2016 R1200RT 600 mile Running-in check - BMW Luxury Touring Community
post #1 of 5 Old Oct 5th, 2017, 10:33 pm Thread Starter
I just purchased a 2016 R1200RT with 3,300 miles, and the service/wrench icon is on. The seller said the dealer would typically reset that at the 600 mile check, but he did his own service and the dealer hasn't serviced the bike yet. I called the dealer and they are insisting that I bring the bike in asap for all the fluids to be changed. I am curious as to what impact on the bike or the warranty this might create if the seller did not change the fluids?
Ssherman is offline
post #2 of 5 Old Oct 6th, 2017, 8:58 am
PadG's Avatar
Re: 2016 R1200RT 600 mile Running-in check
The dealer will typically take the attitude that the service had not been done, and that is why they are insisting that you take the bike in for service. Now, if the previous owner of your bike did his own service work, he MUST have records to prove the work that was done, and the record should have been passed on to you. If not, then potential warranty work will be jeopardized, and to fix that you should take the bike into the dealer!
Just note though that there is absolutely nothing wrong with doing your own maintenance work, and BMW canNOT use that to void any warranty work. Something like that had gone to court a couple of years back, for an owner of a Mini car, and BMW had lost. I do all of my own maintenance, except for the 600 miles (to give the dealer a chance to go over the bike thoroughly after their initial set up when new), but it is important to keep meticulous records. I use BMW's own maintenance check list (they can be downloaded) to check off all items that I did, then dated, record the odometer reading, and sign as if the dealer had done the work. I also attach all receipts of the oil, filter, etc. to show exactly what oil, what filter, and so on, was used for the service.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #3 of 5 Old Oct 6th, 2017, 10:11 pm Thread Starter
Thank you. Very helpful. Any harm to the bike if the seller did not do the maintenance?
Ssherman is offline
post #4 of 5 Old Oct 7th, 2017, 8:28 am
PadG's Avatar
Probably not, but I would make sure that it is done! Basically, the fluids are changed. I think that it is relatively important to change the fluids at this time because the mechanical parts are still wearing in, and the most wear is at the beginning of the bike's life. Change the oil (both engine & final drive), and get those metal particles out.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #5 of 5 Old Oct 7th, 2017, 8:34 am Thread Starter
thank you, sir!
Ssherman is offline
Purchased R1200RT Today - New Member Saying Hi Jkayy RT Series 22 Jun 27th, 2016 9:03 am
Feedback after a 4300 mile trip on my new 2010 R1200RT aladin RT Series 27 Aug 15th, 2010 8:38 pm
12,000 Mile Service cadent50 K1200LT 29 Jan 9th, 2010 10:44 am
responded to a craigslist ad.. JPSpen Bike Talk 12 Feb 6th, 2009 10:05 pm
Head Check.... SS1000 x 4... cfell Ride Tales 12 Apr 10th, 2007 10:51 pm
