Trike Maintenance - BMW Luxury Touring Community
post #1 of 1 Old Aug 23rd, 2008, 3:40 pm Thread Starter
STARFIGHTER's Avatar
Trike Maintenance
We need maintenance info related to trike conversions.
I'll start.
On the Hannnigan trike, changing the rear (side not middle) tail/stop light.
crawl under the rear
you'll see three 8mm nuts holding the lens assembly in. They're in a triangle pattern. One on top and two below X
X X
Remove the top nut and washer and the plate can be removed.
Remove the bottom two nuts and washers
The lens is removed being behind the bike and facing the rear of the bike, rotate the lens from the lower inside corner toward the upper outside corner.
The lamp holders twist cc to remove.
The lamp for tail/stop is a blazer 7443 available at Autozone
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
Thinking about a Trike....... twinrider Trailers, Sidecars, & Trikes 17 Apr 20th, 2009 11:17 am
Trike Hire Waz K1200LT 5 Dec 13th, 2007 4:57 pm
Yearly RT Maintenance Cost Xavier6162 RT Series 12 Nov 18th, 2007 8:44 pm
Hannigan Trike Maintenance STARFIGHTER Trailers, Sidecars, & Trikes 5 Jul 26th, 2007 11:28 am
