Help...Rear Brake Reservoir - BMW Luxury Touring Community
post #1 of 6 Old Oct 15th, 2006, 5:47 pm Thread Starter
kosmo's Avatar
Talking Help...Rear Brake Reservoir
My 2002 LT does not have a rear brake reservoir fill screw type top. Where and how do you add the dot 4 brake fluid for the rear brakes on this model ????
kosmo is offline
post #2 of 6 Old Oct 15th, 2006, 10:28 pm
rear brake
On my 2000 model you have to remove the rear seat, and it is on the rear brake pedal side just inside the tupperware. Kind of hard to see and harder to get the cap off.
Glenn
little_jake is offline
post #3 of 6 Old Oct 16th, 2006, 4:58 am
Steve_R's Avatar
Open the right pannier cover and you'll see the sight glass for the brake resivoir. You'll have to pull the pillion seat to get to it. The cap is a quarter turn to remove and replace.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #4 of 6 Old Oct 16th, 2006, 8:29 am
You should have two "quarter" sized caps one for each of the two chambers. This is a two chamber reservoir with the wheel circuits for both front and rear.
See #2 & #3 in the attachment.
post #5 of 6 Old Oct 16th, 2006, 5:43 pm Thread Starter
kosmo's Avatar
Thanks for all the info.
I can't open your file. I did however find the top of the reservoir and wondered how to open the unit. Does it matter that you take out the sensor, do you have to un-plug the unit before you open it ???
kosmo is offline
post #6 of 6 Old Oct 16th, 2006, 10:16 pm
It is a MS word document - you must be a Mac guy. I was trying to show an image from a PDF file - guess I goofed. You should see two sensors with wires and two caps.
I would not remove the sensors (disconnect the plug if it is in the way) but the two caps should just unscrew. No need to unplug anything unless it is in the way.
The forward reservoir is shared by the rear control and wheel circuits and the rear reservoir is just for the front wheel circuit.
Accessing rear brake fluid reservoir hardrock121 K1200LT 8 Nov 1st, 2008 12:44 am
BMW Service Bulletin for Rear Brake Squeal Serebigal K1200LT 4 Apr 8th, 2006 9:40 am
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 10:37 am
Rear brake fluid reservoir Colin1952 K1200LT 7 Nov 21st, 2005 5:40 pm
Help! 04 Rear Brake Fluid Reservoir mikec826 K1200LT 2 Nov 4th, 2005 9:15 am
