Anyone install Armrests on RT with Topcase - BMW Luxury Touring Community
 2Likes
  • 1 Post By 17GolfRAPR
post #1 of 30 Old Oct 14th, 2007, 10:49 pm Thread Starter
Hanshi's Avatar
I have a K1200GT which I put on a RT Luggage Rack which permitted me to install a RT Topcase on my rig. An interested inf any RT owner has found any passanger armrests that would work with the RT Topcase and rack set up? I know of three armrest makers for the LT, but have not found anything for the RT. Any suggestions would be helpful.
Here are some photos of my rig.
ID:	14742   Click image for larger version
Name:	Russell Seat-1*.JPG
Hanshi is offline
post #2 of 30 Old Oct 16th, 2007, 3:40 am
Nice set-up but one question comes to mind - if you put armrests on the rear seat how on earth is the pillion supposed to get on/off???
brianbeemer is offline
post #3 of 30 Old Oct 16th, 2007, 5:44 pm Thread Starter
Hanshi's Avatar
The armrests typically flip up or out so that the rider can get on and off easily.
Hanshi is offline
post #4 of 30 Old Oct 19th, 2007, 3:32 pm Thread Starter
Hanshi's Avatar
Come on guyts - there has to be some of you RT's out there who desired to have armrests on your rigs. I emailed Don Mud who makes Eagle Armrests for the LT and he indicated that he has had a lot og interest from RT owners, but that he did not have access to a R1150RT rig to be able to take measurements and work up a solution. If there is any RT'er in the Orlands, FL area who could drop by Don's place so he can check it out - we might have something going here. If you can help his email is" "[email protected]"
Hanshi is offline
post #5 of 30 Old Oct 22nd, 2007, 8:04 pm
Hello all Don Muddiman here,
I have some questions about the top box.
1) What is the width of the passenger back pad?
2) What is the distance between the inside of the top case hinges?
Knowing these distances will give me a better feel if it’s fesable to mount armrests.
Keep'em Humming,
Don
Eagle Innovations
K1200LT Armrests
mudman is offline
post #6 of 30 Old Oct 23rd, 2007, 9:38 pm Thread Starter
Hanshi's Avatar
Don:
I will take some close up photos as well as provide dimensions and will post to you here tomorrow when it is light out.
Thanks for looking into this.
Hanshi
Hanshi is offline
post #7 of 30 Old Oct 25th, 2007, 9:53 pm Thread Starter
Hanshi's Avatar
Originally Posted by Hanshi
Don:
Hanshi
Don:
Here are some measurements that you asked for on the Forum. I have also taken some photos of the topcase for reference.
The inside distance between the hinges is 11 1/2 inches
The hinges are 2 1/8 inches wide and 3 1/2 inches high.
The backrest is 10 7/8 inches wide and 1 1/2 inches thick
The bottom of the hinge is 3 1/4 inches above the seat height
Hope this information helps.
Bruce
ID:	14954   Click image for larger version
ID:	14955   Click image for larger version
ID:	14956   Click image for larger version
ID:	14957   Click image for larger version
Hanshi is offline
post #8 of 30 Old May 12th, 2008, 9:29 pm
Re: Anyone install Armrests on RT with Topcase
This weekend I finished up the first prototype armrests for the RT thanks to LaRae for letting me keep his BWM top case for several weeks. I still need to meet up with LaRae to test the design and see if there are any problems. I was limited with the armrests height but it should fit the standard passenger. Attached are some images of the completed product. The Carbon fiber mounting plate will not be the final product. I only used the Carbon fiber as proof of concept as it was the easiest and quickest way for me to get a finished product. If this works out my next step will to talk with my fabricator to see if he can do the part and what the cost will be. I will also need packaging, fasteners and other machined parts not shown.[/font]
ID:	17838   Click image for larger version
ID:	17839   Click image for larger version
ID:	17840   Click image for larger version
ID:	17841   Click image for larger version
Keep'em Humming,
Don
Eagle Innovations
K1200LT Armrests
mudman is offline
post #9 of 30 Old May 13th, 2008, 6:49 am
Isn't there a safety issue here? In a spill, won't the armrests be in danger of trapping the pillion? - Just a thought.
pdeseymour is offline
post #10 of 30 Old May 13th, 2008, 4:33 pm
Yes there is a safety concern that's why I designed the armrests to fail in such situations. As the designer I had an unfortunate experience to test my design. I stalled the bike from takeoff going up a slight incline and down the wife and I went. The down side armrest failed and she never realized she had broken the armrests. A select hinge mount cross section area in combination with a select Aluminum alloy allowed me to provide this safety feature. They are designed to rest your arms not support you body weight. This the same design as the LT but with a different mounting plate.
