No Brake light on trailer - BMW Luxury Touring Community
post #1 of 6 Old Sep 13th, 2008, 8:25 pm Thread Starter
jaskjb's Avatar
I now have a Unigo trailer. I have been working on the wiring all day. I am using the Isolation relay from Mark at Unigo. I have left and right turn signals and Tail light working When the brake wire (blue) is not hooked up, I still have both the filaments in the trailer bulb light up. The lights on the LT work. No brake lights as the wire isn't hooked up
The unigo wiring doc says that the Gray/Blue wire from the lights goes to the blue relay wire. When this is done I still don't get a brake light on the trailer, only on the LT.
The Gray/yellow wire on the LT reads 12 volts with the volt meter when brakes are applied. When I hook up the blue wire to this one, the brake lights on the LT don't come one. Nor do the trailers.
The wiring on the trailer looks correct.
Do I have a bad relay.
I could go with only tail lights on the trailer, since the LT's lights are higher than the top of the trailer. Using only the LT's brake lights and not the trailers.??
Any suggestions. I was planning on using the trailer tomorrow. So I don't have alot of hours to play with this.
Jim G - Rochester, MN
BMW MOA #123976
2000 K1200LTC
jaskjb is offline
post #2 of 6 Old Sep 13th, 2008, 10:30 pm
Gold Supporter
Re: No Brake light on trailer
Use a battery charger or go straight to the battery to verify that the lights are working without the bikes electrical involved. If they do the trace the wiring back from there. if they do not then the relay is probably bad.
Jim
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #3 of 6 Old Sep 14th, 2008, 4:33 pm
SilverBuffalo's Avatar
I don't know anything about Unigo's or their relay but.....
there's a common problem that I and many others have had to deal with regarding trailer wiring.
most trailers have a 4 wire harness (left, right, tail, brake and a ground)
that's because they use both turn signal bulb filaments for the brake light.
The LT has a seperate brake light circuit
you cannot connect this to both turn signals,
if this is what your problem is you'll have to either add an extra light for the brake light on the trailer or a pair of lights for the turnsignals
hope this makes sense and helps you.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #4 of 6 Old Sep 14th, 2008, 4:57 pm
RonKMiller's Avatar
http://www.etrailer.com/tv-t-one-wir...shoot-faq.aspx
"Like Butt-ahh!"
RonKMiller is offline
post #5 of 6 Old Sep 14th, 2008, 5:33 pm Thread Starter
jaskjb's Avatar
So, here is what I have so far.
Tail light, and turn signals all work.
The blue wire from the Isolation relay has power even when it is not connected to the bike. That would explain why both filaments light up.
To me that would indicate that the relay is bad.
I am going to contact the distributor of the relay tomorrow and see what they say.
BMW MOA #123976
2000 K1200LTC
jaskjb is offline
post #6 of 6 Old Sep 18th, 2008, 11:09 pm
Super Moderator
dfinazzo's Avatar
Jim,
Here is a wiring diagram I made for Unigo last summer - I thought Mark was sending out since the instructions they gave me were lacking.
I have used this to help others and maybe this will help you out . . .
http://www.bmwlt.com/files/albums/us...0Diagram-2.pdf
Dan Finazzo
dfinazzo is offline
ABS brake failure warning light shunte3 K1200LT 19 Jul 9th, 2011 6:51 pm
Brake light Problems BillE K1200LT 5 Aug 24th, 2009 8:07 am
'96 R1100r BRAKE LIGHT STAYS ON! HASKINS Other R-Bike Discussion 4 Jul 3rd, 2008 10:14 am
Brake Light Mystery GeneralMilliron Other K-Bikes Discussion 3 Aug 23rd, 2007 4:57 pm
Brake Light Switch jeffklt K1200LT 7 Nov 15th, 2005 2:24 pm
