trailor electrical connections - BMW Luxury Touring Community
post #1 of 4 Old Oct 9th, 2006, 8:39 pm Thread Starter
needed, good advice.
i am purchasing a trailor hitch for my 03 lt on ebay.
it does not come with electrical connections. when i had my venture i purchased elec. connec. from " EC".
assuming i can do the same thing, will making connections to the bike be a complicated process for a novice, or should i consider going to a dealer?
thanks for your help.
scrc- 361
deltarider is offline
post #2 of 4 Old Oct 9th, 2006, 9:02 pm
RonKMiller's Avatar
scrc- 361
Go here for advice:
http://forums.delphiforums.com/n/mai...towing%2Fstart
"Like Butt-ahh!"
RonKMiller is offline
post #3 of 4 Old Oct 9th, 2006, 10:35 pm
mneblett's Avatar
scrc- 361
The process is straightfoward, with a couple of footnotes. Brake, tail, L&R lights and ground are available at the single harness at behind the tail light housing, or if you can find it, under the right upper subframe rail. The one thing to be aware of, is that the '02-on bikes the ABS system monitors some of the brake bulb circuits. This, and the "you-never-know-whether-the-electronics-module-is-gonna-blow-up-from-a-voltage-spike" problem, are reasons I (and others) recommend installing a trailer isolator.
Mark Neblett
Fairfax, VA
mneblett is offline
post #4 of 4 Old Oct 9th, 2006, 11:54 pm
RSnyder's Avatar
You might want to take a look at this:
http://www.dauntlessmotors.com/hitch...Micro%20Relay1
Go to the bottom of the page for the Bosch Micro Relay.
I don't know if you have been towing trailers long or if you have seen this site before but here are some folks with lots of information about trailer towing.
Rusty Snyder
Last edited by RSnyder; Oct 10th, 2006 at 12:08 am. Reason: additional information
RSnyder is offline
'05 Battery connections McRuss K1200LT 10 Apr 2nd, 2006 10:28 am
Autocomm connections? dwsdad Intercom, CB, & 2-Way Radios 3 Mar 2nd, 2006 10:00 am
On board air compressor connections Marshpop K1200LT 1 Nov 13th, 2005 12:54 pm
