if it works on the old trailer.
Pictures are always better for me!!! ( I am VISUAL!!, my wife says!!!)
Regards,
Bowdon
bowdon is offline
post #4 of 15 Old Apr 5th, 2009, 9:04 am
SilverBuffalo's Avatar
I thought we had you all "wired up" a couple of days ago.
Please go back and read the thread under the link that Joe provided you.
Maybe read it again.
What you're trying to do will not work!
Read my post! in that same thread.
I can't explain it any better than that.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #5 of 15 Old Apr 5th, 2009, 9:40 am Thread Starter
bowdon's Avatar
Silverbuffalo;
I had the left turn signal working, and the lights were on the trailer. But nothing else. I found that the 5 to 4 converter was defective so I purchased another one.
Here is what I thought I could do:
1) the relay has two red wires and a white wire coming out of it. One red wire ( with the inline fuse)goes to the + size of the battery. The other red wire goes to the yellow/grey ( left turn signal) on the light( which is also connected to the hoppy 5 wire side) The white wire from the relay goes to ground ( brown) wire on one of the light sockets( which is also connected to the hoppy 5 wire side) the yellow from the hoppy 5 wire side, is connected to the blue/red connector on the light socket( not run through the relay). The brown wire from the hoppy goes to the blue/grey wire on the light socket, and the green wire from the hoppy goes to the blue wire on the light socket for the right turn.
Only two wires ( red and white) are run through the relay.
Should I run the hoppy 5 wire side through the relay, then out to the lights?? Then the 4 wire side to the plug for the hitch?? The hitch plug is a standard 4 wire plug.
This is why I wanted to see pictures of the wires hooked up. Pictures are always easier for me!!!
I had pictures of the wiring harness I received from the guy I received the harness from in a previous post.
I wired my old K 1100 LT direct without a problem ( no relay in the middle) but I seem to have a hard time understanding this wiring procedure on the 1200 LT!!!!!
Thanks for trying!!!
Bowdon
bowdon is offline
post #6 of 15 Old Apr 5th, 2009, 10:01 am
Silverbuffalo;
How is the weather in Canada?
Bowdon
How is the weather in Canada???
Smokin'
post #7 of 15 Old Apr 5th, 2009, 4:01 pm Thread Starter
bowdon's Avatar
I am going to order the Dauntless 4 isolator relay with the wiring harness this week. I don't like the single relay set up.
I guess I should also change the hoppy 5 to 4 connector to a 5 to 5 connector??
Hopefully after this I should be able to hook up the wiring from the bike to the hitch.
The 4 wire HF trailer might be a problem!! ( I guess I might have to add another wire for the seperate brake lights I will also be installing!!!!
Regards,
Bowdon
bowdon is offline
post #8 of 15 Old Apr 5th, 2009, 6:38 pm
Ok it seems like the light bulb in your brain is starting to get brighter.
I think it is a very good idea to order the Dauntless isolator relay because the LT has some very sophisticated electronics that could cost you megabucks if something went wrong.
Once you add some separate brake lights and a 5 t0 5 plug to your trailer your life will become much simpler.
I don't think you had a defective 5 to 4 Hoppy unit,
if you wired it the way I think you did you fried it,
I can say that because I bought and fried two of them
before I figured out that it wasn't going to work.
Also the reason it did work on your K1100 is because it doesn't have the same separate brake light circuit like the LT.
Is it all starting to make sense now?
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #9 of 15 Old Apr 5th, 2009, 9:31 pm Thread Starter
bowdon's Avatar
Exclamation Re: pictures of Lt wired for a trailer!!!
Silverbuffalo;
I read a lot of threads today about wiring the LT!!! It started to make sense.
I know that I need to install to relays ( wired to the lights) relays to the connector ( 5 to 5 ) and add the additional wire ( making it 5) to the hitch plug and on the HF trailer with 2 other lights for the brakes?? RIGHT??
Then I have to put another set wire on the existing tent trailer because it is a 4 wire connector and I won't be able to pull this trailer with the LT?? RIGHT??
Its a little more wiring but hopefully things will work out in the end!!!
