harness wiring for 2002 - BMW Luxury Touring Community
post #1 of 7 Old Jul 1st, 2007, 10:17 am Thread Starter
sheldan2's Avatar
Question harness wiring for 2002
Obviously I have done something wrong and need some help here, what I have done is a temporary fix, to make sure everything worked before I soldered all the wires permanantly. The left side, turn, parking and brake light work fine, but not the right side.
left turn = yellow wire from harness on blue/red on bike
left brake= red wire from harness on yellow/grey on bike
center brake=brown from harness on grey/black on bike
right brake= no splicing
right turn=green from harness on blue/black on bike
ID:	12898   Click image for larger version
ID:	12899   Click image for larger version
sheldan2 is offline
post #2 of 7 Old Jul 1st, 2007, 11:18 am
bowlesj's Avatar
OK, Mike, what you trying to do. Trailer lights, relay pack or something else?
And what is not working? The right tail light or right turn signal or both?
We can do the phone if you want - 828-390-7449.
2004 - LT - Anthracite
bowlesj is offline
post #3 of 7 Old Jul 1st, 2007, 11:27 am
bowlesj's Avatar
Looking at your harness colors - is that the unigo 7 conductor cable?
If so the brown is the interior light and nothing should be spliced to your center brake light. That will throw ABS faults also.
bowlesj is offline
post #4 of 7 Old Jul 1st, 2007, 1:53 pm Thread Starter
sheldan2's Avatar
John, I found the problem(s), one was the ground on he trailer, second was the tail light itself, 2nd one was bad as well, off to wally world to get a replacement. thanks for your help....
sheldan2 is offline
post #5 of 7 Old Jul 1st, 2007, 2:32 pm
bowlesj's Avatar
Good deal. I'm sure your bike side is fine. If the next light assembly you get is bad you may just want to solder this and crimp that to make it work better.
Then if you plug into the bike and still no worky - I'd be thinking bad Hopkins part.
Good luck and enjoy your new luggage space.
bowlesj is offline
post #6 of 7 Old Jul 1st, 2007, 4:23 pm
SilverBuffalo's Avatar
I don't know if this is the problem in your case here, but there is a common problem that comes up a lot when folks try to wire a trailer harness up to the LT.
"most" trailers use the left and right turn signals as the brake lights,
the LT has seperate left, right and brake light circuits,
in other words the brake circuit must be kept seperate from the turn signals.
Hope this helps.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #7 of 7 Old Jul 1st, 2007, 8:18 pm
bowlesj's Avatar
That's right Hans.
Mike had a isolator relay/converter unit assembly that is supposed to rectify all that. It seems he was still having trouble on the trailer. I think he got it sorted.
bowlesj is offline
radio wiring harness 2006 R12RT and a power question paulleventhaldds Satellite Radio 2 May 31st, 2007 6:27 am
K100LT Main Wiring Harness DaveP Other K-Bikes Discussion 7 Jan 4th, 2007 11:31 am
Help wiring a 6 CD Changer factory harness for 05 LT Krazydave iPod/MP3 7 Aug 1st, 2006 2:20 pm
wiring harness festus K1200LT 5 Jul 16th, 2006 9:19 pm
