Wonky Nav VI on '16 RT - BMW Luxury Touring Community
 17Likes
post #1 of 57 Old Apr 9th, 2020, 6:07 pm Thread Starter
N00bie RT Gawd's Avatar
So I have, at least for now, a '16 RT with GPS prep and the Nav VI.
What's happening is that as I am riding along, the screen starts going berserk- it's acting like a million inputs are being sent to it rapidly. The items on the screen jump all over the place, the zoom maxes-out, touching the screen mostly doesn't do anything and flipping through the various GPS pages via the thumb wheel doesn't help.
My remedies in the past have been to remove it from the bike and really wiping-down the screen. Most of the time this seems to work, but sometimes it'll happen almost right away. As suddenly as it happens, all of this weird behavior will just disappear. I can go for a year without an issue but then have it happen three times in a week.
I am wondering if there is a problem with the Wonder Wheel and the connections in the dash for the Nav VI and somehow errant signals are being sent to the GPS? I am leaning this way because my first Nav VI behaved like this and I laid the blame at its feet and Garmin replaced the unit, but now I see that didn't help...unless there is something goofy about the Nav VI in the first place causing these issues.
Anyone else have this issue?
Those who say that it can't be done shouldn't interrupt those who are doing it.
Democrats are to America what mold is to bread.
N00bie RT Gawd is offline
post #2 of 57 Old Apr 9th, 2020, 7:33 pm
Dann323's Avatar
Re: Wonky Nav VI on '16 RT
Mine works fine.
Is it fully connected in the cradle? If not, you will see a small red tab at the top
Do you have the latest software installed with Garmin express?
I suspect a bad connection in the cradle. (Try contact cleaner)
Or it could be a defective unit.
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396, MOA # 171966
2019 R1250RT. 2007 R1200RT (186000 km)
Dann323 is offline
post #3 of 57 Old Apr 9th, 2020, 7:38 pm Thread Starter
Originally Posted by Dann323 View Post
Yeah it's fully connected. I haven't tried contact cleaner, but they all look super clean right now. Someone in the IBA forums said this isn't unusual and that people who had them replaced usually had to get them replaced a 2nd time. Garmin, he said, seems to have some hardware issues that they finally got sorted.
My first one acted like this and was returned. I was surprised when the second one also started goofing up.
So, given the info received, I sent them an email.
post #4 of 57 Old Apr 9th, 2020, 7:45 pm
Dann323's Avatar
I mentioned contact cleaner because I had issues with the Zumo 350 which was loosing power due to a bad contact with it's cradle on my 07 (No screen issues though)
The contact pins were mounted on small springs that got dirty and would prevent the pins from moving and making contact with the unit.
YMMV
Daniel
Dann323 is offline
post #5 of 57 Old Apr 9th, 2020, 8:00 pm Thread Starter
YMMV
I don't have any contact cleaner- can I use diet coke?
post #6 of 57 Old Apr 9th, 2020, 8:06 pm
Dann323's Avatar
I don't think so. Coke Zero maybe...
N00bie RT Gawd likes this.
Daniel
Dann323 is offline
post #7 of 57 Old Apr 9th, 2020, 8:16 pm Thread Starter
Now I have an excuse to go out tomorrow!
post #8 of 57 Old Apr 9th, 2020, 9:52 pm
GSinNC's Avatar
This is a common issue with the NAV VI. There are a couple of threads on both Advrider and BMWST discussing this
ghosting issue. I had this happen twice and got a replacement from Garmin. If you give them a call the support is excellent.
https://advrider.com/f/threads/nav-v...1422861/page-9
https://advrider.com/f/threads/bmw-n...pdate.1416364/
https://advrider.com/f/threads/nav-v...wheel.1398933/
https://www.bmwsporttouring.com/topi...omment-1008282
rapz and N00bie RT Gawd like this.
Ed Apelian
'18 R1200GS - Light White
GSinNC is offline
post #9 of 57 Old Apr 9th, 2020, 10:30 pm
Send it back.
LeeMan is offline
post #10 of 57 Old Apr 9th, 2020, 10:32 pm
Not unusual for the Nav VI - just send it back and roll the dice that the next one you get works as designed.
LeeMan is offline
post #11 of 57 Old Apr 10th, 2020, 12:42 am Thread Starter
Thanks, Ed. I indeed sent them an email and they got right back to me; we're doing an exchange now. Hopefully this cures it.
post #12 of 57 Old Apr 10th, 2020, 5:25 am
GSinNC's Avatar
Yep great service. I sent mine back after the 2nd incident of the ghosting. That was probably 9 month ago and so far so good. Some guys have had no issues and others are on their 3rd or 4th unit. Let's hope they have it resolved.
Good luck and do keep up posted on your experience.
