Which wire for fridge power? - BMW Luxury Touring Community
post #1 of 6 Old Dec 6th, 2005, 2:46 am Thread Starter
big dog's Avatar
Question Which wire for fridge power?
G'day all
Have just wired up my trailer connection harness on the weekend with only one wire left to do. This will be the power wire for the little fridge / cooler that I intend to put on the fromt of the trailer. Which would be a good wire to splice into to power up the fridge? Would prefer something that will not be a continuous supply even with the key in the off position (don't want no flat battery ) and the power line into the trailer has a fuse block already installed.
Many thanks for you anticipated replies.
TIA
Regards
Big Dog
'04 K1200LT
Ulysses #33984
Cogito Ergo Sum: I think, therefore I am.
What am I?
big dog is offline
post #2 of 6 Old Dec 6th, 2005, 5:27 am
Daza's Avatar
Fridge Power
Big Dog,
It depends a lot on how much current it pulls. Is there a label on it that says xxx mA or x.x A where the x's are numbers?
The best way from my point of view is to pick up the power directly from the battery running it via a suitable fuse and then through a relay (either a horn or driving light relay, about $6 at Dick Smiths) that is triggered by the tail light wire. This way you can't leave the power on without the key on but you are not dragging to much current from another circuit. If you want to go down this path but arn't too sure about the wiring send me a PM.
That's my 2 bob's worth....
Daz
Never take life too seriously, nobody gets out alive anyway…..
Black (03) LT
Matching Uni-Go
Ulysses Member 30740
Growing Old Disgracefully.....
Daza is offline
post #3 of 6 Old Dec 6th, 2005, 11:03 am
I had one of the little thermoelectric coolers on the bike for my 10/10ths trip, just plugged it into the passenger aux. power socket. It is only on with the ignition turned on.
post #4 of 6 Old Dec 6th, 2005, 1:51 pm Thread Starter
big dog's Avatar
Daza & Dave
Thanks for the responses blokes. What about joining the wire to the power side of the plug socket next to the pillion? That way, (as I see it) I can still use the socket for SWMBO if needed without having to remove the fridge plug. Have been thinking about getting the BMW plug and converting the bride's phone charger so that we can charge her phone as we ride.......
Daza, the draw off is around 5 amps IIRC. Ran the fridge okay on the trip to Canberra for this years Ulysses AGM, not a problem at all. From memory, I think I spliced the power wire into the tailight wire on my V Star. Lights only came on when the iginition was switched on. Curse you ADR39!!!!
Thanks again peoples.
Regards
Big Dog
'04 K1200LT
Ulysses #33984
What am I?
big dog is offline
post #5 of 6 Old Dec 6th, 2005, 8:53 pm
Daza's Avatar
Fridge Power
Big Dog,
That'll work fine.... and that wiring is not too hard to get to.
Daz
Black (03) LT
Matching Uni-Go
Daza is offline
post #6 of 6 Old Dec 7th, 2005, 2:37 am Thread Starter
big dog's Avatar
Excellent, will see if I can spend some time on the weekend (what's that dear, mow the lawn? Maybe later..... ) and splice it in.
Thanks again all.
Regards
Big Dog
'04 K1200LT
Ulysses #33984
What am I?
big dog is offline
Problems with Hoon Hardware Power Supply LT05RT04 Satellite Radio 3 Nov 28th, 2005 3:45 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 8:36 pm
Bike power to the trailer for accessories Dezrae Australia, New Zealand, and AsiaPac 2 Oct 25th, 2005 4:43 am
Delayed Power to Headset and Detector Canabarry K1200LT 8 Oct 15th, 2005 9:20 pm
