trailer wiring - BMW Luxury Touring Community
post #1 of 3 Old Mar 7th, 2007, 7:22 pm Thread Starter
lenny's Avatar
trailer wiring
trailers almost done...dauntless hitch arrived the other day,,why do i need a seperate hot red wire for the brakelights on the trailer,,,wont they work just tied into the wiring harness of the bike???.....help...thanks
lenny is offline
post #2 of 3 Old Mar 7th, 2007, 7:41 pm
jwd98056's Avatar
I believe the basic wiring harness from Dauntless has a single relay isolator. I upgraded to a four relay harness so all the trailer circuits pull power directly from the battery.
One issues when you wire the trailer lights directly to the bike lights is the extra current draw through the bike wiring may drop the voltage enough to dim both the trailer lights and the bike lights. A second issue is a short in a trailer circuit it will blow a fuse on the bike light circuits. A third but less likely issue is that some turn signal relays may not function correctly with extra lights on the circuit.
#32756 -
#122647
'12
FLTRU Ember Red Sunglo (
'05
R1200GS Desert Yellow (
'00
K1200LTC Canyon Red (
) - Retired 10/2012
'02
FLSTC Custom (
jwd98056 is offline
post #3 of 3 Old Mar 8th, 2007, 6:07 am Thread Starter
lenny's Avatar
do i cut off the 4 wire connector off the trailer and use the 5 wire adaptor dauntless sent?
lenny is offline
trailer wiring dave4462 K1200LT 5 Jan 22nd, 2007 12:08 pm
Trailer wiring???? gwhiz162000 K1200LT 5 Sep 16th, 2006 3:42 pm
Need some advice on trailer wiring SilverBuffalo Trailers, Sidecars, & Trikes 4 Oct 15th, 2005 6:36 pm
Help with wiring non-LT RaffyK Chit Chat 13 Oct 7th, 2005 10:04 pm
