2002 1200lt - BMW Luxury Touring Community
post #1 of 12 Old Dec 28th, 2012, 5:49 pm Thread Starter
2002 1200lt
I have just purchased a 2002 1200lt. I am looking for someone in Columbia SC or near by who would can work on my bike. I was told the bike had a final drive problem when I bought it however now the ABS light and a warning light are on. The front brakes are very touchy and their some noise when starting out in First gear.. Also how do you know which model you have? Elite, standard custom??All the paper work refers to it as 1200LT??
superdavemerriman is offline
post #2 of 12 Old Dec 28th, 2012, 6:50 pm
Re: 2002 1200lt
Lots of questions - most can be found with a little searching and from reading other posts. Lots of times the related posts at the bottom of the page will answer most of your queations.
As far as your level, if you have chrome around your mirrors - is is at least a custom. If you have an intercom & cb, you prob. have an elite.
Yes the brakes are touchy - they are power assisted. Heed the warnings to stop with the front wheel straight ahead, she is heavy and it is easy to lay down.
The ABS will flash until you reach a few mph. What is the other warning light?
You will have to give us more info. on "makes a noise" These bikes have a dry clutch which is a bit different than a wet clutch in that you don't "slip" it, use it like a car clutch - find the engagement point, rev and release the clutch.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #3 of 12 Old Dec 28th, 2012, 7:23 pm
Re: 2002 1200lt
One light is the general warning and the other is the ABS light. They should not be both on and solid. Usually they flash wig - wag style which just means the brake reservior under the pillion seat is a little low on fluid.
During normal start up they should flash very fast and after a few seconds (with the brakes not held) they shift to a slow flash. This means part one of the self test is done. The second part is the rolling test of the wheel sensors. They should both go out after rolling a few feet. If they continue to flash then that reservoir is low on fluid.
It has two chambers and they are separated from each other but either one will trigger a fault if slightly low. Just add fluid to both chambers.
ID:	37295   Click image for larger version
post #4 of 12 Old Dec 29th, 2012, 7:21 pm Thread Starter
Re: 2002 1200lt
where is the brake fluid reservoir located on a 2002 1200lt? I checked under the front seat and didn't see it? This is my first BMW. I have a 2008 Gold Wing however this is all new..
post #5 of 12 Old Dec 30th, 2012, 9:03 am
Re: 2002 1200lt
your nearest best dealer is touring sport in greenville. i have tech sessions at my place on occasion but it wll be a while as i am recovering from some injuries.
Jeff in Myrtle Beach
'01 LTC
'99 Icon champagne
'02 KLR 650
TZ 185 2 stroke
Honda R100R beater
jeffklt is offline
post #6 of 12 Old Dec 30th, 2012, 1:48 pm
Re: 2002 1200lt
Here is a better pic to locate the reservoir.
post #7 of 12 Old Dec 30th, 2012, 2:17 pm Thread Starter
Re: 2002 1200lt
Thanks looks like I need to at least remove the back seat if not the side panel.I only looked under the front seat yesterday...
post #8 of 12 Old Dec 30th, 2012, 2:18 pm Thread Starter
Re: 2002 1200lt
Please keep me on your list when you get better. I would like to learn about the 1200lt
post #9 of 12 Old Dec 30th, 2012, 2:34 pm
gbaltyn's Avatar
Re: 2002 1200lt
+1 on Touring Sport in Greenville. They also have a local club that has tech sessions on occasion. I'm located in Simpsonville if you need a hand. PM me if you want to exchange info.
Greg
gbaltyn is offline
post #10 of 12 Old Dec 30th, 2012, 4:09 pm
blueknightga6's Avatar
Re: 2002 1200lt
Yes, remove the rear seat too. If you've got heated seats there will also be wires attached but you can get it out of the way without disconnecting them. The removal of that one side panel can make things easier too. But to remove it, you'll also need to remove the mounting plate for the passenger footpeg too, but that's pretty easy. The rear portion of the reservoir is actually for the front brakes and the front portion is for the rear brake.
Chris Ehlbeck
blueknightga6 is offline
post #11 of 12 Old Dec 30th, 2012, 5:37 pm Thread Starter
Re: 2002 1200lt
thanks will give it a try..
post #12 of 12 Old Dec 31st, 2012, 6:38 pm Thread Starter
Re: 2002 1200lt
I registered the bike today and road it hard. I noticed that both the red flashing triangle warning light and the flashing ABS light would periodically come on and off. The final leg of my ride I hit hit the brakes pretty hard and it appears to have quit. I am wondering if something happened when I trailer it from Florida. Should I still check the fluid level under the rear seat if it happens again?
the previous owner believed the final drive was going bad. He recently added fresh fluid. What should I look for or what will I notice if the final drive needs replaced?
Replace 2002 Instrument Cluster with 2007? john_loucks K1200LT 8 Jan 30th, 2018 4:03 am
confused - 2720 for 2002 LTE kaswahn GPS 16 Apr 7th, 2009 7:15 am
New (to me) 2002 LTE - GPS question kaswahn GPS 8 Dec 25th, 2008 11:38 pm
1200LT vs Harley Street Glide reschwert K1200LT 69 Feb 19th, 2007 2:37 pm
2002 LT value aikido73 K1200LT 7 Jan 9th, 2006 7:22 pm
