Hannigan Trike Lift - BMW Luxury Touring Community
post #1 of 8 Old Mar 5th, 2008, 10:30 am Thread Starter
GoldenDragon's Avatar
Hannigan Trike Lift
I finally took the plunge and bought a lift. I purchased the Atlas Hi-Rise 1500 Motorcycle/ATV Lift from Greg Smith Equipment. Will handle up to 1500 lbs and will raise it up to 43" high. With the extensions it is 51" wide and 88" long. However, Hannigan LT conversions are 47" inside to inside of the tire and about 57"-58" outside to outside of the tire. That didn't leave much of the tire on the lift so I modified the extensions to get the additional width I needed. I have attached a picture with the Golden Dragon on the lift.
Randi Kobernik
2005 K1200LT with a 2007 Hannigan Trike Kit "The Dragon"
It is not wise to meddle in the affairs of Dragons for thou art crunchy and good with katsup.
GoldenDragon is offline
post #2 of 8 Old Mar 5th, 2008, 2:20 pm
STARFIGHTER's Avatar
Re: Hannigan Trike Lift
Lookin' good buddy............
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
post #3 of 8 Old Mar 6th, 2008, 7:42 am
Richco's Avatar
Nice setup. Can you give a little more detail on the modification. Like dimentions, Materials, How installed. And some closer pictures.
Richard
2002 K1200LT Trike
1979 R65
1992 K75 Sidecar (Soon)
Richco is offline
post #4 of 8 Old Mar 6th, 2008, 10:15 pm Thread Starter
I'll see if I can get some pictures this weekend. Materials are 2" square iron tube(Rack extension) and 1.5 inch solid iron bar(Goes through the racks and frame)
Randi Kobernik
post #5 of 8 Old Mar 28th, 2008, 11:59 am Thread Starter
Sorry it took so long to get the pictures back to you on the details of the extensions. The outside perimeter of the extension is 1.5" by 2.5" steel with 1" by 2" cross pieces. the bar is 1 and 3/8 inch solid steel. I had to drill one hole where the 2" by 2" frame piece crosses on the underside of the lift table. That frame piece is directly over the pivot for the scissor assembly and does not hamper anything when raising or lowering the lift. I use the table extensions that came with the lift for ramps. I welded a U shaped steel piece on the end so they hook on the end of the extensions. I have attached pictures to show these modifications. The table with the extensions is now 63 inches wide.
Name:	Bottom of lift.jpg
ID:	17216   Click image for larger version
Name:	Extension with bar 1.jpg
ID:	17217   Click image for larger version
Name:	Extension with bar 2.jpg
ID:	17218   Click image for larger version
Name:	Extensions as ramps.jpg
Randi Kobernik
post #6 of 8 Old Mar 28th, 2008, 11:41 pm
ErnieA's Avatar
That's is very cool Randi. I might make an adapter for mine in case I get another visitor.
Ernie A
Milwaukie, OR
2013 R1200GSW
> 28k miles!
ErnieA is offline
post #7 of 8 Old Mar 29th, 2008, 12:36 am
AlaskaFish's Avatar
Talking Re: Hannigan Trike Lift
That garage looks so familiar! And that lift looks like some great re-engineering Randi! Now I know where to go if we need a lift in Bend!
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #8 of 8 Old Mar 29th, 2008, 6:04 pm Thread Starter
Thanks Erine & John. You are welcome here anytime. The Grand Tour looks pretty easy this year. Give me a ring and stop by anytime.
Randi Kobernik
Lift to fit a Hannigan Trike???? GoldenDragon Trailers, Sidecars, & Trikes 3 Dec 4th, 2007 2:43 pm
Hannigan Trike Maintenance STARFIGHTER Trailers, Sidecars, & Trikes 5 Jul 26th, 2007 11:28 am
Big Blue Bike Lift grahamw K1200LT 1 Jul 7th, 2007 9:01 pm
Coolant Level - Hannigan Trike PePa Trailers, Sidecars, & Trikes 3 Mar 29th, 2007 9:07 pm
Harbor Freight Motorcycle Lift Jerrym K1200LT 18 Oct 29th, 2006 5:14 pm
