RT Clutch Adjustment - BMW Luxury Touring Community
post #1 of 18 Old Mar 28th, 2009, 8:41 pm Thread Starter
Nebish's Avatar
The friction point on my clutch has advanced to the point that the clutch lever is almost fully at the end of its range of travel before the friction point is reached.
Is this something that I can adjust myself or is this a dealer service item?
Thanks in advance.
Paul M. Feldman
2008 - R1200RT "Cino"
2005 - KLT - "Tipsy" (now "Toasty") RIP
2004 - Suzuki Burgman 650
1978 - GL 1000
1985 - GL 1200 20th Anniversary Edition
1976 - Honda 750A
1973 - Honda CB 360 - "Bone Shaker"
1966 - Suzuki S80 - "Old Smokey"
Nebish is offline
post #2 of 18 Old Mar 29th, 2009, 7:04 am
Stixx's Avatar
Re: RT Clutch Adjustment
same here, the techs tell me it is not adjustable as it is hydraulic and that if it is at the end of the range it is about gone.
Riding two up with the dry clutch in the hills can use up one pretty quick as you have to start sometimes riding the thing.
I've modified my clutch technique and haven't smelled my clutch lately and it seems to be lasting but I know replacement will come prematurely if I rode two up all the time.
pretty bad thinking a clutch wont last more than this..... mines an08 woth only 14k on the clock . I'll be lucky to get 20K befroe replacing it they tell me .
No matter where you go , there you are.
Stixx is offline
post #3 of 18 Old Mar 29th, 2009, 8:46 am
Is it a warrantied item, or is it considered a normal wear item to BMW?
Scottly is offline
post #4 of 18 Old Mar 29th, 2009, 12:59 pm
Stixx's Avatar
Warranty covers the clutch only if mitigated circumstances, i.e. oil dripped on it from a failed seal etc. Normal wear it is not , was what I was told, however < I'm going to be really pissed if I have to replace it before forty thousand miles. No excuse for that. But I do know that dry clutches require a learning curve as to how to preserve them .
I was also told labor was not a whole lot of the cost of replacment so It could be a do it yourself kind of thing. Not sure I would though, just bitch about it let them do it and try to get the warranty to cover it . I think a clutch should go fifty thousand miles at least. I've never had to replace a clutch in a car and I've nad most of my cars with manual shift.
Not one of my favorite things about R bikes with weak clutches.
Stixx is offline
post #5 of 18 Old Mar 29th, 2009, 3:02 pm
Harleyujoe's Avatar
Any one know the cost to have dealers do clutch change in RT..
I just did 2 clutches in yamaha Ventures 1985 and 1996 and it was
simple job and had to make a tool at that and still 2 hour job at most.
Or has anyone changed RT clutch and how much work it is for do it yourselfer?
Does anyone have CD repair manual and how good is it..
I had Yamaha Manual and it really was worthless and went to Venture Forum
like this for RT and learned more from people who posted the repairs and
showed tolerences and short cuts and items needed to buy to do the job.
I know soon I will pickup DVD from JVB on RT that he has when he adds for
morn items for RT.
After warranty runs out I will do most of my own work that I can do.
I know with computers onboard it restricts some things from do it yourselfer.
So wonder how much others here have torn into these RT's ...Joe
Harleyujoe is offline
post #6 of 18 Old Mar 29th, 2009, 3:44 pm
This is from the CD manual. All of the steps are linked to their appropriate section of the manual. So, if you want to know how to remove the seat, you would click on "Removing seat" and it will open another window and show you how.
Otherwise, I think the manual is as good as any other I have used.
Preparatory work
Removing seat
Disconnecting battery
Removing tank rail
Removing left-**hand trim panel
Removing entire left side tank cover
Removing right-**hand trim panel
Removing storage compartment lid
Removing entire right side tank cover
Removing fuel tank
Installing engine lifter
Removing silencer
Removing intake air pipe
Removing right and left injection valves
Disconnecting both throttle-valve stubs
Securing throttle valve stub with cable divider
Disengaging selector rod from shift lever
Removing clutch slave cylinder from gearbox
Removing right footrest plate
Disconnecting brake pipe for rear wheel circuit from pressure modulator
Removing rear-light unit
Disengaging wiring harness at rear
Removing rear section of motorcycle
Removing gearbox potentiometer
Removing starter
Removing clutch cover
Removing gearbox
Removing belt guard
Core activity
(+) Removing clutch
(-) Removing clutch
By means of the belt pulley, turn the engine in the normal direction of rotation until the engine locking device can be inserted.
Insert engine locking device (No. 11 5 640).
