Ok you "let's find the short" gurus! - BMW Luxury Touring Community
post #1 of 21 Old Jan 1st, 2008, 9:13 am Thread Starter
pkpr1998's Avatar
I need to invite myself to a mini tech session. I have the low-beam HID and my light keeps going off and on (Don N. can tell ya' what my headlight light was doing). It has a short somewhere and is probably a simple and quick fix (I hope).
I also have the third brake light and while at Chateau Elan two years ago I had Raffy install the modulator on that brake light, it too has a short. I can wiggle the wire going into the box and wala, my brake light works. It works more than it doesn't!
I should have a chance today to check the connections on the balust and igniter on the low beam HID. If that doesn't work I will need some help.
If my Vols have a victory over those cheeseheads from Wisconsin, I should be able to check for shorts!!!!!!! If not, I will be too despondent to be doing any kind of work!
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
2014 CCR-Chattanooga
2015 CCR-Coeur d 'Alene
pkpr1998 is offline
post #2 of 21 Old Jan 1st, 2008, 9:42 am
BamaLT's Avatar
Originally Posted by pkpr1998
Ion that brake light, it too has a short. I can wiggle the wire going into the box and wala, my brake light works. It works more than it doesn't!
Trunk Monkey can help til you can get her fix.
Don G Norwood
11 R1200GSA w/DMC sidecar Radio Flyer IV
2015 G650GS, 1998 1200 C
"Oh Lord I pray, Just let me live long enough to do everything they say I have done"
BamaLT is offline
post #3 of 21 Old Jan 1st, 2008, 9:46 am
BamaLT's Avatar
I(Don N. can tell ya' what my headlight light was doing). It has a short somewhere and is probably a simple and quick fix (I hope).
Hey Brett, it's on now, no wait it's off, now it on, no off, on, off, on, off.
It only turned off when you hit any bump.
I told you to lead yesterday, that way I would never know that you had headlight problem...
Don G Norwood
BamaLT is offline
post #4 of 21 Old Jan 1st, 2008, 12:18 pm
Rick-L's Avatar
Not to pick nits, but I don't think you have a 'short'. A short circuit would probably blow fuses or start a meltdown of some sort.
Sounds more like a poor connection somewhere, or a broken wire (yes, even if the insulation is intact they can break inside sometimes).
Wiggle the wire on the modulator in different places until you can narrow it down & find the faulty connection or wire. Tighten or replace it.
As far as the headlight, I would focus on the grounding first. BMW used the smallest guage wire for the ground possible, and I think it is too small. When I installed mine I ran a nice 14ga. wire to all the ground points, the ground in the wiring harness, and to a nice solid point on the frame as well. Better yet would be a direct ground wire to the battery. Of course recheck all the hot wire connections as well.
Rick
'01 LT
Rick-L is offline
post #5 of 21 Old Jan 1st, 2008, 12:20 pm Thread Starter
pkpr1998's Avatar
I've checked the fuse and cleaned the contacts, I've "jiggled" some wires and have even reomved the plastic cone behind the headlight, couldn't get a good handle on any of the wire so there is still no low beam .
So fer now, I am helpless in Ringgold!
At least Tennessee is still winning
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #6 of 21 Old Jan 1st, 2008, 12:24 pm Thread Starter
pkpr1998's Avatar
You aren't nit-pickin'
Well, I used the term shorted out kinda of loosely!
It probably is a loose wire or something that simple, trouble is that I am a total idiot when it comes to "fixing" things!
I will keep playing with the wires.
Thanks for your input.
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #7 of 21 Old Jan 1st, 2008, 8:20 pm
cccpastorjack's Avatar
Is your HID kit from CQ lighting? If so, we have had more than one bulb go bad and when it does, it will come on for a moment and then go out.
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #8 of 21 Old Jan 1st, 2008, 9:14 pm
AliMar's Avatar
That's actually a good point... is there another bulb you can put in place of the HID without modifying anything?
Mark
'07 RT
AliMar is offline
post #9 of 21 Old Jan 2nd, 2008, 5:39 am Thread Starter
pkpr1998's Avatar
It is a CQ Kit.
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #10 of 21 Old Jan 2nd, 2008, 5:41 am Thread Starter
pkpr1998's Avatar
No I don't!
I may go ahead and purchase a new bulb.
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #11 of 21 Old Jan 2nd, 2008, 7:11 am
On my CQ kit, I had a similar issue. It would light, then go out. Got to checking the connections and bada-bing! One of the plastic connectors was allowing the metal connector inside to make contact, but the metal was actually pushing out the back. I couldn't get the little tang on the metal to bend out and stay out far and long enough to keep the plug in there. I eventually broke off a toothpick and jammed it in there with it to hold the plug in place. Has worked ever since. Check those connectors and make sure all the connectors are staying in place. try to push/pull the wire through the connector. If one can be pushed in/out, that is likely the culprit. Especially if you didn't have problems before, which would indicate a poor ground.
good luck
Randy
rando is offline
post #12 of 21 Old Jan 3rd, 2008, 6:00 am
Steve_R's Avatar
I know where the short is . . . . . .
Oh never mind!
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #13 of 21 Old Jan 7th, 2008, 9:11 pm
Soooooooooooo.......did you find the problem.
We're waiting..... tick...tick...tick...
Jack Homesley
Cornelius, NC USA
post #14 of 21 Old Jan 7th, 2008, 9:30 pm Thread Starter
pkpr1998's Avatar
Well see
The bike is at BMW of Atlanta having a few things checked, including the HID low beam.
I will try to remember to post the problem.
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #15 of 21 Old Jan 7th, 2008, 9:30 pm Thread Starter
pkpr1998's Avatar
Oh never mind!
Watch it funny guy
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #16 of 21 Old Jan 7th, 2008, 9:33 pm
Hey Bret,
I called BMW of Atlanta and they said they found the short!!!
It was between the seat and the handle bars...
Hey if they can't find it bring it over here and we'll have a mini-tech session and get 'er done.
post #17 of 21 Old Jan 7th, 2008, 9:36 pm Thread Starter
pkpr1998's Avatar
Chuckle chukle
Originally Posted by jzeiler
Hey Bret,
John, you have been hanging around Steve too long!
If they don't or can't, I will let you know!
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #18 of 21 Old Jan 8th, 2008, 8:26 am
quickbeemer's Avatar
Short Finder
I was on a team who developed a short finder for Snap on tools that would find it in about three min. Sounds more like an intermittent open, since its not blowing fuse....
R1200GSA
K1200LTC
Tony Quick
Sanford, NC
quickbeemer is offline
post #19 of 21 Old Jan 8th, 2008, 7:35 pm
tmgs's Avatar
I'd a been glad to help, but you can't ride this far! besides my lift has a Panhead on it this week <g>
know how to run wiring through a wall? I could use a hand doing that and would be mor ethan happy to return a favor
tom
<g>
Tom
tmgs is offline
post #20 of 21 Old Jan 14th, 2008, 6:30 am Thread Starter
pkpr1998's Avatar
My bike is in the shop and while there they found a loose wire! Problem solved.
Thanks for all of the feedback.
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
pkpr1998 is offline
post #21 of 21 Old Jan 14th, 2008, 8:54 am
Briantime's Avatar
I thoguht this was going to be a thread on lowering your seat
Briantime is offline
2610 and Find Address Mr_Bill GPS 3 Jul 11th, 2006 6:23 pm
how do I find my posts? tony BMWLT Site Support Forum 4 Oct 8th, 2005 5:08 pm
