tow pac on the LT - BMW Luxury Touring Community
post #1 of 3 Old Aug 24th, 2014, 7:58 pm Thread Starter
Guest
2191's Avatar
tow pac on the LT
anyone using a TOW PAC ON THEIR LT.
like - dislikes
easy to install
thinking of adding it,
2191 is offline
post #2 of 3 Old Aug 25th, 2014, 10:56 pm
Munmi's Avatar
Re: tow pac on the LT
A friend of mine that rarely participates on this board has a tow-pac on his '06. He likes this system.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #3 of 3 Old Aug 26th, 2014, 1:00 am
rovero's Avatar
Put a tow pac on my 2002 LT about 2 months ago.
Install took me about 6 hours. If I had to do it again I think I could do it in 4hours.
Secret to install is to just mount all the hardware to the LT hand tight. This will allow you to get everything aligned.
Once the mount is secured to the LT the wheels slide into the trailer hitch and two lean too brackets fairly easy. After attaching wheels three bolts hold it in place.
Wheel alignment is next. Tow pac give instructions, but I found the best way to align the wheels is to use a string with a nut attached. Tape sting to top of tire and let hang. Move the tire until the string is flush with the top and bottom of the tire. Once flush tighten bolts that hold the wheels to the frame. Tow pac provides shims if needed to align the wheels.
Going for the first ride.
This scared the hell out of me. The bike will lean slightly in the opposite direction of a turn. The faster and sharper the turn the more the bike will lean. You also have to apply a good deal of force in the direction of the turn with the steering. You will want to put your feet down as you feel the bike leaning. You have to completely unlearn counter steering and steer the bike the same way you would steer a car without power steering.
After overcoming the fear factor and riding for the first couple of weeks I am now somewhat comfortable with the tow pac.
Pro’s
Great at slow speeds, parking lots, parking, and slippery roads.
Two up no fear of bike tipping over as passenger gets on or off.
Stopping on the side of the road no fear of uneven ground.
Stopping anywhere and not having to worry about getting your feet firmly on the ground.
Stopping fast.
Cons
Takes a bit of an effort steering through curves.
Ride is not as smooth as two wheels. Bike will wobble slightly from side to side on rough uneven road surface.
At this point in my learning curve I take all curves in the road at or below speed limit.
I like having a trike, but I think if I stick with it after a year or so I will bit the bullet and go to a complete conversion by Hannigan. The tow pac has no means on adding an anti sway bar. The hannigan does have anti sway which allows for flatter cornering and smoother more stable ride. The tow pac is okay if you ride at posted speed limits and are not aggressive in the corners.
rovero is offline