Ed Apelian
GSinNC is offline
post #13 of 57 Old Apr 10th, 2020, 8:21 am
A common problem with the NAV VI... when mine started doing it, I called Garmin Support, they said they would email me a return authorization, then sent me a new replacement....
Great service from Garmin !!!!!!
biker01red is offline
post #14 of 57 Old Apr 10th, 2020, 10:34 am
timothya1's Avatar
Same problem, same solution, replacement unit worked like a champ.
Garmin support on this issue was fantastic.
Timothy Allen
2017 R1200RT
timothya1 is offline
post #15 of 57 Old Apr 10th, 2020, 1:53 pm Thread Starter
I believe that the Nav VI came out in January of 2017? If so, I got mine in May of that year, so definitely an early batch. That unit had this issue and was replaced within 9 months. This second unit also has the same issues, but really became bad more recently, causing me to miss critical turns in areas I wasn't familiar with.
Ed, I read all 12(!) pages of that first link and am amazed on how widespread this seems to be. What's interesting to me is that they talk about getting hardware version V8 and mine is V5, so just a few revisions behind, lol.
There was some discussion about the Nav VI being discontinued, but someone posted an email from BMW about that. It just seems the model number or something internally was being changed and that was why people would see the "discontinued" label on the Nav VI web page. The Nav VI is not discontinued.
Then there's the new Zumo XT. Looks nice and at $499 is reasonably-priced. Would be nice to be able to fit it in the area the Nav VI went, but the body is about 1/2" wider than that opening. I also don't know if it's really "worth it" for a variety of reasons even though I like the more modern interface and some of the features.
Finally, I am not sure why the talk about how the Nav VI is integrated with the Wonder Wheel is even touted...all it can do is switch between a few pages and zoom in/out, unless I am missing something.
Anyhow, Garmin didn't even try to insult me about "troubleshooting" steps before exchanging it, so that's a plus for them.
GSinNC and tvguy like this.
post #16 of 57 Old Apr 11th, 2020, 7:01 pm
oldspice's Avatar
Glad to hear that Garmin took care of you. They obviously know there's an issue there. Let us know which hardware version you receive. I'm assuming/hoping V8, which I believe is the latest and "greatest".
"Looks like I picked the wrong week to stop sniffing glue..."
2015 BMW R1200RT - "Artoo"
2012 BMW R1200RT - "Arthur", RIP
1985 Ford Escort L (for Luxury) - Ol' Blue - gone, but not forgotten
MSF RiderCoach
BMW MOA 175432
oldspice is offline
post #17 of 57 Old Apr 11th, 2020, 8:47 pm
Dann323's Avatar
I got mine last January when I bought my 1250 and it is V8.
I assume it's the latest version
Daniel
Dann323 is offline
post #18 of 57 Old Apr 12th, 2020, 11:16 am
How do you verify which hardware version you have?
Through the GPS software, or maybe a label under the battery cover?
meese is online now
post #19 of 57 Old Apr 12th, 2020, 11:56 am
Dann323's Avatar
On the NAV VI you have to go to: Settings/Device/About
Daniel
Dann323 is offline
post #20 of 57 Old Apr 12th, 2020, 5:06 pm
I may have to charge my two Nav VI's first, as they haven't been getting much use lately...
meese is online now
post #21 of 57 Old Apr 12th, 2020, 5:40 pm
Dann323's Avatar
I just discovered something strange.
On my Zumo 350 I was able to put an icon on the 'Where to' page to directly access my custom POIs.
This option was not available on the NAV VI which I found strange.
My NAV VI is setup in French which is my native language. I switched it to English to make sure I had the exact terms for the path I gave earlier concerning the unit's hardware level.
Now the option is available
The option is not available if the NAV VI is set to French. I don't now about other languages
I installed it when it was set to English. When I switched it back to French, the icon was gone.
Looks like I will have to leave it in English if I want quick access to my POIs
Daniel
Dann323 is offline
post #22 of 57 Old Apr 13th, 2020, 1:33 pm Thread Starter
Are you saying that on the Nav VI home screen (where it says "Where To?" and "View Map"), that you were able to place a custom icon on that screen? How?
post #23 of 57 Old Apr 13th, 2020, 1:35 pm Thread Starter
Update from Garmin: Getting the new one on Wednesday, the 15th.
And as an FYI: The hardware version is Settings->Device->About. If you want the Serial Number, you need to remove the battery cover and lift the battery.
post #24 of 57 Old Apr 13th, 2020, 2:02 pm
Dann323's Avatar
Not on the map. On the 'Where To' page with the BMW Motorrad, Gas stations, etc icons.
