External antenna to cell phone - BMW Luxury Touring Community
post #1 of 5 Old Sep 12th, 2006, 9:25 pm Thread Starter
Has anyone hooked up an external antenna to a cell phone?
Where did you mount the antenna?
Where did you place the cell phone?
By using the external antenna, does it disable the internal antenna?
ehaughn is offline
post #2 of 5 Old Sep 13th, 2006, 8:53 am
zaphod's Avatar
I used an external antenna with my old Motorola. I mounted it on a BMR Antenna mount with the cable running to the oddments box where I had the phone. A say had because when I switched to a new Sony phone, it had so much interference with the comm. System, I had to remove it all.
Malcolm McGee
Little Rock, AR
'00 K1200LTC Canyon Red
'09 Kawasaki KLR 650
'96 Bunkhouse
IBA #24557
BMWMOA #117769
zaphod is offline
post #3 of 5 Old Sep 13th, 2006, 10:00 am Thread Starter
I am having the same issue. I assume your service is with t-mobile or Cingular (GSM). I thought of hooking up the sony ericsson phone to an external antenna and may fix the issue.
ehaughn is offline
post #4 of 5 Old Sep 13th, 2006, 11:02 am
zaphod's Avatar
Yes, I have Cingluar. I think the only solution is to put the phone in the trunk and have a bluetooth device in the oddments box connected to the intercom. My problem is my new phone isn't bluetooth.
Malcolm McGee
Little Rock, AR
'96 Bunkhouse
IBA #24557
BMWMOA #117769
zaphod is offline
post #5 of 5 Old Sep 13th, 2006, 8:55 pm Thread Starter
Do you have a suggestion for which bluetooth device?
Has anyone out there used a bluetooth adapter, interfacing into the cell port, using a gsm handset?
ehaughn is offline
06 Voice II and Cell Phone Problem MarkEngland Intercom, CB, & 2-Way Radios 16 Jul 22nd, 2008 12:32 pm
Baehr & Cell Phone Use, Two-Up hschisler Intercom, CB, & 2-Way Radios 1 Aug 21st, 2006 2:38 pm
Trivet Cell Phone Tongue as Garmin Foretrex 101 Mount MattKas GPS 0 Aug 1st, 2006 4:07 pm
I just wanna answer my cell phone... RonKMiller Intercom, CB, & 2-Way Radios 18 Jul 17th, 2006 5:32 pm
Cell Phone Volume problem bbake250f K1200LT 2 May 17th, 2006 10:13 am
