Agding GS Mirrors to the R1200RT - BMW Luxury Touring Community
post #1 of 18 Old Feb 3rd, 2013, 9:45 am Thread Starter
Hi,
I want to add a pair of GS mirrors to my 2006 R1200RT. I want the round GS mirrors, not the sleeker K1200RS mirrors. (From what I can tell, the round mirrors are higer and still allow full use of the lower mirrors).
What year mirrors need to be used?
I think that the shaft needs to be 10mm and the threaded portion needs to be 8mm.
Is that all? Is there any sort of mounting post or anything else that is needed?
Any closeup photos of the stalks mounted in the controllers?
Thanks.
twkBMW is offline
post #2 of 18 Old Feb 3rd, 2013, 12:15 pm
Re: Agding GS Mirrors to the R1200RT
I have no idea what a R1200RT looks like from the cockpit.
But I just added mirrors to my LT and still awaiting a test ride to note the improvements in my rear. The install was easy enough the right parts, hardware and Allen tool. So you would know what I am talking about here are a couple pictures. Guess other RT'ers can help you more.
ride safe
ID:	37593   Click image for larger version
ID:	37594   Click image for larger version
ID:	37595   Click image for larger version
billsmith is offline
post #3 of 18 Old Feb 3rd, 2013, 12:28 pm
Check out a thread just posted yesterday.
Under R1200RT a thread 'show your scoots' post #520. I went there to see what your bike looks like and Voila!! Is that close up enough for you
ride safe
post #4 of 18 Old Feb 3rd, 2013, 12:36 pm
MagnesiumMike's Avatar
I installed this kit on my '12 RT. The install was easy. 20 minutes. Looks great!
http://www.sierrabmwonline.com/produ...-preset-p-2514
2012 R1200RT Magnesium Beige Metallic
2014 Genuine Buddy 170i
MagnesiumMike is offline
post #5 of 18 Old Feb 3rd, 2013, 2:31 pm
Hammam's Avatar
Originally Posted by twkBMW
Hi,
Thanks.
My dealer sold me GS mirrors last Spring, and I have no reason to think they were not the latest model. He also sold me the two clamps for the handlebar, and that was it. Easy as pie. And very, very convenient. I use the upper mirrors for the view way behind me, and the RT lower mirrors for side view. Much safer.
Sorry, that's the only crops of photos I can provide.
Name:	GS mirrors.jpg
ID:	37597   Click image for larger version
Hammam is offline
post #6 of 18 Old Feb 3rd, 2013, 3:21 pm
Ponch's Avatar
The 2005-2009 don't require clamps. There is a boss in the switchgear housings that they mirrors mount. Nuts are needed though.
Ponch
"I came into this game for the action, the excitement. Go anywhere, travel light, get in, get out, wherever there's trouble, a man alone."
2009 RT
Previous bikes:2007 Nomad | 2001 Vulcan 800 Classic | 1984 GPz750 | 1978 KZ1000A2
BMWMOA 162849
BMWRA 41335
VROC 8109-R
VBA 19
Ponch is offline
post #7 of 18 Old Feb 4th, 2013, 11:05 am Thread Starter
This is what I am trying to figure out. The housing looks like the mirrors drop in from the top and have a nut on the bottom.
But look at these mirrors for a GS, they screw in from the top and have a nut to torque it down.
http://www.ebay.com/itm/2-Black-Bill...item2ec5d41d95
It looks like there is an addiitonal part needed that mounts to the switch clusters.
twkBMW is offline
post #8 of 18 Old Feb 4th, 2013, 11:10 am
Ponch's Avatar
Those won't work with a pre-2010 and needs the mounts to work with a 2010 and up.
Ponch
2009 RT
BMWMOA 162849
BMWRA 41335
VROC 8109-R
VBA 19
Ponch is offline
post #9 of 18 Old Mar 9th, 2013, 11:22 am Thread Starter
Anyone have the Part NUmber for the GS mirror?
I know they have an 8 mm thread, but there are several GS mirrors available.