Keep'em Humming,
Don
Eagle Innovations
K1200LT Armrests
mudman is offline
post #11 of 30 Old May 13th, 2008, 5:16 pm
Looks great, showed my wife, she loves you and wants a set as soon as they are available. At least I won't have to hear her complain about our friends on their LT with armrests.
Ute's Chauffeur
stepheg is offline
post #12 of 30 Old May 16th, 2008, 11:28 am
Those armrests look fabulous. Better passenger accommodations are the only thing stopping me from ditching my K-LT in favor of a R-RT. I think the R is a superior overall bike, with the exception of passenger comfort.
If and when possible, please post photos of the entire assembly bolted to the bike.
Many thanks.
CalLT is offline
post #13 of 30 Old May 18th, 2008, 8:48 pm
Don,
Those look great. Would you be kind enough to put me on some sort of waiting list for when they are available.
Should we just keep checking here for availability?
Louis
llanda9 is offline
post #14 of 30 Old Jun 23rd, 2008, 9:48 pm
Don,
Any update on the armrests?
LL
llanda9 is offline
post #15 of 30 Old Jun 24th, 2008, 8:28 am
Ditto.
tinman1929 is offline
post #16 of 30 Old Jul 2nd, 2008, 8:44 am
Hi Guys,
I am still researching suppliers for the mounting hardware for the RT, hopefully I will know more by the end of the month.
Keep'em Humming,
Don
Eagle Innovations
K1200LT Armrests
mudman is offline
post #17 of 30 Old Sep 7th, 2008, 7:45 pm
Don,
Any news on the RT armrests?
Louis
llanda9 is offline
post #18 of 30 Old Sep 16th, 2008, 7:36 pm
Nudge once more ...
CalLT is offline
post #19 of 30 Old Oct 12th, 2017, 7:22 pm
I'm in love with Hanshi's color-matched RT top case on his K1200GT. Found a pic of his beautiful sea-foam green rig on Google and followed it here to his post... from 10 years ago... (yikes!) and thought maybe I could contact him. Alas, being newly registered I can't PM him :-(
If anyone still knows of him or of his gorgeous RT top case I'd love to try and find a similar set up for my K1200RS. Thanks folks.
K1200RS4ever is offline
post #20 of 30 Old May 24th, 2018, 11:12 pm
Location: We've traveled the US in our Coach with Tweety & Sylvester on the sides & Tweety on the back waving.
Has anyone heard anymore about the 1200RT Passenger arm rest, by mudman? I'd be interested in a setup for my 2015 1200 RT.
JesusLover is offline
post #21 of 30 Old Dec 10th, 2018, 6:55 am
Are these armrests available for a R1200RT from 2011?
benalla is offline
post #22 of 30 Old Dec 10th, 2018, 4:26 pm
motorhead1977's Avatar
Interested as well but my top case is the older RT model that has the handle at the rear and what looks to be a thinner smaller back pad.
Motorhead1977, Albany, NY
"You have not converted a man because you have silenced him."--John, Viscount Morley On Compromise, 1874
Dissent is Patriotic - Let us never forget that America was born of dissent.
2018 R1200RTW - Mars Red
2015 Ducati Scrambler Icon - '62 Yellow
1987 Honda VFR400R Rothmans livery
motorhead1977 is offline
post #23 of 30 Old Dec 12th, 2018, 12:55 pm
17GolfRAPR's Avatar
I went with Graber Industries. His are not specific to the RT because of the curvature, but he worked with me to get me one of his “blanks” (unbent, unpainted) and I did the rest. Came out really good.