Working in diagonally opposite sequence, loosen screws (4) in stages.
Remove engine locking device (No. 11 5 640).
Remove the thrust plate together with diaphragm spring (1), clutch plate (2) and housing cover (3).
(+) Checking clutch for foreign matter
(-) Checking clutch for foreign matter
Remove housing cover (3) from thrust plate (1) and remove clutch plate (2).
Test
Check the friction faces of thrust plate (1) and housing cover (3) for foreign matter.
Result: Oil or grease on friction faces.
Measure:
Clean and degrease the friction faces.
Consumables/lubricants
Brake cleaner
Cleaners
83 11 9 407 848
Test
Check clutch plate (2) for foreign matter.
Result: Oil or grease on clutch plate.
Measure:
Replace clutch plate (2).
=> Check clutch (clutch removed) (Item: 21 21 600, Billed as a separate item)
(+) Installing clutch
(-) Installing clutch
Install the thrust plate together with diaphragm spring (1), clutch plate (2) and housing cover (3) in the clutch housing.
Note
The clutch components are all precision-balanced. It is not necessary to check for identification marks when assembling.
Insert screws (4).
Use centering pin (No. 21 2 673) to centre the clutch plate.
Tighten screws (4).
Tightening torques
Clutch housing cover to clutch housing
Never re-use the original screws, M6 x 20
tighten by stages in diagonally opposite sequence
12 Nm
Remove engine locking device (No. 11 5 640) and centering pin (No. 21 2 673).
Finishing work
Installing belt guard
Installing gearbox
Installing clutch cover
Installing starter
Installing gearbox potentiometer
Installing rear section of motorcycle
Securing wiring harness at rear
Installing rear-light unit
Connecting brake pipe for rear wheel circuit to pressure modulator
Installing right footrest plate
Installing clutch slave cylinder
Securing selector rod to shift lever
Releasing throttle valve stub with cable divider
Installing throttle-valve stub
Securing right and left injection valves
Installing silencer
Removing engine lifter
Connecting battery
Filling rear wheel circuit
Connecting BMW Motorrad diagnostic system to motorcycle
Installing intake air pipe
Installing fuel tank
Reading fault memory with BMW Motorrad diagnostic system
Checking synchronisation
Disconnecting BMW Motorrad diagnostic system from motorcycle
Installing entire right side tank cover
Installing storage compartment lid
Installing right-**hand trim panel
Installing entire left side tank cover
Installing left-**hand trim panel
Installing tank rail
Installing seat
Final check of work performed
Scottly is offline
post #7 of 18 Old Mar 29th, 2009, 5:50 pm
taran1900's Avatar
"pretty bad thinking a clutch wont last more than this..... mines an08 woth only 14k on the clock . I'll be lucky to get 20K befroe replacing it they tell me "
I have a hard time believing your clutch is shot at 14k. My RT now 75k and clutch is just fine. There is one rider on the BMWSportTouring board with 154k on his RT and the original clutch. Sure you're not just being a little paraniod?
Scott T
McKinney, Texas
2019 R1250RT
taran1900 is offline
post #8 of 18 Old Mar 29th, 2009, 5:53 pm
Stixx's Avatar
well that doesn't sound very simple therefore it doesn't sound like it would be inexpensive to repair by dealer. Maybe I misunderstood my tech.
We'll see soon enough. Mine is starting to smell burned most times I ride two up, even in cold weather. Geez. This is not impressive to me at all............
Stixx is offline
post #9 of 18 Old Mar 29th, 2009, 6:13 pm Thread Starter
Nebish's Avatar
My momma used to say: "don't pee until the water comes", although it might be comforting to know if I have to take out a second, sub-prime mortgage when my time comes.
From the listing of the steps involved, I am not touching this one. Way beyond my capabilities.
Paul M. Feldman
1978 - GL 1000
1976 - Honda 750A
Nebish is offline
post #10 of 18 Old Mar 29th, 2009, 6:51 pm
I don't know who told you that most of the cost isn't labor. I would venture to say that most of the cost is labor. I know I had to pay for the clutch repair in my old LT. The parts were about 300.00. My total bill would have been 1800 without the extended warranty and ended up being about 1300+ since they only covered the seal work that failed.
I hate to say it, but I believe it will be pricey. If you have it done outside of warranty, you can probably get it done by an aftermarket BMW motorcycle shop for significantly less instead of a BMW dealer.
But, before I go that route, I would ask the dealer to take it directly to BMW on your behalf.
