R1200RT 2013 engine misfires - BMW Luxury Touring Community
 6Likes
  • 1 Post By bandytales
  • 1 Post By horseiron1
  • 1 Post By beech
  • 2 Post By bruce2000ltc
post #1 of 25 Old Dec 9th, 2019, 2:14 pm Thread Starter
horseiron1's Avatar
As the title says, I’m having a serious misfire on the low end and also while shifting. At highway speeds the bike runs perfect. If a pull the clutch in the bike dies. I can start it right back up. And it’s only intermittently. Some days it runs perfect. Bike has 45,000 miles. Last service was at 42,000. I went ahead and replaced the spark plugs but no change. It does do it more when it’s cold than hot. My valves were within spec and same with throttle body sync. I have a 911 and I have no codes. I thought it might be the coils but I’ve read that they just go out and are not intermittent failure. So at the moment I’m at a loss. Thanks
horseiron1 is offline
post #2 of 25 Old Dec 9th, 2019, 2:43 pm
Pappy53's Avatar
Re: R1200RT 2013 engine misfires
Recalibrate the throttle:
  1. Ignition off, turn the throttle fully open and hold.
  2. Turn on the ignition (do NOT start).
  3. Cycle the throttle full-min-full three times (I'm not sure about the number of cycles but three has worked for me).
  4. Ignition off.
  5. With the throttle at idle, start the engine.
I had a similar situation last year. Then, I added some Seafoam and that seemed to help. This time it running rough and cutting out (no backfire though) and I think was due to my fiddling with the battery. It was corrected immediately after I did the above procedure.
It's not clear to me that will fix your problem but it can't hurt and takes all of 5 seconds to do. Try it before you go buy some Seafoam.
'13 R1200RT 90th Anniversary Edition
Pappy53 is online now
post #3 of 25 Old Dec 9th, 2019, 3:02 pm Thread Starter
horseiron1's Avatar
Ok. I’ll try that. I replaced the battery back in September and I think I did that procedure then. But that’s easy to do. I’ll do that after I get off work.
post #4 of 25 Old Dec 9th, 2019, 7:02 pm Thread Starter
horseiron1's Avatar
I tried the throttle recalibration and it was no change. Thanks though.
post #5 of 25 Old Dec 9th, 2019, 8:58 pm
Pappy53's Avatar
Seafoam time...
post #6 of 25 Old Dec 10th, 2019, 5:02 am
bandytales's Avatar
Originally Posted by horseiron1 View Post
I thought it might be the coils but Iíve read that they just go out and are not intermittent failure.
Not so. The stick coil problems I have had over the years have NEVER been total failures. They have been deterioration. Maybe worth an investigation. However, I am not sure the GS911 would pick up on that.
2003 R1150RT & 2017 R1200RT
bandytales is offline
post #7 of 25 Old Dec 10th, 2019, 5:22 am Thread Starter
horseiron1's Avatar
I did the sea foam about 2 weeks ago. It helped for couple days then back to engine miss.
This weekend I’ll troubleshoot the stick coils. There is a pretty good write up over on advrider.
Last night I checked the operation of the exhaust flapper and it’s working correctly. I did notice that it was really black and sooty(if that’s the correct term. Lol). At the last service it was a light brown. And I visually checked the fuel pump controller for obvious signs of corrosion/wear and it looked brand new.
Just letting everyone know what I’ve done so far. Thanks again for everyone’s help.
post #8 of 25 Old Dec 10th, 2019, 8:02 am
PadG's Avatar
I second the idea that it is the coils.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #9 of 25 Old Dec 10th, 2019, 9:55 am
Pappy53's Avatar
Yes. Do keep us informed. These kind of posts inform anyone that may one day have similar issues. Also, please be sure to follow up with your final resolution. It's very common that folks will post a question about a technical issue but not tell us later what it turned out to be.
As I mentioned, I had a similar issue last year that resolved itself with the Seafoam but for all I know it may still be lurking. I'm going to file your findings away in case it recurs.
post #10 of 25 Old Dec 10th, 2019, 9:56 am
bandytales's Avatar
This weekend Iíll troubleshoot the stick coils. There is a pretty good write up over on advrider.
Have you got a link to that?
I am interested in as much as I never found a useful way to test them EXCEPT by substitution.
beech likes this.
post #11 of 25 Old Dec 10th, 2019, 7:57 pm Thread Starter
horseiron1's Avatar
https://advrider.com/f/threads/testi....946092/page-2
About the middle of page 2 a person explains what he did to test his 06 1200 GS by disconnecting the wiring to each one. And figuring it out that way. I’m going to try that this Sunday. (Dec 15, 2019).
post #12 of 25 Old Dec 10th, 2019, 7:59 pm Thread Starter
horseiron1's Avatar
I will. That’s how we all learn. I’ll update as I go along.