ID:	148893   Click image for larger version
ID:	148895   Click image for larger version
Qball-16 likes this.
Tom
Past:
64 Yamaha 125
67 Yamaha 125 Scrambler
69 Yamaha 305
71 Honda 305 Scrambler
71 BSA 441
73 Norton 850 Commando
95 HD Roadking
01 HD 1200 Sportster
17GolfRAPR is offline
post #24 of 30 Old Dec 12th, 2018, 2:17 pm
Qball-16's Avatar
Ooooh, that looks bloody awesome and I know my wife would LOVE something like that! If you don't mind me asking, which armrest did you get (15" or 17", straight back or radius back) and how did you go about attaching it to the top case?
Thx!
2016 BMW K1600GTL
IBA Member #74163
Qball-16 is offline
post #25 of 30 Old Dec 12th, 2018, 10:27 pm
17GolfRAPR's Avatar
Sorry, I don’t know how he gets his sizes. He sent me an unbent piece that was about 29” long. It had no radius, or bends. I put the radius in by hand to match the top case, then took it to a metal shop to bend the arms. I painted it, drilled 4 holes and bolted it to the top case.
Tom
Past:
64 Yamaha 125
69 Yamaha 305
71 BSA 441
95 HD Roadking
post #26 of 30 Old Dec 13th, 2018, 10:20 am
Qball-16's Avatar
Thanks for the info! I don't have much experience with metalwork, so I would likely just get the radial back version and fill any gaps with spacers, if necessary. I can't imagine the radius of the arm rest and the radius of the top case would be hugely different.
Last couple questions:
How solid is the the top case as an attachment point for the arm rest?
Does it flex much or at all?
Did you bolt it through both the inner and outer shells (right through to the inside compartment)?
Cheers!
2016 BMW K1600GTL
IBA Member #74163
Qball-16 is offline
post #27 of 30 Old Dec 15th, 2018, 9:53 pm
17GolfRAPR's Avatar
It’s pretty solid. Used 4 bolts thru inner and outer shell through to inside. Capped nuts with plastic caps. Wife has put full body weight on it a few times, against my advise. She doesn’t weigh much, but so far it’s held up.
I thought of getting the radius one too, but vendor talked me out of it. Probably because he asked if I was handy. I think you’ll do fine. Let me know how you do.
Tom
Past:
64 Yamaha 125
69 Yamaha 305
71 BSA 441
95 HD Roadking
post #28 of 30 Old Mar 29th, 2020, 1:01 pm
Is anyone still active here and was there ever a solution to the RT passenger armrest? I just purchased a 2003 R1150RT and am racking my brain trying to find a solution. Thanks. Aron
Trying to post pics but can't figure it out. Haha
Aron R. Fleck is offline
post #29 of 30 Old Mar 29th, 2020, 1:07 pm
I was able to post picks in a response to my original post
ID:	156185   Click image for larger version
ID:	156187   Click image for larger version
ID:	156189   Click image for larger version
ID:	156191   Click image for larger version
post #30 of 30 Old Apr 8th, 2020, 10:33 am
Hi
This would be a smart solution if you make one to mount on the top box. Then for shorter trips it wont be in the way
I have an K1200 GT mod 2008 up here in Norway. Most of the people driving BMW is not the youngest one and are always looking for more comfort on long trips. If you make an solution that fits several models you will have invented the wheel again. Looking forward to follow you. Have a nice Easter, drive carefully and wash your hands.
StÃ¥le Hørlyk is offline
Another HID install RaffyK Lighting 8 Dec 19th, 2009 5:54 am
A Dealer Who Won't Install Farkles ronk1200lt Dealer Experiences 11 Jul 23rd, 2007 7:09 am
Do This Immediately...REMOVE THE TOPCASE! Billy K1200LT 33 Dec 19th, 2006 10:17 am
Armrests in Gray? BUGKILLER Ergonomics & Rider Comfort 3 Mar 29th, 2006 3:10 pm
Topcase design sledman K1200LT 1 Oct 3rd, 2005 12:16 pm