Good Luck
rglassma is offline
post #11 of 18 Old Mar 29th, 2009, 7:04 pm
I put a clutch in my old R1100RT at about 80,000. Took me about 8 or 9 hours. I'm a profesional auto mechanic so I have some experience. I could definately do it quicker if I had to do it again. Hopefully my R1200RT won't need one. I think parts were about $400 but it was 3 years ago so I can't be shure.
Bob1200rtc1 is offline
post #12 of 18 Old Mar 29th, 2009, 8:29 pm
Stixx's Avatar
just passing along the info my tech told me when i told him most of my travel was gone in my clutch could they adjust it. He said if the travel is gone it means the plate is about used up and that would explain the smell after riding two up that i was getting.
I wrote it off as riding the clutch too much on the hill starts around the hills where I have to start off at lights which are on steep hills with a chubby passenger and a bike that likes to stall if you don't give it enough gas.
Paranoid, maybe, I hope you are right and I am paranoid. time will tell.
Stixx is offline
post #13 of 18 Old Mar 29th, 2009, 9:01 pm
OU812's Avatar
I am starting to miss my multi plate wet clutch. 1 hour change out on most of them.
BMW'S ARE THE WORST BIKE IN THE WORLD, CEPT' WHEN YOU COMPARE THEM TO EVERYTHING ELSE!
OU812 is offline
post #14 of 18 Old Mar 29th, 2009, 10:09 pm
Stixx's Avatar
well don't let me pour water on your parade, maybe my clutch will go the distance and the funny smell after two up riding, and lack of travel in the grip is just some other thing.
Like these guys say many guys are getting long clutch life. Perhaps I was spoiled with jap bikes and I just need to learn how to drive these dry clutchs.
Or get a jap bike with a slipper clutch and not worry about that aspect of riding. LOL
Stixx is offline
post #15 of 18 Old Mar 30th, 2009, 7:47 am
05hexhead's Avatar
I had transmission and counterbalance seals replaced under warranty. The clutch plate was removed and checked for contamination. I received all the paperwork and the labor time was listed as 11 hours. I know this is probably the value the dealer was able to charge BMW, but consider that they have the knowledge and special tools.
You might want to remove the starter and use a light and small mirror to check and see if your engine and tranny seals are not leaking. The plate might be contaminated and this would be warranty work. Is the engine and tranny free of oil externally?
Nick
05hexhead is offline
post #16 of 18 Old Mar 30th, 2009, 9:20 am
hopz's Avatar
I have been reading the thread and want to go back to Paul's original question. I know there is no adjustment except for the dials on the lever. I assume that dial adjustment has been checked and it is where you thought it was.
I sometimes have garage gremlins and things get changed. Actually it could have been kids with curious fingers. But I digress.
In my opinion, from thousands of miles away... I just have to believe that there is something else going on beyond "normal" wear and tear.
In the thousands of posts here and on other boards, I have not read reports of this kind of clutch life. It might have been a manufacturing problem or maybe even a user's bad habit- which I sincerely doubt, but this kind of wear is just not heard of.
I hope Paul gets to the bottom of this story and keeps us informed.
2014 R1200RT WC
“As Woody Guthrie says, ‘Left wing, right wing, chicken wing.’I keep my mind open. Whatever you believe, it’s all a mystery in the end.”
hopz is offline
post #17 of 18 Old Mar 30th, 2009, 1:44 pm Thread Starter
Nebish's Avatar
Thanks for all of the input. It is much apreciated.
I am in the process of trying to get the bike looked at. The problem is that with the start of the riding season after a winter that never seems to end and every bike in creation in need of service, getting an appointment will take a few weeks. And since the bike is currently under warranty, I need Motorrad to cover the cost of any repairs, if possible. That means getting the dealer to handle this one.
I will report back in due course.,
Paul M. Feldman
1978 - GL 1000
1976 - Honda 750A
Nebish is offline
post #18 of 18 Old Apr 1st, 2009, 9:51 am
falconspirit's Avatar
Paul:
BMW Durham service schedule is wide open. Just completed my 20,000 for the RT last week that I had scheduled the day before and I had no problem scheduling my 1,000 for the GT. The weather looks promissing for the next few days.
Hope all is well.
Anthony
Toronto Canada
'09 K1300GT - Falcon
'07 R1200RT - Silver Falcon
'03 HD Sportster XL1200C Anniversary - Shake & Bake
falconspirit is offline
Take off, 'eh? Starting the LT from stop... petevandyke K1200LT 26 May 30th, 2012 9:48 am
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
Clutch Adjustment strsout K1200LT 19 Jul 8th, 2007 8:35 am
Clutch adjustment? REWDOC K1200LT 15 Mar 6th, 2007 9:19 am
