48 mpg - BMW Luxury Touring Community
post #1 of 11 Old May 4th, 2014, 10:28 pm Thread Starter
48 mpg
I've run a couple of tanks through my new to me 2013 R1200RT. The mpg indicator in the display gradually increases until it gets to 48.0 mpg and then stops. It's as if there is a limit that is preventing it from going higher.
Has anyone else experienced this?
Tom Pfeffer
2013 R1200RT,
2000 R1100RT
1983 R100RS
tpfeffer is offline
post #2 of 11 Old May 5th, 2014, 12:13 am
beech's Avatar
Re: 48 mpg
While your looking at the 48 mpg, hold the button down for 3 or 4 seconds and it will reset.
Beech
I change your tires $40, you buy them on the web.
beech is offline
post #3 of 11 Old May 5th, 2014, 2:59 pm Thread Starter
Re: 48 mpg
Yup, done that. But the same thing happens again; increase gradually to 48 mpg and no further.
Tom Pfeffer
2013 R1200RT,
2000 R1100RT
1983 R100RS
tpfeffer is offline
post #4 of 11 Old May 5th, 2014, 4:16 pm
Re: 48 mpg
ride downhill in 6th.
2011 RT
"After silence, that which comes nearest to expressing the inexpressible is music."
--Aldous Huxley
jzzmusician is offline
post #5 of 11 Old May 5th, 2014, 6:01 pm
beech's Avatar
Re: 48 mpg
Okay being difficult eh? Find a level road you can putts along at 50 or so. Now, reset the unit (until you see the dashed bars) and keep a steady state. You should be over 48. On my 2014 GS it has instant window and average windowand a second trip average window etc.. Gets complicated.
Beech
beech is offline
post #6 of 11 Old May 5th, 2014, 6:13 pm
JayJay's Avatar
Re: 48 mpg
tpfeffer - Perfectly normal behavior.
MPG is calculated as total fuel used divided by the miles driven. As you come off reset you are accelerating (using more fuel at varying rates) plus you haven't driven very many miles (low number on the bottom of the calculation). So yes, it will change, and pretty dramatically. But as you drive and acquire more miles, the number will approach the overall average you drive, and the small variations from that average will get overridden. So it seems that for the driving you do then 48 is your overall average. Which is a pretty good average, actually. I average 43.7.
JayJay
JayJay
'09 R1200 RT
'73 R75/5 Toaster (gone)
'07 Honda Rebel (gone)
Kids (gone - graduated and employed!)
'81 Honda Gold Wing (gone)
'75 Honda CB500 Twin DOHC (gone)
'77 Honda CB750 (gone)
Bride (going strong)
BMWMOA 159659
IBA 63871
JayJay is offline
post #7 of 11 Old May 5th, 2014, 6:35 pm
Re: 48 mpg
I also have a 2013 and I have on occasion registered over 50, though not often.
bwpsg42 is offline
post #8 of 11 Old May 5th, 2014, 6:57 pm
David13's Avatar
Re: 48 mpg
Yours may top out at 48. I think mine tops out at 50.
Downhill, on a reset, I have seen 78, I think.
Uphill, with a wind, 37.
But then it levels out into an average, and the little changes don't change it anymore.
Reset it and then see where it goes.
dc
2008 R1200 RT
David13 is offline
post #9 of 11 Old May 5th, 2014, 7:45 pm
Re: 48 mpg
My brand-new 2013 is currently showing 5.1 L per hundred KM which is 48 miles per gallon US. But I only have 400 miles on the odometer so it is still very tight. I expect mileage will improve as the bike loosens up.
2019 r 1250 rt
2017 r nine t scrambler (traded in)
2013 r1200rt 90th (traded in)
2012 K1600 GTL (traded in)
2009 K1200LT (traded in)
2006 FJR
2011 KLR 650
2013 SYM wolf 150
jauntytime is offline
post #10 of 11 Old May 6th, 2014, 7:04 am
mtrevelino's Avatar
Re: 48 mpg
What button (left or right on dash)? On my LT it was pretty simple. I cannot figure this out on the RT. Thanks!!!!
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is online now
post #11 of 11 Old May 6th, 2014, 10:25 am
Re: 48 mpg
Info button. On the left hand side control. Press and hold it to reset while I the MPG average screen.
I also regularly get 47-48 in my travels. Have seen higher but ornaments settles back to that range after 200-300 miles. I consider that pretty good considering my Little Triumph is lucky to get 43 and has half the engine and weight!
mbondio is offline
Tags
2013, mpg, r1200rt
