Hannigan K1200LT Aux gas tank ? - BMW Luxury Touring Community
post #1 of 7 Old May 7th, 2008, 5:47 pm Thread Starter
Hi, question for K1200LT Hannigan trike owners. When transferring gas from aux tank to main tank do you need to have the machine off, using just the iginition on to transfer OR can you turn the switch on while riding down the road? I thank you in advance for your feedback.
ccwhoami is offline
post #2 of 7 Old May 8th, 2008, 8:13 am
STARFIGHTER's Avatar
Re: Hannigan K1200LT Aux gas tank ?
You can transfer fuel while traveling down the road.................
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
post #3 of 7 Old May 8th, 2008, 5:31 pm Thread Starter
Thank you, we are having an issue with ours not pumping, the dealer was telling us that we had to pull over, turn key on and pump on and it will take about 20-30 minutes to pump.....whew not what I want to do! Needless to say Hannigan is sending out a new unit!
ccwhoami is offline
post #4 of 7 Old May 9th, 2008, 12:27 am
GoldenDragon's Avatar
Starfighter is correct. Just wait until the low fuel light comes on then flip the switch to start transferring the gas from the Aux. tank to the main tank. Takes about 20 minutes but you should be able to do the transfer on the go.
Randi Kobernik
2005 K1200LT with a 2007 Hannigan Trike Kit "The Dragon"
It is not wise to meddle in the affairs of Dragons for thou art crunchy and good with katsup.
GoldenDragon is offline
post #5 of 7 Old May 14th, 2008, 7:58 am
Ditto. Don't know where the dealer got the idea that the trike had to be stationary to transfer fuel???
ben1364 is offline
post #6 of 7 Old Jul 12th, 2008, 10:08 pm
I agree with the other trike owners. I transfer fuel going down the road. Actually, is the only sensible way to do it! I wish there was a more visible indication that the pump was on, however. I have to scrunch over and look for the red light on the switch. Improvement needed!
Jerry
BMWMOA # 134919
2000 LT Hannigan Trike
1986 Suzuki TM400 (gone)
1957 BSA 500 cc Twin (long gone)
1955 BSA Golden Flash (longer gone)
1950 or thereabouts HD 165 cc 2 stroke! (gone in 1954)
scubajgp is offline
post #7 of 7 Old Jul 18th, 2008, 10:36 am
If perchance you were serious about the fuel transfer pump indicator light, you could install a bigger one and a buzzer or horn or both...
ben1364 is offline
Rear Tire for K1200lt with Hannigan Sidecar Hopalong1 Tires 2 Aug 24th, 2006 10:21 pm
Aux Tank Installed RMW K1200LT 13 Apr 22nd, 2006 3:29 pm
Aux tank Help RMW K1200LT 7 Apr 8th, 2006 9:56 am
