My display keeps resetting itself - BMW Luxury Touring Community
 3Likes
  • 1 Post By beech
  • 1 Post By PadG
  • 1 Post By bandytales
post #1 of 16 Old Dec 1st, 2019, 11:58 am Thread Starter
Every time I start a ride the dash display has erased the digital speedometer with the RT logo. I must go through the menu and reset it again. Does this mean anything?
siclmn is offline
post #2 of 16 Old Dec 1st, 2019, 1:32 pm
alegerlotz's Avatar
Re: My display keeps resetting itself
Yes, you need a battery. How old is yours? Does it crank up nice and fast or does the starter seem labored.
It could be other things, but my bet is on the battery getting weak. You can have it tested, or if its over 3 years old, skip that and just replace it.
2016 R1200RT
alegerlotz is offline
post #3 of 16 Old Dec 1st, 2019, 3:16 pm Thread Starter
Yes that is what I thought but the battery is only 8 months old and it was an $89 battery from one of those batteries+Bulbs stores. I thought I would see how long a cheap battery would last and I found out. So now is the age old question of which battery to get?
siclmn is offline
post #4 of 16 Old Dec 1st, 2019, 3:44 pm
If the battery is not at least $200 the BMW's will reject it!!
I have no advice on a battery, but I do know sometime last month there was a post debating batteries for the RT.
Kabish is offline
post #5 of 16 Old Dec 1st, 2019, 9:14 pm
Cat Herder
tvguy's Avatar
You need this. About $150ish at any bike shop other than BMW. Model GYZ16H It is the highest end unit for your bike
Tvguy
'16 R1200RT - "Golden Eye"
tvguy is offline
post #6 of 16 Old Dec 1st, 2019, 10:16 pm
garr2's Avatar
Recent battery thread
My plan is to live forever. So far so good.
garr2 is offline
post #7 of 16 Old Dec 2nd, 2019, 12:33 am
beech's Avatar
Battery suggested up a couple of posts looks good. I'm interested too. But for now Here is a battery I have used three times for ten years in my K13S. Works great and is cheap to your door.
https://www.atbatt.com/yuasa-ytx14-b...ports-battery/
I like it because you add the acid yourself so it is fresh. Follow the instructions. Do not leave out the charging after filling. That gives you 20% more capacity than not doing it.
LAF likes this.
Beech
beech is offline
post #8 of 16 Old Dec 2nd, 2019, 8:24 am
PadG's Avatar
You guys needs to know how to shop!!!!
You can get a good quality battery for that $89. See: https://www.walmart.com/ip/YUASA-GYZ...FREE/129243723 The perfect battery for the wethead RT!
On topic - I agree with the comment that it's probably your battery. You need to have it checked out. The symptom that you are having is typical for when the battery starts to fail.
dleasman likes this.
Pad. Gajajiva
Solon, OH, USA
2007 R1200RT (Sold!)
Once Upon a Time........
1963 Norton Dominator 650 SS
1960 Triumph Thunderbird (6T)
1952 Triumph Thunderbird (6T)
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #9 of 16 Old Dec 2nd, 2019, 8:27 am
PadG's Avatar
See my previous post!!!!
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #10 of 16 Old Dec 2nd, 2019, 9:08 am
bandytales's Avatar
To the OP.
Take your fully charged battery over to a tyre of battery depot and ask them to do a Capacity test on it. It will reveal the state of your battery.
In the UK, this test is normally free.
2003 R1150RT & 2017 R1200RT
bandytales is offline
post #11 of 16 Old Dec 2nd, 2019, 1:18 pm
Originally Posted by bandytales View Post
To the OP.
Autozone will test them for free as well in the US
Kabish is offline
post #12 of 16 Old Dec 2nd, 2019, 6:51 pm Thread Starter
I had the battery tested at the place that I bought it and of course they said it was good.
I ordered a new Yuasa from wall mart anyway. Better safe.
siclmn is offline
post #13 of 16 Old Dec 2nd, 2019, 11:36 pm
Cat Herder
tvguy's Avatar
remember "FACTORY ACTIVATED" means the acid is already in the battery. It could have been sitting on a shelf for a year or more. My battery was activated when I bought it. That's why you pay the big bucks
Tvguy
tvguy is offline
post #14 of 16 Old Dec 3rd, 2019, 8:44 am
PadG's Avatar
This is the very same battery as the one that you had suggested, and so I assume it's the same one that you are using. FYI, when the battery is delivered, it will be accompanied by a note indicating when the battery was activated and the voltage of the battery measured immediately before shipping.
Pad. Gajajiva
Solon, OH, USA
1932 Triumph 500
1952 BSA Goldstar
PadG is offline
post #15 of 16 Old Dec 5th, 2019, 6:40 pm
You are spot on Beech. Just read an article on the topic in MCN , last month or two, on the subject. If you buy a battery from a good dealer you should be reasonably assured that they did the proper fill and charge process. Ask them to be sure. They will appreciate that you are aware of the need to condition a new battery correctly. Easier to return it to them if there are issues. Not sure how Yuasa would respond if you were responsible for the initial charging. Some peep get six years or more out of a AGM battery. Must be doing things right with maintenance also.
Sirby is online now
post #16 of 16 Old Dec 6th, 2019, 5:39 am
bandytales's Avatar
Why didn't you get the battery tested at an independent location. That way you cam go back to your purchase shop with some ammunition to argue the case and get a refund (IF it was the battery).
LAF likes this.