The Icons you can put on the map are pre-determined
Daniel
Dann323 is offline
post #25 of 57 Old Apr 13th, 2020, 7:37 pm
PatM55's Avatar
Good catch. I tried on my Nav V and I too don't see custom POIs when in French. If you look into the "Categories" search button on the right, the "Points d'intérêts personalisés" is there if you go down. However, all I see in there are BMW Independent shops, Red light and speed traps.
My question is when and how would you use that button? I must say that rarely use the search function on the gps other than gas or maybe hotels.
Ride safe!
PatM55 is offline
post #26 of 57 Old Apr 13th, 2020, 10:52 pm
Dann323's Avatar
I have tons of POIs like: Ethanol free gas stations, Motorcycle parking spots , rest areas, border points, Personal stuff etc that I transfer from Basecamp to my GPS.
I use the POIs more when planning routes in Basecamp but I like having some of them in the GPS as backup
I emailed Garmin but so far they didn't come up with a working solution.
YMMV
Daniel
Dann323 is offline
post #27 of 57 Old Apr 14th, 2020, 8:43 am
It's a known fault. Contact Garmin for a replacement. If in the US, 5 year warranty; UK is 2 years (Garmin offer a replacement service for a charge if outside of warranty).
_B_M_ is offline
post #28 of 57 Old Apr 15th, 2020, 11:13 am
Dann323's Avatar
After a couple of emails with Garmin and no solution, they will replace my NAV VI
Voyager likes this.
Daniel
Dann323 is offline
post #29 of 57 Old Apr 15th, 2020, 5:45 pm Thread Starter
I got mine today. Hardware v8 and the only other change was that the BMW Motorrad version was bumped from 12 to 13.
post #30 of 57 Old Apr 26th, 2020, 9:37 am
PatM55's Avatar
Hi Dan, I just got a slightly used Nav VI from a friend, it has the same issue as yours.
The custom POI disapears when switching to french. I also tried in Italian, same thing.
I wouldn't be surprised if the new one you get has the same issue.
Ride safe!
PatM55 is offline
post #31 of 57 Old Apr 26th, 2020, 9:43 am
Dann323's Avatar
The new unit didn't solve my problem. It looks like it's a coding issue since the function works in all other language I tried except French. (I even tried in Afrikaan...)
Daniel
Dann323 is offline
post #32 of 57 Old Apr 26th, 2020, 11:32 am
GSinNC's Avatar
Hey ... just a related question ... if the NAV VI is discontinued and they need to replace it ... what are they now replacing it with? Do they still have some VI's in stock?
Would be great to have them replace it with a NAV VII
Ed Apelian
GSinNC is offline
post #33 of 57 Old Apr 26th, 2020, 4:28 pm Thread Starter
The Nav VI is still in stock and no next-gen Nav units are being talked about.
Dann323 likes this.
post #34 of 57 Old Apr 26th, 2020, 6:24 pm
GSinNC's Avatar
Thanks! I had heard the NAV VI was discontinued so was not sure. Guess they have a stock pile of them for replacements :-)
Ed Apelian
GSinNC is offline
post #35 of 57 Old Apr 26th, 2020, 6:42 pm Thread Starter
What happened is that the SKU numbers, or something like that, where changed and that caused Garmin's website to erroneously say that they were out-of-stock. That detail was fixed and you'll find them in-stock.
But seriously, if the day comes when the Nav VI just completely gives up the ghost and Garmin can't replace it, I'll be going to the new Zumo. It looks to be way better and only like $500 whereas the Nav VI is still priced near a grand- shame on you, Garmin!
Matter of fact, if I could figure a way to mount the new Zumo in the spot where the Nav VI goes, I would ditch the VI in a heartbeat.
post #36 of 57 Old Apr 26th, 2020, 8:30 pm
Dann323's Avatar
That's why they make sure nothing else fits...
PatM55 and N00bie RT Gawd like this.
Daniel
Dann323 is offline
post #37 of 57 Old Apr 26th, 2020, 10:54 pm
GSinNC's Avatar
The only issue with going with a non-NAV is the Wonder Wheel does not work. And while I have not seen the new Garmin Zumo all prior non BMW GPS units did not have the display the Nav VI has where it is clear and perfect in direct sunlight. If the new Zumo has that kind of display I'd be tempted. The wonderful display is why I upgraded from my Nav V
Ed Apelian
GSinNC is offline
post #38 of 57 Old Apr 27th, 2020, 12:29 am Thread Starter
I have really yet to see any benefit of the integration with the WonderWheel. As far as I can tell, it only flips through the various screens and zooms in/out.
The disappointment I have with this lack of doing anything useful was similar to my recent experience with Android Auto- it wouldn't display the text message on the screen but read it aloud...badly.
