Speed bleeders - BMW Luxury Touring Community
 3Likes
  • 3 Post By N00bie RT Gawd
post #1 of 8 Old Feb 1st, 2020, 9:42 pm Thread Starter
Dann323's Avatar
Speed bleeders
Anybody knows the model number for speed bleeders on a R1250RT?
All my internet searches only got me generic speed bleeders.
I only found for 2013-2017 RTs
Daniel
If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
IBA # 56396
MOA # 171966
2019 R1250RT (0 km)
2007 R1200RT (186000 km)
Dann323 is offline
post #2 of 8 Old Feb 1st, 2020, 11:00 pm Thread Starter
Dann323's Avatar
Re: Speed bleeders
Ok found my own answer
They are the same as the 14-18 RTW
3 different ones
R1200RTW
13-17
Front
SB8125L right
SB6100 left
SB1010S rear
Daniel
IBA # 56396
MOA # 171966
2019 R1250RT (0 km)
Dann323 is offline
post #3 of 8 Old Feb 2nd, 2020, 9:56 am
PadG's Avatar
Re: Speed bleeders
Dan - double-check that data! The 1250 have different manufacturer for the front brake, it's no longer Brambo, and so I suspect that the bleed screws will be different.
Pad. Gajajiva
Solon, OH, USA
2015 R1200RT (San Marino Blue Met.) - FOR SALES!
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #4 of 8 Old Feb 2nd, 2020, 10:40 am Thread Starter
Dann323's Avatar
Re: Speed bleeders
I'm aware of that.
The front ones are made by Haynes and the rear is still Brembo
That's why I compared the part numbers from both
The parts fiche shows the same part numbers for the 2017 R1200RT and the 2019 R1250RT.
Daniel
IBA # 56396
MOA # 171966
2019 R1250RT (0 km)
Dann323 is offline
post #5 of 8 Old Feb 3rd, 2020, 9:35 am
PadG's Avatar
Re: Speed bleeders
Nonetheless, you don't need them for a couple of years yet, and I would suggest holding off getting any until then, and you might find that the sizes may be listed on SpeedBleeder site, and give you the confirmation or not. That's what I am planning to do, since the logical time to change to the device is right at the time that you do your brake flush.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #6 of 8 Old Feb 3rd, 2020, 9:50 am Thread Starter
Dann323's Avatar
Re: Speed bleeders
That was the plan
Great minds think alike
Daniel
IBA # 56396
MOA # 171966
2019 R1250RT (0 km)
Dann323 is offline
post #7 of 8 Old Feb 3rd, 2020, 5:11 pm
N00bie RT Gawd's Avatar
Re: Speed bleeders
I disagree...one should NEVER POSTPONE the purchase of a new tool or farkle, even when not needed immediately!
BTW, if I remember correctly, these three bleeders require THREE different-sized wrenches! But man, these things are SO WORTH IT! They are so much fun to use, that I change my brake fluid every time I fill-up!
LAF, Bighopper and PatM55 like this.
Those who say that it can't be done shouldn't interrupt those who are doing it.
Democrats are to America what mold is to bread.
N00bie RT Gawd is offline
post #8 of 8 Old Feb 4th, 2020, 12:24 pm
6speedTi's Avatar
Re: Speed bleeders
If memory serves me right on my 2012rt the manual stated a brake bleed service after the first year of original purchase then every two years afterwards.
Not sure if that changed for later models.
You should look into getting your bleeders ordered so you'll have them available on your next servicing of the brakes. From experience I lost track of spare oil and air filters and went on a panic order. Thinking I had spare parts available for my next servicing. Always be prepared. The only thing you shouldn't store after opening a container is brake fluid. Fresh sealed can everytime. Closely buy the amount you need to minimize waste of fluid and money.
2012 R1200RT
1985 T5 Vespa
2007 Piaggio X9 500 EVO
6speedTi is offline