During the wiring part of the LT and HF trailer, I will take pictures and maybe do a step by step because I have seen a LOT of threads from others who are going through the same headaches with wiring trailers for the LT!! and have not seen any pictures or step by step drawing of how to do it right the first time!!! The Dauntless instructions don't show ant type of detail in wiring the LT for the hitch, and I have yet to see a step by step with pictures!!!
This would be extremely helpful to me and others that are trying to wire thing up!!!
Regards,
Bowdon
bowdon is offline
post #10 of 15 Old Apr 6th, 2009, 7:47 am Thread Starter
bowdon's Avatar
SilverBuffalo;
I was wondering if I ready need the 5 to 5 connector. I could just run 5 wires from the relays to the plug for the hitch.? Right?
It eliminated the additional cost of this connector (because I have enough wire to do the job.
Just asking.
Regards,
Bowdon
bowdon is offline
post #11 of 15 Old Apr 19th, 2009, 2:45 pm
CaptainTom's Avatar
Cool Wiring an LT for a Uni-go trailer
I've been reading the threads but does anyone have clear instructions and photos for installing the isolation relay on a K1200LT? My friend received the trailer and relay from Uni-go but we're not electricians and they only provided a basic wiring diagram.
Captain Tom
2002 K1200 LTE
Email:
CaptainTom is offline
post #12 of 15 Old Apr 19th, 2009, 8:28 pm Thread Starter
bowdon's Avatar
Re: Wiring an LT for a Uni-go trailer
Here is what I found for the Unigo trailer, I will have a wiring diagram for a dauntless next week when my isolator kit gets here, post when I get it.
Regards,
Bowdon
File Type: pdf Unigo%20K1200lt%20Wiring%20Diagram-2.pdf (75.1 KB, 95 views)
bowdon is offline
post #13 of 15 Old May 1st, 2009, 5:31 pm Thread Starter
bowdon's Avatar
Hi all;
I finished the wiring of the bike and trailer (finally!!!!) Here is what I did which made the most sense for me:
I wired the bike (2005 LT) with the Dauntless 4 relay isolators ( located on the right behind the passenger seat). Red wire to the + side of the battery.
The bike is wired with 5 wires.
The trailer is wired for 4 wires (standard). This way I can also pull with my car or truck.
I made a separate cable that goes in-between. 5 wire plug from the Dauntless hitch on the LT. Then into a 5 to 4 connector and the 4 wire flat plug on the other end for the trailer. Tested and everything works well!!!!
Thanks to everyone on this site for their information ( some were a little more patient then others!!!) but it all worked out!!!
The paint ( black) worked OK but seems to scratch of easier. The gold is a better paint but only comes in a small selection of colors. Not fussed with the grey, but it will have to do for now!!!! ( I might just paint the whole thing black later on, but for now..............).
Maiden voyage on Sat to see how it pulls!!
Here are some pictures of the finished work!!
Regards,
Bowdon
ID:	22854   Click image for larger version
ID:	22855   Click image for larger version
ID:	22856   Click image for larger version
bowdon is offline
post #14 of 15 Old May 1st, 2009, 6:02 pm
Bighopper's Avatar
Very satisfying when you get it to work. I like your idea of doing a write up with pictures, it certainly has helped me do some of the electrical jobs on my 06 LT this winter.
Can you take the carrier off the trailer & put your QUAD on , now that would be a useful trailer out here in Alberta
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
Bighopper is offline
post #15 of 15 Old May 1st, 2009, 8:43 pm Thread Starter
bowdon's Avatar
You should purchase the LARGER trailer at HF for the Quad!!!! HF now makes a homemade cargo trailer ( just like the one I finished!!! for around $ 450.00 US, check the web site!!! Nice looking rig!!
The only problem I had/have is the 2.04" bearing buddies don't fit!!! They are loose and fall off. I packed the axle full of grease and just put the caps back on. Should not be a problem, but will be bring a grease gun along on any long trips!!!
Anyone need a set of bearings buddies, 2.04" and 1.98" CHEAP!!!!
Bowdon
bowdon is offline
No Brake light on trailer jaskjb Trailers, Sidecars, & Trikes 5 Sep 18th, 2008 11:09 pm
LT goes for a ride ... on a trailer. Colyn Bike Talk 19 Jun 22nd, 2008 1:42 am
Triked her out Mel Trailers, Sidecars, & Trikes 14 Jan 22nd, 2008 8:19 pm
