Handel bars not alined with front wheel - BMW Luxury Touring Community
post #1 of 6 Old Mar 29th, 2020, 11:24 am Thread Starter
Renzo's Avatar
I Towed my bike in a closed trailer, tied down per bmw towing requirement.
Got it home unload and noticed that the handle bars don’t line up with front wheel when straight.
Nothing is bent
Just slightly off
Anyone know a way to settle the front to return to alignment?
Renzo
Renzo is offline
post #2 of 6 Old Mar 29th, 2020, 12:00 pm
dleasman's Avatar
Can you detail where you tied down?
Did you only tie down the front end on the fork tubes? Or did you strap from the bars? Maybe both?
I know you said BMW towing requirements, but I am curious what that actually means.
dleasman is offline
post #3 of 6 Old Mar 29th, 2020, 12:29 pm
Stooie's Avatar
Re: Handel bars not alined with front wheel
It would help if we knew the model and year.
Bob Stewart
Salem, Oregon
2018 R1200RT
Stooie is offline
post #4 of 6 Old Mar 29th, 2020, 7:24 pm Thread Starter
Renzo's Avatar
The front forks like it says in the manual I did not put it on the handlebars used the manual and followed the directions carefully it’s a 2016
Renzo
Renzo is offline
post #5 of 6 Old Mar 29th, 2020, 7:28 pm Thread Starter
Renzo's Avatar
Other bike forums suggest (not BMW) To loosen the front forks and pump the front like your giving CPR then tighten
My bike is a 2016 R1200RT
Renzo
Renzo is offline
post #6 of 6 Old Mar 30th, 2020, 12:36 am
beech's Avatar
I know there may be technical answers. But I suggest to do the dirt bike trick. It is actually the reverse of what you did tying the bike down (too tight). Put the front wheel against something solid and quickly push hard against the handle bars towards that resistance. If the wheel is pointing left put the resistance on the left side and then really push hard on the bars to the left. Same for the right side. This manually moves stuff back where it should be.
Beech
beech is offline
