dauntless hitch - BMW Luxury Touring Community
post #1 of 4 Old Mar 10th, 2007, 4:03 pm Thread Starter
lenny's Avatar
dauntless hitch
for those of you that have a dauntless hitch where did you put the relay ?? thanks
lenny is offline
post #2 of 4 Old Mar 10th, 2007, 4:42 pm
SilverBuffalo's Avatar
When I had the Dauntless hitches (I've had two and switched to a Bushtec hitch)
I put the relay either under the passenger seat or right next to it,
double stick taped to the top of the right saddlebag where all the wires are,
speaking of wires if you follow the "bundle" back you'll come to a rubber grommet that goes into the back side of the taillight a very convenient place to make all of your connections.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #3 of 4 Old Mar 11th, 2007, 7:39 pm
tsBMWminer's Avatar
relay
Lenny
I put my relay where the canister was taken out under the trunk.
I drilled a hole thru to the tail light for the wires .
Tim In Portland
2000 Lt Icon
"Ike"
tsBMWminer is offline
post #4 of 4 Old Mar 12th, 2007, 8:50 am
zaphod's Avatar
Like Lenny, I put mine where the canister was. Make sure you tie-wrap the wires from the hitch socket to the hitch frame on their way up to the hole you cut. Donít ask how I know, but if you donít do it right the wires can get chewed up scrapping on the rear wheel.
Malcolm McGee
Little Rock, AR
'00 K1200LTC Canyon Red
'09 Kawasaki KLR 650
'96 Bunkhouse
IBA #24557
BMWMOA #117769
zaphod is offline
Dauntless hitch rack tested pozo_izquierdo Trailers, Sidecars, & Trikes 15 Sep 20th, 2006 7:01 pm
