Stripped out scew threads... - BMW Luxury Touring Community
post #1 of 6 Old Oct 2nd, 2008, 7:26 pm Thread Starter
kosmo's Avatar
Talking Stripped out scew threads...
I solved the abs problem and now have another...I was topping off the front brake resevoir and being careful tightening one screw opposite of each other, when I got this sickening feeling..the screw let go of it's housing tension. Damn !
I've got a trip planned with my two older brothers to Dealsgap this weekend and I need help.
kosmo is offline
post #2 of 6 Old Oct 2nd, 2008, 7:46 pm
Re: Stripped out scew threads...
How about very carefully drilling it and tapping it to the next size larger? just a though.
danbrown is offline
post #3 of 6 Old Oct 2nd, 2008, 7:57 pm Thread Starter
kosmo's Avatar
Talking Re: Stripped out scew threads...
Thats a step I thought of. I have a friend who is the service manager at a Honda dealership who has offered his help and I think I'll take him up on it, since I'm not only frustrated and a little shaken from this problem.
I can't believe how easy it was to strip this out in cast.
kosmo is offline
post #4 of 6 Old Oct 2nd, 2008, 8:08 pm
tbarstow's Avatar
A helicoil should fix you right up.
Tim Barstow
2004 GSA Silver
2007 X Challenge
tbarstow is offline
post #5 of 6 Old Oct 2nd, 2008, 8:59 pm
Ricky,
Next time just snug them up gentle - no high torque needed here.
No for a fix I have used in the past on light duty fasteners that have stripped out. J B Weld. Clean the hole really good (Alcohol etc) and use a tooth pick to apply a tiny amount of J B Weld to the hole edges, don't completely fill it. Then take the screw and dip it in some light machine oil and dab up the excess with some tissue. Slide the screw into the hole as far as you can push it and let it set over night.
Break the screw loose with a "loosening" movement and then apply light torque to secure the screw. I have even used this technique on the 8MM fuel tank bolt that is always a bi**h to get started in the right side of the frame.
post #6 of 6 Old Oct 5th, 2008, 1:06 pm Thread Starter
kosmo's Avatar
Thanks guys.
My older brother's son-in-law, opened his honda shop and helped me out early am friday morning. We just tapped one size larger and it was fixed.
kosmo is offline
Grrr....please help me with a stripped Allen head... Briantime K1200LT 10 Apr 8th, 2008 7:45 pm
all threads in Farkles? CarSalesman BMWLT Site Support Forum 0 Oct 10th, 2005 8:15 pm
