Tongue length? - BMW Luxury Touring Community
post #1 of 8 Old Apr 3rd, 2009, 12:17 am Thread Starter
joevano's Avatar
Tongue length?
I understand the tongue should be twice as long as the trailer width.
Does that mean the total length of the tongue, or, it's length from the front of the trailer bed forward?
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'11 DR650 Alaska Bike
'13 KTM 250XCW
joevano is offline
post #2 of 8 Old Apr 3rd, 2009, 6:22 am
MOPMan's Avatar
Re: Tongue length?
or length from the axel forward?
I just had an extension made for my trailer tongue and I also dropped the hitch by 5". What a wonderful difference!
When you're comfortable...Riding Is Wonderful
Joyfully, MOPMan (Jim Mick)
MOPMan is offline
post #3 of 8 Old Apr 3rd, 2009, 7:33 am Thread Starter
joevano's Avatar
Re: Tongue length?
Hi Jim, how are you doing?
You left in the question mark, I assume that is your answer, axle to hitch needs to be double the width!
Joe Van Orsdol
Zimmerman Mn
'02 K1200LT
'94 K75S for sale
'13 KTM 250XCW
joevano is offline
post #4 of 8 Old Apr 3rd, 2009, 7:38 am
MOPMan's Avatar
Re: Tongue length?
Actually, mine was a question. I am no trailering expert.
MOPMan is offline
post #5 of 8 Old Apr 3rd, 2009, 12:09 pm
kellenbenz's Avatar
Re: Tongue length?
I have always used the formula of 60% of the weight in front of the axle and 40% aft of it. This normally leave you with about 10% of the total weight being tongue weight.
HTH,
Ron
IBA 45658 MOA167437
Total BMW miles 497,451
Goldwing miles 238,383
kellenbenz is offline
post #6 of 8 Old Feb 8th, 2014, 4:13 am
Re: Tongue length?
Hi I'm building a monowheel trailer and have got to the stage where I need to cut off the the excess length to the draw bar (I think you call it a tongue) the length of the trailer from wheel centre to front of body is 36" and the width is 24 " any suggestions before I cut? I was thinking 18" from the body to the u/j. What do think, I'm a little confused with the responses I've read.👍
Cheers Bren
Airportech is offline
post #7 of 8 Old Feb 8th, 2014, 6:27 am
MOPMan's Avatar
Re: Tongue length?
Again, I'm no expert, but have had several trailers that I have pulled behind cars and various motorcycles. I pull 3 of my 5 current trailers behind bikes.
I will always go with a longer tongue than any 'formula' recommends.
I have had small trailers over the years that were built by professionals which would run true, w/o issues, when behind a 4 wheel vehicle regardless how they were loaded. Those same trailers, behind a motorcycle, COULD BE A PROBLEM. Get it loaded with a little more weight to the rear, or get in gusty winds, etc. and watch out!!
A trailer being pulled behind a motorcycle is a different story than when pulled behind a 4 wheel vehicle. A bike has less weight and stability. Consider the movement of your bike hitch when passing a big truck (for example). The wind will likely make you lean a bit left and right as you hit the air turbulence from the truck. What does that lean, back and forth, do to your hitch? Can you understand that your hitch will also move back and forth? The higher the hitch is from the pavement, the more the movement!! The potential danger is that movement begins a trailer wag that might only get worse. Add additional length to the tongue and the problem is gone - just a bad memory.
I don't mind having an extra long tongue... If nothing more than it makes it easier to get into my trunk or walk behind the bike...
Many years ago, I was told that the ideal place to attach a trailer to a bike is where the rear tire touches the pavement... The higher and farther back from that 'tire patch', the more your hitch will move with leans. In addition, the higher the hitch is, the more chance there is that the momentum of the trailer will push up on the rear of your bike in a quick stop, rather than down (to add traction to your rear tire).
MOPMan is offline
post #8 of 8 Old Feb 10th, 2014, 4:32 pm
Re: Tongue length?
Hi Jim/Mick thanks for your feedback and advise, it's a suck-it-and-see situation I suppose cheers Bren
GSA Shock length tmgs GS Series 2 Jan 14th, 2008 6:04 am
Ideal length of 9/16 hex stock is? yechave K1200LT 11 Dec 14th, 2007 1:30 pm
Length tall screen ®win K1200/1300GT (The Next Generation) 2 Aug 9th, 2006 5:49 pm
Trivet Cell Phone Tongue as Garmin Foretrex 101 Mount MattKas GPS 0 Aug 1st, 2006 4:07 pm
