WH Front Seat Heating Element - BMW Luxury Touring Community
post #1 of 2 Old Yesterday, 12:07 pm Thread Starter
EzyMount's Avatar
I have an RDL set that is being recovered. When top of the front seat was pulled back, the heating element was attached (excessive glue) to the foam material used on the underside of the top cover. It would not detach, even with heat applied. So removal of top cover pulled heating element apart making it unusable !!
Of course yu cannot buy just a heating element from BMW, which forces me to an aftermarket element. BMW also does not publish, or make available the max allowable power draw the CANBUS will allow, before shutting it down !
> Anyone ever been thru this, or have any idea what the power draws are for low and high setting for front seat.
The aftermarket element I am looking at requires a min 10A fuse.
The kit comes with a relay and its own switch, so I may be forced to run it on its own controller if bikes canbus wont allow it..
Tks for any inputs !
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is offline
post #2 of 2 Old Today, 8:12 am
bandytales's Avatar
Re: WH Front Seat Heating Element
Maybe someone with a stock heated saddle could pop a multi-meter across the contacts at the heated seat and measure the element resistance. That would let you know what current the stock seat draws.
2003 R1150RT & 2017 R1200RT
bandytales is online now
Currently Active Users Viewing This Thread: 6 (3 members and 3 guests)
Dsmith1200, Lynn_Keen, RT-rider
