Torque number for these bolts? - BMW Luxury Touring Community
 1Likes
  • 1 Post By dleasman
post #1 of 11 Old Nov 27th, 2019, 8:08 pm Thread Starter
dleasman's Avatar
Do any of you have a service manual that indicates the torque of these 2 bolts? I am installing my crash bars, and will need to re-torque them on re-assembly.
On the right side, there are 2 bolts, and I need to remove the forward bolt (right side of pic) and ol the left side, near the kick stand mount, I need to remove the top, forward bolt (top left side of pic).
Also, I assume blue loctite would be required? Or, should I use anti-sieze? (I have both on hand)
If anyone with a service manual could help me out, I would appreciate it.
ID:	155189   Click image for larger version
dleasman is offline
post #2 of 11 Old Nov 27th, 2019, 9:40 pm
davebullock's Avatar
Re: Torque number for these bolts?
looks like 42 in my manual, if they are paralever mounting bolts
2000 LT 213K miles
2010 RT 35K miles
2007 RT P 42,000 miles SOLD
1982 vision 550 Yamaha SOLD
Four corner SCMA ride 2013
All Yooper SS1000K, 6/17/17, 6/19
48 state/12 day ride 2016
Great Lakes Challenge, 2011
davebullock is online now
post #3 of 11 Old Nov 28th, 2019, 5:04 am
bandytales's Avatar
Yes, Loctite required
I have it as 55Nm for those M10 x 45 Torx bolts:
See what you think.
Name:	Engine to frame fastener  torque.JPG
2003 R1150RT & 2017 R1200RT
bandytales is offline
post #4 of 11 Old Nov 28th, 2019, 9:28 am Thread Starter
dleasman's Avatar
See what you think.
Yes, that is exactly what I needed. Bolt #3 on each side. I agree that we are reading it correctly. I wonder why they number the bolts, but don't reference the number? Anyway... Thanks for the doc image. Very helpful.
dleasman is offline
post #5 of 11 Old Nov 28th, 2019, 1:41 pm
beech's Avatar
blue 242 loctite. Never use red.
Beech
beech is offline
post #6 of 11 Old Nov 29th, 2019, 7:25 pm Thread Starter
dleasman's Avatar
Thanks again for the help. My engine guards are now installed. Blue loctite on those frame bolts. 55nm (40-41 lbs). Also have the B6 and CANsmart installed. Had to do some repair on my upper ferrings. Next is mounting the DR1 lights on the bars, and then putting all the panels back on.
dleasman is offline
post #7 of 11 Old Nov 29th, 2019, 8:14 pm
Don't remember -- did you buy the under mirror mounts for the DR1's? If so, you may want to file a slot in the fairings for the wiring to pass through. This allows the fairing panels to lay smooth over the bike, and may reduce the pressure on those fragile clips.n
Jack Goertz
'12 Triumph Bonneville
'15 BMW R1200RT
BamaBiker is offline
post #8 of 11 Old Nov 29th, 2019, 9:07 pm Thread Starter
dleasman's Avatar
Originally Posted by BamaBiker View Post
Did you buy the under mirror mounts for the DR1's?
No. I did not want them there. They would be too close to the signal lights, and would wash them out. Plus, the high beams and halos are up there too. I wanted them lower, for the triangle of light.
I mounted them on my crash bars using the Denali bar mounts. The U bracket is down and forward, to stay below the bar, but out in front of the left valve cover, which is further forward than the right.
I still need to tighten, aim, finish cable ties, adjust the CANbus settings, and re-assemble. I have attached one photo of the left light on the bar, so you can see what I am talking about.
I also have the B6 tail light working.
I did another post today, showing how the previous owner repaired the broken clips, with metal ones. The fix works... I had no idea they were broken until I removed the panels.
davebullock likes this.
dleasman is offline
post #9 of 11 Old Nov 29th, 2019, 9:39 pm
Just where I have my Clearwater lights. Good move
2000 LT 213K miles
2010 RT 35K miles
post #10 of 11 Old Nov 30th, 2019, 8:35 pm
I have mine programmed to go out when the signals are active. I also have programmed them to flash when activating the horn (Denali Mini-SoundBomb). Someday I may add the smallest Denali lights on the lower forks to get that tall/narrow triangle of light. I like the way the high-mounted lights light up the road without the wheel blocking part of the light pattern.
There's always another way to install something, to make it more "yours".
Jack Goertz
'15 BMW R1200RT
post #11 of 11 Old Nov 30th, 2019, 8:41 pm Thread Starter
dleasman's Avatar
I ran the other 2 cables to the front for the horn and 2nd set of lights. The ends are capped off and zip tied out of the way, for now. Easier to run all wiring whilst I had it dismantled.
Again, I really like the Denali Elevtronics system.
dleasman is offline
