Has anyone ever needed to pop start the LC RT or even tried? I was just wondering if it can be done on modern motorcycles like the RT if a battery drains too much.
I never try on the newer bikes, but I have done it on 11 and 1150 countless times, they actually start after a few feet (much easier than a "Normal" bike)
Yep! Have done it once. Stopped at a service station to fuel the bike up. Went to start it, dash lit up, hit the starter, and dash display died. Release the starter button and dash came back up again. Luckily the servo was situated on a slight hill. Was able to roll down the hill in second gear and pop the clutch at the same time as bouncing on the seat and the engine fired up. Got home and checked out the problem. Battery had likely dropped a cell. New battery the following day and all good.
That was because you still had fuel pressure built up. That will not work unless the bad battery has enough juice to get the fuel pump running for a cold start.
That's why I carry a jump starter battery pack in my tank bag. The one I have is about the size of my iphone but slightly thicker. I've used it to start cars, trucks and my '13RT on a cold morning in Colorado a couple of weeks ago - fired it right up. Bought it on Amazon a few years ago for less than $50.00. Gives you peace-of-mind when you have an old battery.
Yes I got in a dead battery situation while traveling...left the key on...oops...and even loaded with travel gear with a dude helping to push on blacktop in a high gear....could not make it happen....seemed like it just slid the tire and would never turn over...so a jump box to the rescue...2014 RT
I tried with a battery with 3 volts in it (didn't know it at the time) with someone pushing me and it was a nogo. Ran okay on the alternator okay but once I turned it off that was it. I would assume if you could get the alternator to generate a bit of power it would go.
However it is a big beast to push start unless you have a good downhill slope.
Related Threads
BMW Luxury Touring Community
894.3K posts
44.8K members
Since 2005
