Another $%^&*() Tire Thread! - BMW Luxury Touring Community
 13Likes
  • 3 Post By Rider2
  • 3 Post By Pappy53
  • 2 Post By Rider2
  • 1 Post By Goose11
  • 2 Post By reg26
  • 2 Post By reg26
post #1 of 16 Old Nov 11th, 2019, 1:32 pm Thread Starter
Well, I don't intend to start a new tire discussion but I did want to let you all know the basics of motorcycle tire use hasn't changed. Yup, my new tires (Dunlop RSIIIs) are way better than the worn out Michelin RP4 GTs that were on the RT before. Yup, the source of 1,000 glowing tire reports is still there.
A little more seriously, while I can't say the RP4s weren't good I believe the Dunlops have a little better turn in and generally give a little better feedback and a planted feel I really like in the twisty stuff. I tested on a road known to some as SRC, a major twist fest.
Finally, it is great to know I'm not crazy for riding a BMW. This is the first time I've had the front wheel off, wow that was easy. I love the way the inner (flat black plastic) fender is cut away to make it easy to pull the wheel almost straight up, avoiding the wheel clamp on my lift table. By far the easiest dual disc front wheel I've pulled. Everything else was done really well, the alignment dowels for the calipers, only 4 screws to pull the "snow shovel" outer fender, I made a simple tool for the big allen screw on the axle so that was easy too. Great job legendary gnomes of Germany.
Livin' the good life in my little home by the sea.
Goose11 is offline
post #2 of 16 Old Nov 12th, 2019, 8:54 am
jrjackson651's Avatar
Re: Another $%^&*() Tire Thread!
It's good to hear you like the Dunlops. I'm a transplant from riding H-D's the last 15 years and always liked the Dunlops on my Touring bikes. Some switched to Micheline, some to Metzler, but the Du(Rocks) always had good road feel, good overall mileages and rarely cupped. When I switched over to the BMW RT world, I bought a used 2009 that needed tires, so at the recommendation of MAXBMW, I had them put the RP4 GT's on it. I checked my tires for wear this past September before a major trip up to Maine for a week of spirited riding and was somewhat surprised to see they were already down to 4mm after only 6000 miles of use, and I noticed some cupping on the front sides, the center was fine. I'm used to getting around 15 to 17K from a set of Dunlops, but from what I have read and heard, the RT's go through rubber fairly rapidly. That being said, I don't mind as much because a set of rubber installed by MaxBMW was around 1/2 the $ of my RoadGlide Ultra. So, come Springtime, I will most likely need some new shoes for my RT, and will look at all contenders. I've had Bridgestones on my Sportster and liked them, but, if the RP5 GT's get good reviews, I may go with them, I like the feel of my RP4's just fine.
Thanks for your review.
jrjackson651 is offline
post #3 of 16 Old Nov 12th, 2019, 9:03 am
rockitcity's Avatar
Well, I don't intend to start a new tire discussion...
Yes you do!
New tires always transform the feel of a bike. The only fair way to compare the Michelins vs the Dunlops would be to swap wheels with new tires on each set, but who's going to do that?
I have a set of Continental Road Attack 3's I'm waiting to put on my RT, but the Michelins just won't wear out. I keep thinking they are almost done, but they keep holding clear of the wear bars. The front is getting a little triangular, and the rear is getting squared off, but handling has not gotten to the point that I feel I need to change them. They were on the bike when I bought it so I don't know how many miles they have. I have been accustomed to getting 15-17,000 miles on PR4's on previous bikes, but I don't ride very aggressively, mostly commuting.
Glad you like the Dunlops, keep us posted as to their wear properties.
rockitcity is offline
post #4 of 16 Old Nov 12th, 2019, 10:51 am
Rider2's Avatar
This is OIL THREAD season, c'mon, get with the program.
All you need to know about tires is to change out the summer air for winter air, and you'll be fine.
pkpr1998, tvguy and Goose11 like this.
2020 R1250 GSAW Low
2016 R1200 GSAW Low (traded)
2015 R1200 RT (traded)
2012 K1600 GTL (traded)
2012 R1200 RT (totaled, RIP)
Rider2 is offline
post #5 of 16 Old Nov 12th, 2019, 11:50 am
Pappy53's Avatar
I like using 75W-90 hypoid gear oil on my tires. I find they look much nicer after a fresh lube. Of course, I seem to wreck my bike after every application. Funny how that happens. Bad luck I guess. Good thing I put on a set of crash bars in the spring...
...say, you guy don't think they might be related do you? Am I using the wrong lube?
Bill, pkpr1998 and Rider2 like this.
'13 R1200RT 90th Anniversary Edition
Pappy53 is offline
post #6 of 16 Old Nov 12th, 2019, 1:57 pm
Rider2's Avatar
They totally do look nicer but if you still find you're crashing it's probably because you're using the front brake, try using spline grease on the rotors.
Bill and Pappy53 like this.
2020 R1250 GSAW Low
Rider2 is offline
post #7 of 16 Old Nov 12th, 2019, 9:08 pm Thread Starter
Yes
pkpr1998 likes this.
Goose11 is offline
post #8 of 16 Old Nov 13th, 2019, 4:51 am
bandytales's Avatar
Originally Posted by Goose11 View Post
Finally, it is great to know I'm not crazy for riding a BMW. This is the first time I've had the front wheel off, wow that was easy. I love the way the inner (flat black plastic) fender is cut away to make it easy to pull the wheel almost straight up, avoiding the wheel clamp on my lift table. ...
What bike do you have?
2003 R1150RT & 2017 R1200RT
bandytales is online now
post #9 of 16 Old Nov 13th, 2019, 12:53 pm
zippy_gg's Avatar
His garage says 2018 RT
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #10 of 16 Old Nov 13th, 2019, 1:00 pm Thread Starter
That is correct, sorry to leave a very important detail out of my original post.
Goose11 is offline
post #11 of 16 Old Nov 14th, 2019, 5:04 am
bandytales's Avatar
What is this 'Garage' you talk of?
post #12 of 16 Old Nov 14th, 2019, 6:04 am
Here is the best review I have seen:
Stooie and jrjackson651 like this.
Much older Jap bikes and HD's
Most recent:
2006 HD Street Glide
2009 HD Street Glide
2006 FJR
2006FJR
2013 KLR650
2015 BMW R1200RT
reg26 is offline
post #13 of 16 Old Nov 15th, 2019, 9:53 pm Thread Starter
Thank you very much, I assumed the superior feel and (apparent) traxion of the Dunlops would cost me milage, maybe not. Lower cost, better feel and superior life, seems like a good deal.
Also nice to see and hear Moshe, I used to read his stuff in MCN. I subscribed to his channel, I look forward to more from him in the future.
Goose11 is offline
post #14 of 16 Old Nov 16th, 2019, 9:21 am
I think the most interesting thing he said is how we really can't compare tires between different riders as there are to many variables. So his review is with the same bike and same roads over many miles. I'mm going to try the RS III's for my next tire change
PatM55 and Goose11 like this.
Most recent:
2006 FJR
2006FJR
2013 KLR650
2015 BMW R1200RT
reg26 is offline
post #15 of 16 Old Nov 17th, 2019, 1:02 pm
zippy_gg's Avatar
Look in the left column, under his name, and you will see a "Garage" hyperlink.
Just click on it...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #16 of 16 Old Nov 18th, 2019, 6:15 am
bandytales's Avatar
Just click on it...