Pappy53 likes this.
post #13 of 25 Old Dec 11th, 2019, 5:39 am
bandytales's Avatar
About the middle of page 2 a person explains what he did to test his 06 1200 GS by disconnecting the wiring to each one. And figuring it out that way. Iím going to try that this Sunday. (Dec 15, 2019).
I'm afraid it ain't that easy.
If you read the thread (you linked to), you will find that it works for one bike but not another. Steptoe seems to make it clear that it is easy to identify, but really, it isn't.
It is worth trying the procedure though. If it works and your bike runs cleanly with either the upper or lower set, but not the other way then you may have a 'win' situation. However sometimes there are 2 coils playing up.
Substitution with KNOWN good ones is by far the best way.
PatM55 likes this.
post #14 of 25 Old Dec 11th, 2019, 9:17 pm Thread Starter
horseiron1's Avatar
That’s true. Same thing also if when I get to try it out then the bike runs perfect, since it only does it intermittently. I wish I could find a definite way to say if they were good or bad.
post #15 of 25 Old Dec 12th, 2019, 5:35 am
bandytales's Avatar
Ha! that is so true. You would thing that being electrical / electronic devices, you would be able to plug a box into them and know. However, with temperature / moisture / pressure / reluctance (to mention just a few) variable that come into play it just isn't that straightforward (sometimes).
Occasionally you can see something obvious. Like the body of the coil corroded or bulging a little. But so often nada.
post #16 of 25 Old Dec 12th, 2019, 2:27 pm
beech's Avatar
Here is a good place to purchase a full set of stick coils for your bike. They are on sale at an amazing price. Also get the puller for 10 bucks. Not using one easily damages coils.
https://www.euromotoelectrics.com/category-s/1754.htm
6speedTi likes this.
Beech
beech is offline
post #17 of 25 Old Dec 12th, 2019, 7:43 pm
6speedTi's Avatar
Yes I purchased items from them several times. They ship fast. Mostly 2 day shipping. Great website to research parts and part number applicability.
2012 R1200RT
1985 T5 Vespa
2007 Piaggio X9 500 EVO
6speedTi is offline
post #18 of 25 Old Dec 12th, 2019, 9:03 pm Thread Starter
horseiron1's Avatar
Ok cool. I’ll check them out. Thanks
post #19 of 25 Old Dec 12th, 2019, 9:31 pm
At 45k I had to replace the o2 sensors. My bike would die at lower rpm but always start back up. Never did show a code but I did see on the graph on 911 that it was acting up
mwood7800 is offline
post #20 of 25 Old Dec 15th, 2019, 6:33 pm Thread Starter
horseiron1's Avatar
I went out today to troubleshoot some more and the bike ran perfect. Imagine that. So unplugging and replacing the coil had the expected change in engine performance but didn’t tell me that was a definite problem of a coil being bad.
However, I hooked the GS911 back up and checked the o2 sensors and the graph is all over the place. Way too rich and bottomed out on way too lean. The graph wasn’t very uniformed either. Very erratic pattern.
post #21 of 25 Old Dec 17th, 2019, 2:44 pm
beech's Avatar
Normal pattern is up and down. A straight line indicates NFG.
Beech
beech is offline
post #22 of 25 Old Dec 18th, 2019, 9:51 am Thread Starter
horseiron1's Avatar
Normal pattern is up and down. A straight line indicates NFG. <img src="http://www.bmwlt.com/forums/images/BMWLT_2015/smilies/tango_face_surprise.png" border="0" alt="" title="EEK! Surprise!" class="inlineimg" />
Ok, then they were working. Thanks
post #23 of 25 Old Dec 30th, 2019, 7:16 pm Thread Starter
horseiron1's Avatar
Update.
Just to let everyone know that I got a deal on coils and oxygen sensor from the company that Beech recommenced. So I replaced all 4 coils and both oxygen sensors. And there was no change. It’s still misfires. Pretty bummed out at the moment. I went about 40 miles and it only does it random. I can’t replicate the problem.
post #24 of 25 Old Dec 30th, 2019, 10:35 pm
bruce2000ltc's Avatar
Update.
Just to let everyone know that I got a deal on coils and oxygen sensor from the company that Beech recommenced. So I replaced all 4 coils and both oxygen sensors. And there was no change. Itís still misfires. Pretty bummed out at the moment. I went about 40 miles and it only does it random. I canít replicate the problem.
I would post your problem on the BMWSportTouring site in the Camheads forum. There is a member "dirtrider" that is very sharp that might be able to help with your misfire problem.
bandytales and 6speedTi like this.
bruce2000ltc is offline
post #25 of 25 Old Jan 1st, 2020, 7:38 pm Thread Starter
horseiron1's Avatar
Update.
Ok. Thanks