Thanks.
twkBMW is offline
post #10 of 18 Old Mar 9th, 2013, 11:38 am
reddingrdr's Avatar
Morning twkBMW,
These are the parts that I used on my '12RT. I know the brackets are different but the mirrors should be the same;
Part Number Description lb Qty
Each
32727673917 CLAMP 0.04 2 $30.52
51167698694 ADAPTER 0.04 2 $7.70
51167698470 COUNTER NUT 0.01 2 $1.86
51167698437 COVER 0.01 2 $2.02
51167699791 MIRROR 0.58 2 $74.12
You must also purchase: 51167698437, 51167698470, 51167698694. They are required w/the newest 791 mirror. The friction fit (241) mirror is NLA from BMW.
(note for the '12RT)
Hope this helps.
Ron
reddingrdr is offline
post #11 of 18 Old Mar 9th, 2013, 6:26 pm
Forgive me if this is a stupid question, but how do these mirrors lock down? I know there are two nuts that lock against each other, but is loctite needed or will the nuts alone hold. Seems to me if it was bumped it'd come loose.
Greg
2011 R1200RT (sold)
2012 K1600GTL
GRB60 is offline
post #12 of 18 Old Mar 9th, 2013, 6:40 pm
reddingrdr's Avatar
Afternoon,
I used no Locktite-just the jam nut.
They stay in place.
Ron
post #13 of 18 Old Mar 10th, 2013, 8:34 am
BMW_Ken's Avatar
Originally Posted by reddingrdr
Morning twkBMW,
Each
Hope this helps.
Ron
These mirrors will not fit the OP's 2006 RT. They will only fit 2010-2013 GS and RT with the additonal brackets.
Ken Martin
Kingsport, TN
2011 R1200RT
2007 Tuono 1000R
BMW_Ken is offline
post #14 of 18 Old Mar 10th, 2013, 9:01 am
itspossible's Avatar
I used the mirrors from Wunderlich, screw right into the switch assemblies with a nylock nut underneath, $54 and a huge improvement in visibility, Look under comfort and Ergonomics in the RT section. I only use 1, on the left bar.
Ron
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
itspossible is offline
post #15 of 18 Old Mar 12th, 2013, 10:42 am
The parts for the PRE-2010 1200 RT are from the 1150 GS:
51162307769 mirror
51162309607 wave washer
51132328287 nut
Jon Bush
' 09 RT
"SAPHIRE"
bushj1 is offline
post #16 of 18 Old Mar 15th, 2013, 6:29 pm
Dann323's Avatar
I've just ordered K1200RS mirrors, They're supposed to fit on my 07 RT and I find them better looking than the GS one
1/51167653774
RIGHT REAR VIEW MIRROR
1/51167653773
LEFT REAR VIEW MIRROR
2/51162309607
WAVE WASHER - D=8,4
2/51162328287
NUT - INBUSMUTTER M8
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396
MOA # 171966
R1200RT 2007
Dann323 is offline
post #17 of 18 Old Mar 16th, 2013, 5:08 am
Dan those K mirrors look fantastic and I agree they look nicer than the GS ones. I have a 2010 RT, will these fit on my bike. Where can you get them from? Thanks for posting the picture.
Gs921441 is offline
post #18 of 18 Old Mar 16th, 2013, 10:23 am
Dann323's Avatar
I ordered them from MAX BMW
http://www.maxbmwmotorcycles.com/
I think they need an adaptor for the 2010+ model because I don't think the 2010+ models have holes in the handle bars to fit them
Name:	r1200rt mirrors.jpg
ID:	37937   Click image for larger version
Name:	r1200rt mirrors2.jpg
Daniel
IBA # 56396
MOA # 171966
R1200RT 2007
Dann323 is offline
Adding Mirrors to a R1150RTP jireynolds67 RT Series 4 Apr 26th, 2011 8:52 pm
R1200rt Mirror Options With Ztechnik Screen dembones RT Series 4 Mar 22nd, 2011 7:16 pm
Extra mirrors on R1200RT Yellowshock RT Series 33 Feb 23rd, 2011 7:56 am
Is a used 2007 R1200RT a good choice vs. the newer ones? Humbucker RT Series 13 Dec 8th, 2010 7:49 pm
stock mirrors cwo K1200LT 5 Nov 5th, 2010 6:52 pm