Here is a write-up about the new Zumo XT by some guy names Greg Rice. I don't think you'll be disappointed.
post #39 of 57 Old Apr 27th, 2020, 8:39 am
GSinNC's Avatar
Well I am probably the exception here but I do not synch my phone to my GPS. I don't want to get phone calls or texts while I am riding. It is just my preference to keep distractions to a minimum. I usually will stop to load a route or do a search on the GPS. But while riding I will occasionally want to zoom in or out and scroll the screen for compass, trip info, etc. So having that feature on the wonder wheel for ME is a real value add. I did like the feature not the new Garmin Zumo that alerts of incidents ahead. That would add to safety. Oh ... and I don't need music through the GPS. But again that is just my preference.
Ed Apelian
GSinNC is offline
post #40 of 57 Old Apr 27th, 2020, 9:09 am
Dann323's Avatar
This the last response from Garmin:
Thank you, I have let them know that it did not have an effect on the issue. It does seem to me as well that it is a software issue. I do not have an answer for if or when the issue will be fixed but you can keep your device up to date with Garmin Express. Otherwise if they do release a fix you should be notified by email.
PatM55 likes this.
Daniel
Dann323 is offline
post #41 of 57 Old Apr 27th, 2020, 4:57 pm Thread Starter
Actually you're not the only one- I don't use my GPS for anything other than for navigation. Even then, I have the unit on mute because I don't need it to tell me what I can easily read. I pair my phone to my 20S and I stream music and phone calls directly to it. It's my opinion that the BMW audio system is absolute shit and I've removed the speakers and receiver from the bike.
I am not sure why Greg is making a big deal about traffic and weather alerts- the Nav VI, when paired with the phone app, does the same thing. Honestly though, I've found that the weather alerts were useless and I would just use my phone's weather app to tell me what to expect. When on long trips, I would make an Excel table that would show each stop, what time I am expected to be there, how far to that stop from the previous stop, and the rain % and temperature. I would freeze the leftmost columns so I could swipe horizontally through the table for easier reading.
post #42 of 57 Old Apr 27th, 2020, 6:52 pm
GSinNC's Avatar
I think he audio on my 2016 RT is actually pretty good and will turn in on when on long straight roads like Kansas of Nebraska and listen to XM. And I do use the Nav directions through the RT audio when I am on a congested area and want to make sure I don't miss a turn. But for the most part I just use my GPS for well GSP stuff. I have a Sena that I only use when riding with a buddy or 2. I just like to keep things simple. My phone is not paired to anything and like you noted if I need to look at weather app or Pure Gas app I will just stop and check my phone. I am never in that much of a hurry.
reg26 likes this.
Ed Apelian
GSinNC is offline
post #43 of 57 Old Apr 27th, 2020, 8:54 pm
Dann323's Avatar
Actually it's possible
https://www.bmwlt.com/forums/rt-seri...ml#post1905533
Daniel
Dann323 is offline
post #44 of 57 Old Apr 27th, 2020, 11:57 pm Thread Starter
That's interesting.
post #45 of 57 Old Apr 28th, 2020, 1:45 pm
works fine for me
juanlien is offline
post #46 of 57 Old Apr 28th, 2020, 2:18 pm
Dann323's Avatar
Originally Posted by juanlien View Post
works fine for me
What works fine?
Daniel
Dann323 is offline
post #47 of 57 Old May 9th, 2020, 10:27 am
I sent my NAV 6 in for the swap. My question is since they told me to take the battery out along with the memory card, will my replacement come back with a new battery?
Much older Jap bikes and HD's
Most recent:
2006 HD Street Glide
2009 HD Street Glide
2006 FJR
2006FJR
2013 KLR650
2015 BMW R1200RT
reg26 is offline
post #48 of 57 Old May 9th, 2020, 10:49 am
GSinNC's Avatar
They recently changed their return policy. When I got my new one I opted for them to send me the new one first so I could set it up exactly like my old one. Then I got the replacement it was a new sealed box just like what you buy at the dealer. GPS, carry case, screwdriver, usb cable, etc. But what I've heard recently is they are just sending you a new unit. So you may just get a unit with out battery. Not sure. But it seems they are no longer sending a full sealed box.
Ed Apelian
GSinNC is offline
post #49 of 57 Old May 9th, 2020, 12:51 pm
Dann323's Avatar
My replacement was reburbished one with the battery, even if mine was only two months old
I didn't send the battery with the unit so I have a spare one now
I dealt with Garmin Canada, could be different in the US
Daniel
Dann323 is offline
post #50 of 57 Old May 10th, 2020, 7:18 am
Ha just got my new Nav 6 back and yes it did come with a new battery. Thanks for the replys guys. New unit after a quick ride seems to be working GREAT!
Most recent:
2006 FJR
2006FJR
2013 KLR650
2015 BMW R1200RT
reg26 is offline
