Help on wiring of Bushtec? - BMW Luxury Touring Community
post #1 of 6 Old Jul 7th, 2007, 1:34 am Thread Starter
akzl's Avatar
I need help from someone that has installed a Bushtec hitch on an LT. The wiring instructions from Bushtec were clear except they state “connect the White/Green to the Gray/Black on the LT. The White/Blue to the Gray/Yellow on the LT. There is a
Gray/Yellow but not a Gray/Black. My question is the LT has a Gray/Blue, is that the one that should be connected to the White/Green on the harness? My guess is it’s a type O on Bushtecs part? The other thing is they say to grab the connections for the four wires at the plug in the tail light. Any guidance on a good way to connect and run to the isolator that will be mounted under the seat. I searched the forums and only found the Dauntless wiring and I’d like to put this mess back together in the morning rather than wait til Bushtecs opens on Monday. Thanks John email: [email protected]
02 BMW
LT
98 HD FLHT
97 Honda Valkerie
65 HD Chopper
01 Polaris Ranger
akzl is offline
post #2 of 6 Old Jul 7th, 2007, 10:55 am
SilverBuffalo's Avatar
go to this post:
http://www.bmwlt.com/forums/showpost...4&postcount=10
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #3 of 6 Old Jul 7th, 2007, 11:16 am Thread Starter
akzl's Avatar
Wiring
Hans
Found and printed your post the day I bought the hicth (thanks for the great link too) but it show as a Dauntless relay and didn't know if the colors are the same. The Bushtec is a primary white and with a color stripe. If the Dauntless green is the same as the White/Green on the Bushtec relay then the Gray/Blue is the wire I need intead of the "Gray/Black" stated on the Bushtec installmanual. Did you grab the wires to tap at the tail light and run them back up under the seat to the relay? Thanks again.
02 BMW
LT
98 HD FLHT
97 Honda Valkerie
65 HD Chopper
01 Polaris Ranger
akzl is offline
post #4 of 6 Old Jul 7th, 2007, 7:40 pm
Senior Member (ret.)
RaffyK's Avatar
RaffyK is offline
post #5 of 6 Old Jul 7th, 2007, 8:38 pm
I reread the post I sent you to this morning and it needs a little clarification,
the picture I referred to was the one Steve posted of his Bushtec plug,
the picture I attached is the paper I have on my bike
for the wiring harness with the Dauntless hitch/Bushtec trailer.
The following are the color codes from the Bushtec website.
13. WIRE HARNESS COLOR CODES
Following are the primary wiring harness functions identified by color.
GREEN: RUNNING & TAILLIGHTS
WHITE: CHASSIS OR BATTERY GROUND
BLUE: BRAKE LIGHTS
YELLOW: RIGHT TURN SIGNAL
BROWN: LEFT TURN SIGNAL
BLACK: INTERIOR LIGHT
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #6 of 6 Old Jul 16th, 2007, 12:32 am Thread Starter
akzl's Avatar
Bushtec Wiring
The deed is done, grabbed the wiring under the seat and tapped there, Hans thanks for the help!! Now we'll see how it tows behind the LT compared to the FLHT
02 BMW
LT
98 HD FLHT
97 Honda Valkerie
65 HD Chopper
01 Polaris Ranger
akzl is offline
Wiring diagrams for 2002 K1200LT Tat_n_Telle K1200LT 10 Feb 24th, 2014 9:20 am
Took delivery of my Bushtec yesterday. BruceHarrisJr Trailers, Sidecars, & Trikes 10 Jul 24th, 2008 11:27 am
Wiring Suggestions for Kisan Brake/Turn Signal Device Nebish Lighting 0 May 24th, 2007 1:16 pm
wiring harness festus K1200LT 5 Jul 16th, 2006 10:19 pm
